Question about HP PSC 2350 All-In-One InkJet Printer
Can't get HP PSC 2530 to accept re-filled catridges! Both are full but it keeps telling me to remove and check right-hand one; can't by-pass or override the message.
    Director Badge:
    Uploaded 100 video answers.
  • 1,751 Answers
Hi
In order not to have error messages in your printer
You need to remove all the air bubbles from the cartridges
the best way when you do it alone is bu using refill clips
check here the right method
Hi pls vote us to keep us alive
Posted on Nov 16, 2010
  • 823 Answers
HP printers have computer sensors built into the ink cartridge that tell it when it is empty. When the cartridge is empty and you have it refilled, they have to change the sensor or the printer will still consider it empty.
HP does not want their customers using refilled ink cartridges. Using a refilled cartrige voids your printers warranty.
There is no way to trick your printer to accept the refilled cartridge unless the sensor is changed.
I am sorry and wish I could help you further.
If you want to save money by using refilled cartridges, take your empties to a company who does it professionally. They will know how to change the sensor in the cartridge.
Posted on Nov 08, 2010
My hp psc 2410 keeps reading to remove and check black catridge i clean the contacts, i make reset but nothing. keep saying the same to remove and check black catridge
You could remove both cartridges.
Close cover and turn off printer.
Unplug printer for at least 10 minutes before plugging back into the outlet
Turn on printer and install cartridges.
If this does not correct the problem, the cartridge may be bad.
Dec 25, 2010 | HP PSC 2410 All-In-One InkJet Printer
My printer hp psc 1350 keep on blinking check print catridge even after change new catridge both colour and black..how to settle?
Tried removing the cartridges again, then turn off you printer for 2 mins.
clean the print nozzles of the cartridges, turn the printer on
insert the cartridges again, then check if the problem persist.
You can also try to put the original cartridges that came with the printer
to isolate the problem, if it's really the ink cartridges.
Feb 25, 2010 | HP PSC 1315 All-In-One InkJet Printer
Printer always says "Remove and check color cartridge"
It must be your ruined catridge. Some times the wire connections are burned at the side of the catridge and you must thaw away it and buy a new color catridge.
Oct 28, 2009 | HP PSC 750 All-In-One InkJet Printer
How can we remove the color catridge holders from ht HP psc 2400? Not the cartridges - they are out - but the holders that are filled with old ink.
please your printer in colour catridge in old ink is west and thru out of west dustbin and safe palace. and refling holder to cartridges in refling a new in and use.
Oct 21, 2009 | HP Office Equipment & Supplies
Hp PSC 950 gives me a message to remove and check black cartridge
Did you remove the tape from the contacts of the new black cartridge? If so once the new one is in, unplug the printer from power and power it back on, it should do a full check after a power on off.
Sep 23, 2009 | HP PSC 950 All-In-One InkJet Printer
Display says "Remove and check right cartridge", but even replacing the right cartridge with a new one does not fix the problem, and the printer will not function.
This HP PSC 1610 all in one - scan / fax / copier *** printer, normally the cartridges inserting
locations might have caused some issue. When you install the genuine catridge and getting the
error. Might be the catridge inserter might be replaced with local hardware engineer is the best solution. Moreover this type of printers are HP itlsef is giving the maximum life of 3 years only as printer life time.
In our office we are using HP PSC 1110 - 4-in-1 printer and it is having the same problem, but when the message displayed, we will just say OK and it will automatically print the necessary pages.
Best of Luck always.
Jul 16, 2009 | HP PSC 1610 All-In-One InkJet Printer
I changed my black ink and now i get the message left cartridge incorrect..how do i fix it?
HP PSC 2210 InkJet Printer. The following has to be done for checking the Blank Ink Catridge working : 01. Remove the existing Black catridge and Color Catridges from the Printer carefully. 02. Clean the location with a soft cloth with cleaning liquid to make the place dust free. 03. Put the correct black and colour cartridges recommended by HP and that too genuine one. 04. Do not use any refilled or reinked local catridges that will spoil the HP PSC 2210 printer. 05. Re-install the catridges both Black and Colour properly. 06. Take a test print out - both black and colour print outs. 07. Check the Printer status and there is no warning of Cartridges wrongly inserted. Have a Good day.
Jul 14, 2009 | HP PSC 2210 All-In-One InkJet Printer
Catridge led blinking
Good day. Stop panick .. check for the cables installation, then try to get the ink tank out then check for burn and dust... Usually this kind from product defect or the Electricity symptons.
Tell me the result..
Regards
Paul
Dec 03, 2008 | HP PSC 1410v All-in-One Printer
Cartridge problem
Please remove the printer catridge and clean the the extra ink in the catridge holder and in the catridge connection point with the soft cloth without damaging the cables in the catridge and the holder then test it
T.Boopathy
Jul 22, 2008 | HP PSC 1610 All-In-One InkJet Printer
HP PSC 2350 All-In-One InkJet Printer Logo
373 people viewed this question
Seeker5211
Seeker5211
