Question about Sony VAIO PCG-GRT360ZG Notebook
I have a sony pcg-grt360 laptop, and I need to install XP from external cd-rom - I can not get into the bios to make the changes to select boot sequence - I need to remove the existing password
  • 11 more comments
  • anves Nov 08, 2010
    I did not put any PW in this LT, One Sony tech says it was PW Protected from the factory, others say it was not. I have tried every PW I could think of, it seems to be 7 Chars
    No, that did not work - I have tried every PW I could of used - In desktops I would remove the battery and that would reset it to default, I can not even find the battery
    I know where to send it, I have spoken with them several times, and each time the answer is different and the price - I do not want to send it out for repair, its too old
    my email address - vinnie@anves.com
    Nice info, but not for mine
  • anves Nov 09, 2010
  • anves Nov 11, 2010
    No, does not work - what I need is a Master PW for a sony using PhoenixBIOS
    Yes I have, I have a zero drive, so can not install software to get the PW
    Does a Back Door Password exists for the bios in this Sony Laptop
    President:
  • 2,777 Answers
Unfortunately this laptop uses the restrictive style of BIOS password. Meaning if you can remove the cmos battery there is a good chance it will not forget the password.
Unfortunately the only way to truly clear it is to replace the whole motherboard which is a nightmare, especially with an older machine like this.
Are you sure there is no way you can get the BIOS password / remember it? I assume that is what is going on, correct?
Please let me know, just reply to my answer here...
Thanks
Tim
Posted on Nov 08, 2010
  • Tim Grayson
    Tim Grayson Nov 08, 2010
    Well that Sony Support person that said it has a default password is mistaken, and if their was a default password they should have know what it was...
    I can confirm there is definitely NO default password set on the BIOS of this laptop... someone somewhere must have set it..
    Did you ever send it in for service, it's possible they did it then, it must have been some time it was out of your control so to speak..
    There is one document that refers to entering the date after pressing F2, I can't imagine that it's referring to the password being the current date but try it I suppose... 1182010 if it wants a 7 digit code...
    Let me know!
    Tim
  • Tim Grayson
    There is a battery but you have to get to the area underneath the keyboard which is extremely difficult on this laptop. Also, removing the battery will not clear the password as it does on a desktop, it is designed in such a way that the password is not removable, they do this for ultimate security so that if you were to lose the laptop / have it stolen someone could never access the machine (if you ahve it requiring BIOS password to even boot, which it sounds like you have it set only to get into the BIOS).
    I am so sorry about that :(
    Tim
  • 3,530 Answers
Hi. Bios password are encrypted passwords. You may try to remove the cmos battery of the motherboard and turn on the system without the battery. This will reset the motherboard. Again, this is not applicable for some motherboards. You may also use manufacturers backdoor password for the motherboard. Here's the link.
  • orwonka
    orwonka Oct 13, 2015
    your method seem to have more truth to it than all the others
  • 656 Answers
To boot from bios when the system start press DEL you will get in to the bios in the boot menu ist boot device enter usb boot your CD must be a boot CD restart your computer while booting you will see boot from CD click enter it will ask do you want to boot from cd click enter again the system will start to boot from CD follow instruction given while loading XP if you cant enter the bios or its password locked remove your cabin cover you will see a jumber pin near the clock CLTRC it contains three pin and two shorted with a jumber remove the jumber and connect the 2&3 pin and restart your computer in some computer the CPU fan wont work dont worry switch of your computer and replace the jumber in the original settings and restart your computer while starting press DEL and adjust the time and date and go to boot menu or you can remove CMOS battery if you cant find the jumber pin and the the follow the above steps this will release your password set your bios to default
Posted on Nov 12, 2010
  • orwonka
    should read ? before you answer if person asking about cmos and can not get into it pressing del on boot up will only get where you are already asking for paeeword
  • 4,472 Answers
The only way to even have a hope of resetting the bios password would be to disassemble the laptop down to the motherboard and get to the CMOS battery that can be removed which will reset all the settings including the password.
Thank you,
Lee
  • 1 more comment
  • Lee A.
    Lee A. Nov 08, 2010
    So you took apart the laptop and couldn't find the battery on the board?
    Thanks,
    Lee
  • Lee A.
    Lee A. Nov 11, 2010
    You will need to disassemble the laptop and find the cmos battery remove that and that is the only way you will be able to install windows from an external device by changing the boot order.
    Thank you,
    Lee
  • Lee A.
    Lee A. Nov 11, 2010
    NO there is no "back door" password.
  • 4,281 Answers
When you power up the computer press F1 or F2 or del or ALT+F2 key to enter in bios if it ask for password then you need to reset it. For that open back cover of laptop then you cans see motherboard pull cmos cell from motherboard for 10 minutes then all settings goes to defaults. Then you can access bios. Let me know if you need further assistance. Thanks for using FixYa.
  • For that you need to open the whole back cover of laptop then you can see motherboard chip set.
    Pull cmos cell from mother board for 10 minutes then check.
  • 2,973 Answers
So, your basic problem is the BIOS password? To remove the BIOS password that you have forgotten, you must remove the bottom plates one by one and find the CMOS battery. Remove this battery for a minute or so and replace it in the seating after that. The BIOS password would have been removed.
  • 4,889 Answers
Which password? BIOS or windows password? Windows password can be hacked by using a tool and BIOS pass can be removed by disconnecting the laptop from all power sources i.e, AC power, laptop battery and CMOS battery.
Posted on Nov 11, 2010
  • eagle338
    eagle338 Nov 11, 2010
    Well I told you what you should do. That is how you should reset the BIOS password
  • eagle338
    And no. There are no back door passwords for any BIOS.
  • 345 Answers
You can try to use system choice to boot to that cd drive. Since you can not get in to bios have you tried to reboot and once system shuts down keep on tapping key F12 and this should bring you option to choose where to boot from. Stop tapping once you see the boot options. Make sure as soon you choose cd rom option to press any key when it asks you to so, so it can boot and load from the cd rom. Hope this works.
Posted on Nov 09, 2010
  • 2 more comments
  • Mihajlo Jerkovic Nov 11, 2010
    Not sure have you tried this and depends on what kinda bios you have. Check this link.http://www.cgsecurity.org/wiki/CmosPwd. You might also have to go to cmos battery and pull it out for couple hours but this requires disassemble of your laptop. Also some laptops have jumper pins that are used to reset bios to factory but you would have to check your manual.
    have you tried thishttp://www.tech-faq.com/reset-bios-passw...
    This is something i found. LAPTOP AND NOTEBOOK RECOVERY
    Most laptop manufacturers have provided additional safeguards for their computers. We are not aware of any simple BIOS recovery program that works on laptops, nor are we aware of any simple backdoor passwords for these machines. BIOS passwords in most laptops are stored in a special chip on the motherboard and the only way to bypass this password is to replace this laptop security chip. Laptop BIOS passwords cannot be bypassed or reset by removing or shorting the CMOS battery. Further, doing this may cause other system errors and complicate the recovery or your system.
    We offer a full-range of replacement laptop security chips. These chips will allow you to bypass the laptop BIOS password. Note that these chips will require soldering on the system board (a hot air soldering kit is also available.) Since these chips store the laptop BIOS passwords, replacing the laptop security chip will remove the BIOS password. However, if a hard disk lock password has been set, it will remain. Passwords can be recovered from the original chip removed from the system board using our Password Recovery Service (PRS) for an additional fee. Since the BIOS password and hard disk lock passwords are usually the same, recovering the BIOS password from the old chip may allow you to access the hard disk. However, this is not guaranteed, since these passwords can be set independently. All replacement chips include detailed instructions. Password Crackers, Inc. cannot take any responsibility for damage to system boards, computers or data. More information about our security chips and our chip password recovery service are available on our security chips page. I think you might have to fight with Sony on this one. Another link has some other suggestions but not sure will it work.http://www.ozzu.com/hardware/laptop-lock... Good luck.
  • Mihajlo Jerkovic Nov 12, 2010
    i believe back door password goes by bios manufacturer and not by model of laptop, at least this is what i have found.
  • Sony Master
  • 13,433 Answers
Hello
For password reseting you must send the laptop to sony for service. please contact sony.
Please get in touch with sony for repair and support
http://esupport.sony.com/US/perl/contact-land.pl
you can not reset the bios password yourself.
Thanks,
Ekse
  • 2 more comments
  • Ekse Nov 08, 2010
    Hey,
    I have a number of sony service manuals, can you give me your email address and I'll email you a few to help you take it apart and find the battery, maybe it helps, but I can't guarantee it.
  • Ekse Nov 08, 2010
    I've sent you a email.
  • Ekse Nov 08, 2010
    In case you didn't get the email or it went to spam or similar let me copy and paste the email here.
    Hello Vinnie.
    I decided to put the manuals on this page instead of attaching them all
    on this email.
    http://ekse.pp.fi/PCG/
    theres all the PCG series service manuals that I have.
    Hope it helps.
  • Ekse Nov 11, 2010
    Okay - I've removed the manuals from the page, suprised that you couldn't figure out how to take it apart with those detail, looking at the service manuals that is for guidance on how other sony machines are built.
I have a sony vaio pcg-srx51p/a, and i want to format it b'coz of viruses. but it doesn't boot from cd, although i have a IDE to USB cable and a internal cd rom drive. how can i format it by using a...
Hello sir, Hi, unless we find a replacement cd drive for your laptop. I don't see how this goes. you see, the laptop you have does not support boot from USB drives, (see setup on the bios first boot, hopefully theres a usb boot option, if not you may opt for a WINME install.) so its useless to use the internal CD rom drive.
Mar 18, 2011 | Sony VAIO PCG-SRX51P/A PCG-SRX51P/B...
Hello. I have Sony Vaio PCG-5426. And I can't reinstall windows on that machine. I have out CD-ROM "II FreeCom" and i try to reinstall with that. In BIOS menu I acces for first boot drive...
you shouldn't need to have to press f9 to boot from cd rom if you have it set in the bios as the first boot device , are you sure the copy of windows on cd that you have is bootable. Try booting from the disc on another laptop or pc and see if you can start it
Another option to try is to boot from a usb drive
instructions on how to do that are here
http://www.xtremesystems.org/forums/showthread.php?t=118576
once you have booted to usb you should be able to access the cd rom
depending on what version of windows you are trying to install you will need to run different programs.
you could also install vista or windows 7 to usb drive and install it from that, it is much quicker than installing from cd/dvd you would need to be able to boot from usb to start with though
how to install vista or windows 7 from usb instructions can be found here
http://www.intowindows.com/how-to-install-windows-7vista-from-usb-drive-detailed-100-working-guide/
please vote for me if you found any of this useful
Feb 20, 2011 | Sony VAIO PCG-5212 PCG-5426 PCG-551L...
I've formated the hard drive of my sony vaio pcg-k33 then try to install a bootable windows xp full but all i get is a black screen and after a while it says bootmngr is missing I don't have the...
Good day,
You have to set the CD as the first boot device in the BIOS.
When you power on the laptop press delete repeatedly until you are in the BIOS.
You then have to browse trough the tabs until you find Boot Priority.
On the first Priority set the CD-ROM and on the second Priority set your hard drive.
Save the settings and exit.
The machine will reboot and will ask you to press any button to boot from disk.
Press any button to launch the installer and you are on your way to install Windows.
Let me know if this solution was useful!
Regards
Nov 29, 2010 | Sony VAIO PCG-K23 Notebook
I have sony vaio laptop whice model is vgn fw 140e. i try to install win xp but i can't install it. can u solve my problem please.
hello, you have to check your BIOS setting if the HARD DRIVE is not above the CD OR DVD ROM, if it is then you must change the settings and allow the CD OR DVD ROM to be above the hard drive,then insert your window xp formatting CD.this time you should be able to install window xp.
Nov 18, 2010 | Sony VAIO VGN-FW140E/H Laptop
How to Install WinXp in Vista Platform
There is very simple procedure.
  • 1st restart your Laptop and enter in bios setup with the help of F2 key or F1 or Del key.
  • After entering in BIOS setup change the Boot order or Boot sequence.
  • Select the booting device 1st boot from CD Rom.
  • Save the setting.
  • Insert windows XP Cd in CD Rom.
  • Now Computer start from CD Rom.
  • You follow the instruction and install the windows.
  • Compaq Notebook Drivers
Mar 20, 2010 | Compaq Presario Notebook
Usb dvd writer can install xp?
Yes you can use a usb external cd/dvd-rom to any operating system as long as the bios allows you to, most bios's have the capability.
When the external usb drive has been connected power up the mechine, in post it should tell what to press to enter your boot menu without entering your bios and choose usb drive to boot.
Jan 22, 2010 | LG GCC4522B CD-RW/DVD-ROM Combo Drive
Trying to install XP when disk selection comes up it reads, "Unkown disk. There is not disk in this drive". NOt sure what that means.
your drive is not being read,
have you set BIOS to boot from CD ROM,
is your CD ROM working,
is your XP CD working
Do the following
1 go to BIOS and re-set to BOOT from CD ROM
2 use another copy of XP/Win98/Vista etc to verify if CR ROM is reading the CDs else...
if you doubt CD ROM drive has a problem....
3 use a USB external CD ROM, and to do that u need to re-set the BIOS to boot from USB CD ROM
Dec 07, 2009 | IO Magic Corporation GigaBank (I250HD35)...
Sony pcg k45
Put the cd in and restart. If it doesn't give you a message to press "x" to boot from cd, then you need to chage the boot order in the BIOS.
To get into the BIOS, restart and press del or F2 (it might say something on the screen like press del to enter setup) that is the BIOS.
Change the boot order to CD first.
Dec 18, 2008 | Sony VAIO K45 Notebook
Problem Installing XP
you can go to your BIOS system set up and select the right sequence if you prefere HDD first then CD-ROM,
depends on your manufacturers settitng pls press F2 or F10 immediately upon start up then you will be prompted to enter password, ( if you know ) then scroll down until you see the booting sequence, dont forget to save this and end your system set up
goodluck
Aug 06, 2008 | Sony PCG-TR3A Notebook
Install Windows XP without a CD drive
You'll need to assign the CD drive (which should show up as USB devicein BIOS or setup) as first boot device, if capable on your model/Computer. After you press power button, you should see a menu or dialog that shows something like 'press F2' or 'Delete' to enter setup. Once in setup, you should navigate thru until you find boot options or something of that nature. Select 'Boot from CD' or ' USB Device'. You should now insert your XP CD into the drive, close the tray, then choose 'Save'. It should now let you boot from the XP CD. At the first screen, you should select 'R' for repair console. It will then ask you to select an installation, type a '1' and then press the 'Enter' key. Next line will ask you to type an Administrator password. If you have one, type it, then press Enter. If no password, just tap the Enter key. Now, at the prompt, type CHKDSK C: /r as in (C: a space /r). then tap the Enter. It shoild now attempt to repair your Windows 2000 installation. When it finishes, reboot, go back into Setup and change first boot device to hard drive. Select Save and reboot LT. Have fun!
Jan 06, 2008 | Sony VAIO PCG-K25 Notebook
Sony VAIO PCG-GRT360ZG Notebook Logo
597 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
