Question about HP Officejet 6310 All-In-One InkJet Printer
Fax problemcan't receive faxex--device says phone off hook--No phone is connected to my device
  • HP Master
  • 7,733 Answers
I need to connect my fax whit the magicjack
A voice over Internet protocol device, magicJack allows you to make and receive telephone calls from your computer using a USB device. While magicJack does not officially support sending and receiving faxes, you can connect a regular fax machine to the magicJack device to send and receive faxes.
Attach the magicJack device to a USB port on your computer.
Connect the phone wire to the port at the end of the magicJack device.
Connect the other end of the phone wire to the "Input" jack on your fax machine.
Turn off error correction on your fax machine, and set your fax machine to the lowest possible transmission speed. Consult your fax machine's user guide if you do not know how to turn off the error correction or lower the transmission speed on your fax machine.
Send a fax to your magicJack phone number to receive a fax. You can find your magicJack phone number at the top of the magicJack splash screen that will display on your computer after inserting the magicJack device.
Send a fax from your magicJack by loading the fax you want to send into your fax machine and pressing the "Send" button.
Oct 31, 2016 | Computers & Internet
Hp officejet 6500 instructions for receiving a fax? Thanks
You can receive faxes automatically or manually. If you turn off the Auto Answer option, you must receive faxes manually. If you turn on the Auto Answer option (the default setting), the device automatically answers incoming calls and receives faxes after the number of rings that are specified by the Rings to Answer setting. (The default Rings to Answer setting is five rings.)
If you receive a legal-size fax and the device is not currently set to use legal-size paper, the device reduces the fax so that it fits on the paper that is loaded. If you have disabled the Automatic Reduction feature, the device prints the fax on two pages.
NOTE: If you are copying a document when a fax arrives, the fax is stored in the
device memory until the copying finishes. This can reduce the number of fax pages stored in memory.
This section contains the following topics:
• Receive a fax manually
• Set up backup fax reception
• Reprint received faxes from memory
• Poll to receive a fax
• Forward faxes to another number
• Set the paper size for received faxes
• Set automatic reduction for incoming faxes
• Block junk fax numbers
• Receive faxes to your computer (Fax to PC and Fax to Mac)
When you are on the phone, the person you are speaking with can send you a fax while you are still connected. This is referred to as manual faxing. Use the instructions in this section to receive a manual fax.
NOTE: You can pick up the handset to talk or listen for fax tones.
You can receive faxes manually from a phone that is:
• Directly connected to the device (on the 2-EXT port)
• On the same phone line, but not directly connected to the device
NOTE: The automatic document feeder must be empty to receive a fax. If there are documents in the ADF, then the device will not be able to receive incoming faxes.
To receive a fax manually
1. Make sure the device is turned on and you have paper loaded in the input tray.
2. Remove any originals from the document feeder tray.
are documents in the document feeder, then receiving the fax will be
3. Do one of the following to answer a fax manually:
• Set the Rings to Answer setting to a high number to allow you to answer the
incoming call before the device answers.
• Turn off the Auto Answer setting so that the device does not automatically
answer incoming calls.
4. If you are currently on the phone with the sender, instruct the sender to press Start on their fax machine.
5. When you hear fax tones from a sending fax machine, do the following:
a. Press START FAX Black or START FAX Color on the device control panel.
b. When prompted, select Fax Receive.
NOTE: Depending on your country/region, the device might receive the fax
automatically when you hear fax tones from the sending fax machine.
6. After the device begins to receive the fax, you can hang up the phone or remain on the line. The phone line is silent during fax transmission.
Jan 30, 2011 | HP 1250 Plain Paper Thermal Inkjet Fax
Can't receive a fax
Go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set. Make sure the phone wire which you insert in fax machine getting proper dial tone and getting out going calling facility.
Have a nice day and do not forget to rate please...!
Mar 15, 2010 | HP OfficeJet 6210 All-In-One InkJet...
I want to fax over a regular phone line nota dedicated line
Yes you can do that..I have one at home myself on the phone line. As for as setting it up its all in your directions. There is no special equipment, you can call the phone company if you want they can make the ring different if its a fax versus a regular call..but that's the only thing you need to call them for...
Mar 20, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
I cannot re-set my Brother 575 fax machine to send a fax. What are the steps to reset it? I do not have the correct manual to seek out the steps to re-set this machine. It was working a few days ago but I...
No settings you could have changed would keep it from "sending"...."receiving", yes. If you are sure it is plugged into the proper jack on the machine (line), and the phone line has a dial tone, you're problem is more serious
Mar 08, 2009 | Brother Office Equipment & Supplies
How do I get faxes and copies to print from tray 2?
That is an advanced feature, genrally this is known as Automatic drawer eligibility. However, I am not sure this device offers this advanced feature. Look for options to select drawers for your diff functions in your users manual. Sorry best I can say...
Jan 06, 2009 | Office Equipment & Supplies
HP Officejet v40 - Not Faxing or Receiving
I have checked all my connections and my hp office jet v40 is giving the message off the hook though the phone it is connected to is not off the hook.
Aug 14, 2008 | HP OfficeJet V40 All-In-One InkJet Printer
Do you have fax server?There could be problems with it.
Are you directly connected to tel. line with copier?
Try to recive faxex from different numbers and see wats going on
Jul 31, 2008 | Canon PowerShot S2 IS Digital Camera
Problem with fax
You need to set the received fax should be stored in a memory or should be printed.
Feb 15, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Cannot send faxex
Did you try to send a fax to a different number? Also are you sending to a local number? Most send problems are poor phone line conditions. If you have tried to send to several different numbers with no success, then you can assume that the LIU board needs to be replaced. It costs about $40.00 from Brother for the part.
Dec 28, 2007 | Brother IntelliFax-2820 Laser Fax
HP Officejet 6310 All-In-One InkJet Printer Logo
50 people viewed this question
Ben Johnson
