Question about Whirlpool LEQ9858P Electric Dryer
Whirlpool dryer !
My friend an i have a
bet on this ok
will it mess up the timer if you turn it counter clock wise to diff. cycles like tumble press then when it goes off turn it then lets say to heavy counter clock wise to that setting ? who is right either way or it has to be turned clock wise !? rember this is a bet !!!!!!!
  • 66 Answers
Its always recomended that you turn clockwise on a timer that only goes that way but if it moves c/wise or a/clockwise with no effort then it was desighned to do this hope this helps
Posted on Jun 15, 2008
Dryer spins but does not turn off when done
sounds like a bad timer stuck somewhere in the cycle, have u notice the timer knob advancing at all? Also the cycling thermostat or moister sensor, if bad may not detect the dryness properly and therefor not shut unit down.
Mar 01, 2015 | Dryers
Why it doesnt start and make a long noise
Grandson just had this problem with our dryer. he was setting the timer by turning it counter clock wise, all he got was a buzz. When it set it clock wise it worked find.
I know this is a simple fit but worked or him
Randy
Apr 29, 2014 | Siemens WFXD5200UC Front Load Washer
Washer not agitating,spining,motor turns but will not turn belt,the belt gets hot an melts.Replaced belt,lid switch works ok, I can manually turn agitator in clock wise direction but not counter clock...
Need model number! Do a google search for a manual (just search by model number). Repair parts and some troubleshooting help at: http://www.repairclinic.com/
Jan 16, 2014 | Washing Machines
Dryer runs but does not get hot
if timer runs thru cycles then it is the element sounds like timer
Oct 30, 2009 | Whirlpool LER8648P Electric Dryer
Whirlpool dryer LE6810XS110 timer only works on air fluff and tumble press does not work on regular or perm. press
Check to see if the unit will heat up in the time dry. if the heater does not come on in the time dry cycle, then you will need to change the thermol fuse on the back of hte dryer.
Oct 10, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool GEW9200LW1 won't run
Could be that the belt has broken and triped the belt safty switch. If you reach into the dryer and rotate the drum in a clock wise rotation and it moves extreamly freely. It is probably the belt.
Sep 29, 2009 | Whirlpool LAB2700ML Pedestal Drawer for...
Replaced timer, new one stops turning and doesn't turn dryer off.
Some dryers have a "press guard" setting. This willkeep the dryer tumbling with no heat at the end of the cycle. Usually you can select it on or off and in some cases can set the time. see if you have this feature.
Apr 07, 2009 | Dryers
Dryer turns on, but does not run
Try to turn the drum inside with no clothes in it, does it turn freely both ways?
Then as someone is holding the start button, hold the door switch button, then try to turn the drum counter-clock wise, and see if it will start turning on its own.
If it does start turning, then the motor is more than likely the problem.
If it dosen't then the timer is more than likely the problem.
Feb 05, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Dryer drum won;t turn
you have a bad motor / sorry to tell you but thats what your looking at / larryyb
Nov 24, 2008 | Dryers
Whirlpool LEQ9858P Electric Dryer Logo
164 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
