Question about LG RC897T DVD Recorder/VCR Combo
I have a LG DVD/VCR Recorder RC 897T. Some times when I turn the unit on the DVD door will open and not close. I must push the DVD Door closing function button many time before the door stays closed and I can use an of the other functions of the recorder. How can I fix this problem. Thank you. Dan
  • 2 more comments
  • d_engel Nov 08, 2010
    Where can I find the part you mentioned, New Load Belt, and a repair manual with diagrams for my DVD. Thank you. Dan
  • d_engel Nov 11, 2010
    OK, I check both web sites you stated and could not find the Load Belt. Also where can I find a internal diagram of my unit?
  • d_engel Nov 13, 2010
    My E-Mail is D_engel@att.net, Thank you Dan
    Top Expert:
  • LG Master
  • 76,016 Answers
The load belt can be located inside the mechanism of your DVD player, just beneath the slide draw. You have to open it to locate it. In most DVDs this belt can be replaced without dismandling anything. OK
Posted on Nov 11, 2010
  • 2 more comments
  • The Knight
    The Knight Nov 12, 2010
    Hello
    I've the exploded view of your DVD mechanism in which you can see all the parts including the loading belt I mentioned. But I can't send it to you without the permission of Fixya. You just ask them about i. Ok
  • The Knight
    Hello
    I've the exploded view of your DVD mechanism as PNG mage. But there is no facility to send it to you through this reply. You just ask Fixya to make an arrangement to send this to you. I've requested them a while ago about this situation. No reply has been got to me till yet. OK
  • The Knight
    The Knight Nov 13, 2010
    Hello
    Ify you give me your email address, I'll send it you as an attachment.
  • The Knight
    Hello
    I've forgotten to give you my mail address
    gopakumarg43@ymail.com
    gopakumar1@hotmail.com
  • 1,476 Answers
D_engel,
It sounds like you need a new load belt. Installing the belt is a complicated process, not impossible, but if you have not done it before it could be daunting.
If you want to try it you will need to remove the cover. Take out the screws on the rear and any located on the sides. Remove the cover. Now you need to disconnect any wires attached to the DVD. Mark them first for easy assembly. Remove the screws holding the unit to the base and any other mounting screws. Remove the DVD and take the screws out of the sides to remove the cover.
From here it will be something which you will have to determine as every unit is different. You will probably have to remove the load assembly. This is the tricky part. Reassembly will require making sure the timing is correct.
If this seems like more than you need to deal with you may want to buy a new unit as they are not that expensive today. Another solution would be to push the door shut manually until the belt finally gives out completely.
Thanks for using FixYa and for the great rating. Great ratings will keep the experts helping to solve everyone's problems. Thank you.
hardrocko
Posted on Nov 08, 2010
  • Kim Yearick
    Kim Yearick Nov 10, 2010
    Sorry, I guess I forgot to mention that.http://www.encompass.com orhttp://www.mcminc.com should be able to supply the belt.
    Thanks for using FixYa.
    hardrocko
  • Kim Yearick
    d-engel,
    The one site I mentioned should behttp://www.encompassparts.com . Thanks for using FixYa.
    hardrocko
DVD disk tray will not open at all
had the same problem the mechanism for the door opener is faulty.........waited for 2 months to be finally told by samsung part is no longer available......wonderful back up service isnt it. Luck have it I had an extended warranty and getting it replaced with a LG combo
Jun 03, 2009 | Samsung DVD-VR320 DVD Recorder/VCR
How to fransfer video from vcr tapes to dvd
you done that the problem so. press power on bottom & press dvd section mark"open/ close" bottom & hold it untill show in dvd from vcr by lcd screen. if want dvd to vcr. you just playing vcr the system going to vcr section direct. good luck!
Mar 23, 2009 | LG RC-197 DVD Recorder/VCR
Unable to close the door
the player section is out of timming.if you push it in hard you are going to damage it bring it by a tech.
Mar 02, 2009 | LG RH299 DVD Recorder/VCR
Dvd drawer opens and closes continually
the inter relay swich on the door is molfushing,or the open and close butten is bad'', try closeing the door and at the same time that the door close's unplug the power and then plug it back in after a few seconds and see what happens it my stay closed and then you can play it,, and it my stop doing that ''if not you will have to take it in to a repare shop'''' my names is ''james ''' let me know if this works for you''' you can e-mail ' me back at '' jay_win2002@yahoo.com .
Jan 30, 2009 | GoVideo VR3845 DVD Recorder/VCR
I need to change my DVD players Region code to play all regions.
1.Switch on unit 2.Press- Setup on the remote
3.Select the Lock option from the on screen setup menu
4.Press Lock on the remote unit ( under slide cover)
5.Press 0 7 times on the remote keypad
6.A message appears stating the unit is now Code free on the screen
7.Press Enter on the remote.
8.Close Setup menu and switch unit off.
9.Switch on and enjoy Multi-region DVD playing
please donot forget to rate this solution.
Jan 28, 2009 | LG RC199H DVD Recorder/VCR
Tne dvd door will not open
These are instructions to open door if DVD is jammed or the DVD recorder wont open.
Unscrew the 7 cover screws and the 2 foot screws. Remover player cover.
Pry the front control cover off from the top of the player and not the bottom with a thin screw driver paying attention not to crack or break the tabs. Just lift them enough to clear the hooks.Then lower the cover withut removing it so you can gain access to the DVD front internal bezel.
On the left side of the DVD recorder there is a notch with a lever in it. gently push on it as this is the release for the DVD door. Remove DVD from tray and close.
Re-install all covers and screws. Machine should work after this.
Jan 17, 2009 | GoVideo VR2940 DVD Recorder/VCR
LG COMBO RC797T RECORDER
DVD door switch is bad. If you are willing to open it up and sodering a new one, here is a link to a replacement switch.
Oct 26, 2008 | LG XBR446 DVD Recorder/VCR
LG DVD recorder/VCR Combo problems
you need to replace the dvd loader(the whole setup, the draw/tray,laser sled assy ,etc) statewide sell
parts for lg.unless you know an authorised lg repair agent.too bad you dont know me, lol.
(ps,its not in the manual,cuz there is nothing you can really do about it without serviceing the unit)
Feb 18, 2008 | LG RC199H DVD Recorder/VCR
Door opens and closes 3 times
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} t needs to be realigned
unplug power
open unit
clip_image001.jpgremove dvd drive (4 screws)
remove power cable to dvd right rear of unit on circuit board
(squeeze plastic connector and pull up)
remove ribbon cable CAREFULLY wiggle it from side to side and it will come up clip_image002.jpg
Then with drive removed, open up drive to access the bottom near front door
Once open you will see a smalll motor and a white pice of plastic that slides. with tray closed slide that piece of plastic as far towards the middle as it will go clip_image003.jpg
with that slid all the way over you should be done.
close it up and be carefull sliding the ribbon cable back into place
Worked for me!
Good luck
Dec 22, 2007 | JVC DR-MV7 DVD Recorder/VCR
Keeps opening
may have a microswitch that signals that the door is closed that may be faulty. look for a switch that is actuated when the door closes.
Nov 06, 2007 | Emerson EWR20V4 DVD Recorder/VCR
LG RC897T DVD Recorder/VCR Combo Logo
183 people viewed this question
Steve Allison
Steve Allison
