Washing machine has high amp draw
I have a Kenmore top-loading washer that is seven years old. After the rinse water drains out and immediately prior to starting the spin cycle, it makes a series of thumping sounds, then starts to spin. At this point, it will often (but not always) trip the 20A breaker on its circuit. Normally it draws 6-8 amps, but as it begins to spin, the current shoots up to around 21 amps and hangs there for 5-7 seconds. The breaker usually trips at that point. However, sometimes the machine will finish an entire cycle without tripping the breaker. Any suggestions as to what the problem might be?
  • 66 Answers
Yes sounds like your motor is breaking down
Posted on Jun 15, 2008
What is best way to have my new Kenmore Elite Top-Loading washer (Model 796.3162) drain into a high pipe 7 feet from floor?
Nope, the drain pipe can be no higher than the Washing machine itself, the pump's to weak will not carry the water
Nov 19, 2014 | Kenmore Washing Machines
Machine is draining as it fills, can not rinse due to this. What may be causing this?
If the drain hose is laying down then the water will flow out as it fills. The drain hose should empty into a 2 inch drain pipe that is about as high as the top of the washer.
Jun 24, 2010 | Kenmore 24032\24036 Top Load Washer
Water will not drain
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 04, 2010 | Kenmore 26882 Top Load Washer
Kenmore Model 22722 will not drain
heatman101
Jun 01, 2010 | Washing Machines
Washing machine keeps draining during rinse
You may be experiencing a condition known as "siphoning". This is caused by the drain hose not being high enough off the floor, or not having a proper air gap at the standpipe in order to drain properly. This creates a suction and the washer will constantly drain as it tries to fill. The following link explains:
http://www.fixya.com/support/r3575830-how_to_prevent_washer_siphoning
In the majority of the cases, this problem is attributed to improper installation, rather than an actual problem with the washer. If you have any questions, please post back and let me know. I hope this helps you.
Apr 08, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
My 3 year old Maytag SAV5710AWW top-load washer
It is your water pump. If you don't know what you are doing it could be tough.
Nov 20, 2009 | Maytag SAV5710 Top Load Washer
Kenmore 22622100 Top Load Washer won't drain the water, nor rinse
HI!!! you seem to have a bad lid switch on your washer..I would also check the timer on it good lucck.
Feb 13, 2009 | Kenmore 22422 Top Load Washer
Whirlpool Washer - Imperial Series Quiet Wash 2
your washers drain hose is too far down the drain pipe which is causing a siphoning action pull the washers drain hose out pipe some you should be able to hear water dropping into the pipe the reason it only happens in the rinse cycle is because the water from wash is being drained and before the water vacuum is broken the rinse water comes in causing it to keep draining
Dec 30, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
10 year old model kenmore top load washing maching won't fill.
That means that eithere the membrane water lever switch is faulty (most common) or that the drain pump solenoid is stuck on open.
Dec 21, 2008 | Kenmore 24032\24036 Top Load Washer
Washing machine
check pressure switch hose
Jan 02, 2008 | KitchenAid KAWS850L Top Load Washer
Washing Machines Logo
284 people viewed this question
Top Washing Machines Experts
