Question about Broan-NuTone 273603 Kitchen Hood
I have a Broan 2736 Eclipse downdraft blower system. When I push the button the downdraft rises but then immediately goes back down
Gail was spot on. That worked for me until the unit would go up and/or down on its own. The problem was traced to the double microswitch called the 'Lower Switch Bracket Assembly' ($24. thru Lowes ). To replace these switches is not for the faint of heart as it is deep within the assembly. A good weekend mechanic can look at the exploded parts diagram and see what / where. Found grease residue on- and slightly within- the microswitchs due to Broan not properly design shielding and protecting these critical switches from grease. Did not find any ghosts, however.
Posted on Sep 12, 2013
5 Suggested Answers
  • 1462 Answers
SOURCE: Blower does not work and the vent does not rise
hum is the motor trying to go. check no packing or other foreign object stuck in the fan
Posted on Mar 28, 2007
shaggyrat
  • 1224 Answers
SOURCE: Downdraft blower quit working
replace whole unit thats roughly what the whole unit costs 157.00 just a little secret there they dont tell you cause they mark up the prices i worked for the company that sold and installed this equipment you also remember tax
Posted on Jun 01, 2008
SOURCE: 30" Viking downdraft
After 11 years of use, the same problem just happen a few days ago - fan keeps running, doesn't respond to the on/off switch. Also cannot reset filter alert. As far as I can tell the entire switch panel isn't working. Or worse, shorted out. Might have to replace the ribbon and some switches.
For example the switches can be found at AllVikingParts.com For example --> http://www.allvikingparts.com/Button_Switch_Assy_p/pv300182.htm
There's a another thread on this forum: http://www.fixya.com/support/t410261-viking_downdraft_ventilator_electrical
I'll post the exact solution as soon as I have it figured out completely.
Posted on Jul 08, 2010
  • 1116 Answers
SOURCE: Broan 273003 30" Downdraft -
When you made the adjustment the adjustment for the switch membrane was adjusted to much and is in constant contact with the switch membrane. Therefore it cannot retract. Remove the switch cover and readjust the position switch bracket so the activating switch just barely makes contact with the underside of the switch membrane. Anything more than this will cause it to stay i the up position.
Posted on Jul 02, 2011
We have a separate Jenn-Air 36" telescoping downdraft vent (#HV363) installed behind a 36" 5-burner Jenn-Air gas cooktop. The problem is with the downdraft. Specifically, after several...
yes you are right..there are switches that should be detected that the unit is in its proper level ans hould stop and turn the fan on.
you may inspect the railing or where the moving part is moving to find limit switches or sliding switches or sensors..it could have been defective with oil or grease and not making contact to transfer the signal to the controller.
tnx 4 using fixya,
drcool
Sep 28, 2008 | Kitchen Ranges
KitchenAid Retractable Exhaust Fan problem when rising. When button is pushed, unit rises up about an inch. Requires 10 or more presses to extend fully. Otherwise fan and retraction is normal.
Kitchen Ventilation ' Kitchen Hoods and Fans ' KitchenAid
www.kitchenaid.com/major-appliances/hoods-and-vents/
KitchenAidShop and find how our hoods and ventilation systems clear the air in your ...Retractable Downdraft Design ... Telescopic Downdraft System in Stainless Steel.
30" Retractable Downdraft System, 600 CFM (KXD4630YSS ...
www.kitchenaid.com/shop/-[KXD4630YSS].../KXD4630YSS...
KitchenAidLearn about features and specifications for the KitchenAid 30" Retractable ... This 30-inch retractable downdraft vent rises 14 inches to help filter steam from ... 14" Rise. Enhances overall capture above the cooktop for more effective ... Makes it easy to select and adjust fan speed depending on your ventilation requirements.
KitchenAid® 36" Retractable Downdraft System, 600-1200 ...
Jan 10, 2016 | KitchenAid Dishwashers
I have a Broan Elite 2736 downdraft range fan that is 3 years old. Upon using it , it started to go up and then down without stopping until I unplugged it. I replugged it in and it continues to go up and...
Broan model 2736A won't stay up
In my case, I pushed the button, the housing goes fully up, then right back down. I removed and disassembled the unit for cleaning. After Assembly I located two microswitches that cause the extension moror to stop at the top and at the bottom of the swing. In my case, the inertia of the motor caused the unit to "Coast" thru the top of the stroke and continue back down. I bent the outer 1/3 of the metal tabs that depress the microswitches so that the unit stopped rising a wisker sooner and no longer goes back down without pushing the button. The same coasting theroy may apply at the bottom of the stroke. The motor that runs the up and down motion is controlled by three switches, the two limit switces plus the momentary push button switch. If you don;t need to completely remove your unit for cleaning, the microswitchs can be located by removing the fan housing and looking up from inside the cabinet (under the stove) on the right side. IN my case, there was 10 years of goop to be removed.
Oct 23, 2010 | Broan-NuTone 273603 Kitchen Hood
CFM's pushed out by blower for jennair S176W range
hi there,
initially downdraft ranges from 6oo CFm to 1600 CFM within the pushbutton control.
CFM means (cubic feet of evacuated air per minute)
Hope this initial info/idea helps.
Let me know for further clarifications,
Jun 04, 2009 | Jenn-Air JES9860 Electric Kitchen Range
Broan kitchen hood - frenetic chimney
It can be 2 things.
1. The motor that elevates the fan is turning a tad to much. Just by stepping on the floor near it could cause it to go up/down constantly.
2.Or what i had seen was the wires that go to the switch dont have enough slack, and are just making contact to the switch causing it to think somone is pushing the button constantly.
There is way too many steps involved to type out.
Dec 01, 2008 | Broan-NuTone Rangemaster RMDD3004...
Jun 01, 2008 | Kenmore 59940 Kitchen Hood
Mar 28, 2007 | Jenn-Air HV363 Kitchen Hood
Broan-NuTone 273603 Kitchen Hood Logo
1,759 people viewed this question
Top Broan-NuTone Kitchen Ranges Experts
Phil Lovisek
Phil Lovisek
Steve
Are you a Broan-NuTone Kitchen Range Expert? Answer questions, earn points and help others
