When I'm recording the image on the screen looks good, but stuff that I have recorded has lines all through it, does the camera just need to be cleaned?
No, most camcorders doesn’t work when you recording the image directly on the screen, that means you use your camcorder shot directly to the screen. Maybe the frequency is different, I have tried used RC plugs directly connect to the VCR and recorded, it is much clear.
take a close look to the lens, and if is clean, you have two possible problems
1. the CCD part is almost dead
2. the CCD connector is not in the right position, so you will have to open the camera and ensure that connector is properly set and the lock is on.
You are in luck. Sorry for the trouble but your model Elura 50 still has the CCD advisory from the factory for free repair. Send it in for CCD advisory before it is too late! When all functions are working but has distorted image in camera mode is due to CCD chip. Good Luck -James. for further assitance email, go to www.camerarepairjapan.com
Does the black line record on the tape? When you play back on a TV/Computer can you still see the black line. If you do that would be the image sensor.
Good luck!!
I have a sony 14E and suddenly it stopped playing and recording. With vertical lines on the screen I knew to clean the heads. No effect on the recording/playing malfunction.
However I persevered and it seems to have worked in it is now recording and playing back. The steps I suggest, with PERSEVERANCE, are :
1. Clean the heads (I did it 3 times in all, with about 1 hour between each session);
2. Leave the camera open (tape section) for about 2 hours and put the camera (with or without tape) in a warm place. (I also had condensation messages).
3. Once it is warm put in a recorded tape and attempt to view it. At first I had "dirty" vertical lines for a few seconds but it cleared and played normally.
4. If Step 3 still does not work repeat 1 and 2. As I said PERSEVERE.
If Step 3 works then try to record. It should work hopefully. If not, repeat 1 and 2 (shortening the "Warm Up" time).
Good luck. I hope mine continues to work OK now. It is to do with dirty heads and coldness I think.
Your camera ccd-TRV328 has defect with ccdimagerthat's why not giving picture in camera / recording mode. This part (ccd imager) needs to be replaced and good news Sony will replace it free of cost.
Please click Sony Official Website for details.
Regards,
Defective ccd imager!! the company will replace this ccd imager free of charge. Year 2002 up to 2005 released unit has a factory defect ccd imager. the company recalled those units and replaced with a stronger version of ccd imager ( they are still doing it). check it out.
I had this problem a lot on Labtops. The problem is that it has been unliquifed in the screen. This means that the screen has been damaged or has got really hot. Also its has been on for along time. LCDs go bad real quick and can be a hassle when you need the infomation in the thing and have no display. When I had this problem on my labtop, I used the external bay to use another monitor so I can work on it. So I say that nothing can be done to fix it. The only way to see your stuff on there is to use the video out on the recorder and try to check your stuff. That multicolor lines you saw is becoming major right now in LCD displays. I hope this solves your problem.
The filename (e.g. DSC0012.jpg) shows the image number, the filespec shows the date and time recorded. Most software will give you document info about resolution of the image. I wouldn't worry about what the battery status was when the shot was taken or how many other images were on the Mstick.
I guess I'm not sure what you need.
