Question about GE DBXR463EDWW Electric Dryer
The Dryer will not start but has power as the drum light works.rhe start switch seems to have power going to it but makes no noise when turned to the right and dryer does not start
  • GE Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Nov 11, 2010
Why does my dryer hum?
DRYER MAKES NOISES.
A loose or worn BELT can make funny noises
Or the idler pulley that puts tension on the dryer drum drive belt could be worn out. If the pulley is bad we recommend also replacing the belt.
The glides on drum worn and making metal to metal contact.
The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out.
CHECK FOR LOOSE BELLOES inside the drum
Sometimes an item can get stuck inbetween the drum and the housing and scrape and grind making funny noises, things like coins, bra wire, nails, hair pins, etc sometimes u can just remove the cabinet and observe by turning the drum by hand or looking for scratch or scrape marks on housing.
The blower:
Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel.
The bearings:
The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process.
The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The drum rollers or castors:
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers.
Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density LITHIUM BASE gear grease to re oil/grease them.
GOD IS GOOD !!!!
Apr 23, 2016 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Dryer won't start..light clicking noises
There is a switch inside the unit that stops it when the belt breaks or comes loose. Check that.
Mar 15, 2017 | LG Home Applaince LG DLE2101W 7.3 Cu. Ft....
Kenmore 80 series electric dryer Model - 110-60882990 The dryer won't turn on. Once the start button is pushed it makes a single clicking noise. If I open/shut the door and push the start button...
check the actual door switch,, you can jumper it to see if this is the problem, Just connect the 2 wires together , if this cures the problem replace the switch
May 25, 2011 | Dryers
Dryer makes noise and will not start.I hold door switch and turn drum manualy, dryer starts working
Usually a bad start winding in the motor. Very rarely is it a wiring problem to the motor, especially when it is making noise. This means you have to replace the motor, after examining the wiring going to the motor. Fairly expensive repair. Good Luck, Appliance Specialists.
Dec 09, 2010 | LG DLE2514 Electric Dryer
The drum doesnt seem to turn and makes a VERY LOUD grinding noise. It does seem to be heating up though.
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley.
And it sounds like you have noisy drum rollers.
If you have to replace your drum belt and if you have a front loading machine.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
Good luck,
I hope this helps
Please do not forget to rate me
Thank you
Aug 11, 2010 | GE Dryers
When I press the button to start the dryer it just makes the noise but doesn't kick on. The light was off a few weeks ago and i never got around to change the bulb. But I did pull the dryer out to clean...
I believe the light and the fact that it is not running are unrelated.
The light may simply have come loose and needs refitted or may need to be replaced. I'll need the model number of the dryer to help you further on this.
For the noise, try this (you may need two people):
1. Open the dryer door and locate the door switch. While pushing the door switch in, have someone else push the start button. 2. You'll hear the noise. Keep pushing both buttons and take your other hand, reach in side and grab one of the drum fins and manually push the drum in a clockwise direction. 3. The drum may take off on its own. BE CAREFUL TO REMOVE TO HAND QUICKLY TO NOT GET BUMPED BY THE FINS AS THEY BEGING TO ROTATE.
If it does not start, the motor needs to be replaced.
If this works, turn the dryer off, close the door and try to start it again just by pushing the start button. If it works, it may have been something obstructing the drum from turning. OR, the motor could be going out. It may continue to start on its own for an unkown period of time, a day, a week, and year. But eventually it will go out and will need replaced.
Replacing the motor is a bit involved, but if you want to attempt it I can walk you through it. I'd need the model number to go any further.
Most dryers, however, have a 5 YEARS warranty on the motor, so you might consider a repairman. Make sure they are Amana certified and there will be no cost to you for the motor. The labor, however, may be up to you and could be expensive.
I'm willing to assist you on whatever you decide.
Best, G
Aug 03, 2010 | Amana Dryers
Dryer will not turn on
Get someone to hold in the door switch mechanism while you push the start and turn the drum to get her going. If it runs their may be a chance you can replace and/or oil wheels, slides, and idler. If not then motor replacement is emminent.
Feb 26, 2009 | Dryers
Dryer is making loud thumping noise.
Take off the back panel of the dryer and look at the motor and belt turning the drum. There may be something caught on the drum and is pinned in place causing the noise. The motor could be loose on the platform and needs to be tightened. It is probably something physical and seen causing the noise.
Jan 04, 2009 | Whirlpool LER4634J Electric Dryer
GE DBXR463EDWW Electric Dryer Logo
51 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
