Question about HP Compaq Presario SR1950NX PC Desktop
I tried to turn on my pc but what appeared on the monitor is this: BOOTMGR image is corrupt. The system cannot boot. Please help. Thanks.
  • 2,229 Answers
Do you have a system disk? If so, try the tip listed below--even though it doesn't say it is for your specific problem, it should work.
http://www.fixya.com/support/r4501608-when_windows_xp_start_primary_fix
Posted on Nov 08, 2010
'Bootmgr image is corrupt.The system cannot
if you can get hold of a windows installation disk you can boot from it and choose the repair option.
Nov 06, 2012 | Computers & Internet
Bootmgr image is corrupt. The system cannot boot
There are a number of possible causes for BOOTMGR errors, including the most common "BOOTMGR is missing" error message.
The most common reasons for BOOTMGR errors include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors an outdated BIOS and damaged or loose IDE cables
Anothe reason you might see BOOTMGR errors is if your PC is trying to boott from a hard drive or flash drive that is not properly configured to be booted from. In other words, it's trying to boot
from a non-bootable source. This also would apply to media on an optical drive or floppy drive that you're trying to boot from.
make sure there are no disks in cd floppy usb drives
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your ((MOTHERBOARD TO YOUR HARD DRIVE)) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
if its a flat ribbon 40 pin IDE it will be the fist to fail
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs
data and power to travel through every working device and to continue its cycle and to have an end so any faulty leads will end up with a computer error
also make sure you have set it boot from you hard drive in BIOS
hope this helps
Jul 30, 2012 | Computers & Internet
BOOTMGR IS MISSING
Visit this site for complete solution of BootMgr is missing:
http://answers.microsoft.com/en-us/windows/forum/windows_vista-hardware/bootmgr-image-is-corrupt-the-system-cannot-boot/2042e9e7-4820-49fa-9a9a-922f216384c0
Use a system utility sfotware like RegInOut to repair registry and windows files.
Jan 04, 2012 | Acer Aspire One AOA150-1784 Netbook
How can i boot my Windows Seven OS if the "bootmgr is missing"? I'm installing windows seven but when windows start copying files but error message appears that required files for the...
What you need is bootable DVD/CD for installing or repairing Windows 7 to get missing 'bootmgr' or repair corrupted bootmgr...If there are files corrupt on your CD, you can get new one from shop you have purchased..Maybe just need to clean up your DVD/CD, so your DVD drives can read properly the files installation..
Aug 07, 2011 | Computers & Internet
Bootmgr missing
Causes of BOOTMGR ErrorsThere are a number of possible causes for BOOTMGR errors, including the most common "BOOTMGR is missing" error message.
The most common reasons for BOOTMGR errors include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors, an outdated BIOS, and damaged or loose IDE cables.
Another reason you might see BOOTMGR errors is if your PC is trying to boot from a hard drive or flash drive that is not properly configured to be booted from. In other words, it's trying to boot from a non-bootable source. This also would apply to media on an optical drive or floppy drive that you're trying to boot from. Fixes for BOOTMGR Errors
  1. Restart the PC. The BOOTMGR error could be a fluke.
  2. Perform a startup repair of Windows. This type of installation should replace any missing or corrupt files, including BOOTMGR. Continue troubleshooting if this does not resolve the issue.
  3. Check your floppy and optical drives for media. Often times, the "BOOTMGR is Missing" error will appear if your PC is trying to boot to a non-bootable floppy disk or CD/DVD.
    Note: If you find that this is the cause of your issue and it's happening regularly, you might want to consider changing the boot order in BIOS so the hard drive is listed as the first boot device.
  4. Check the hard drive and other drive settings in BIOS and ensure they are correct. The BIOS configuration tells the computer how to use a drive so incorrect settings can cause problems, including BOOTMGR errors.
    Note: There's usually an Auto setting in BIOS for hard disk and optical drive configurations which is usually a safe bet if you're not sure what to do.
  5. Reseat all internal data and power cables. BOOTMGR error messages could be caused by loose or malfunctioning power or controller cables.
    Try replacing the PATA or SATA cable if you suspect it might be faulty.
  6. Update your motherboard's BIOS. An outdated BIOS version can sometimes cause the "BOOTMGR is Missing" error.
  7. Perform a clean installation of Windows. This type of installation will completely remove Windows from your PC and install it again from scratch. While this will almost certainly resolve any BOOTMGR errors, it's a time consuming process due to the fact that all of your data must be backed up and then later restored.
    If you can't gain access to your files to back them up, understand that you will lose them all if you continue with a clean installation of Windows.
  8. Replace the hard drive and then perform a new installation of Windows. If all else has failed, including the clean installation from the last step, you're most likely facing a hardware issue with your hard drive.
BOOTMGR Errors Apply To BOOTMGR issues apply to Windows 7 and Windows Vista operating systems only. Windows XP does not utilize BOOTMGR. The equivalent function in Windows XP is NTLDR
Whish you the best luck.
Mar 06, 2011 | HP Computers & Internet
Got everything installed with a new biostar mcp6pb m22B but can't boot from the dvd to install windows 7. Keep getting bootmgr image is corrupt message. Help!
The dvd which you placed int he drive to be booted from is corrupted so the bootmanager is not accepting the disk so try to boot your system with another dvd
thanks
May 15, 2010 | Computers & Internet
Bootmgr image is corrupt error message at startup
1) start up on safe mode ... try to do a restore ... all programs - accessories - system tools - system restore
2) reload windows
Oct 05, 2009 | Compaq CQ60-215DX Notebook
BOOtMGR image corrupt. system cannot boot
HI Stephen
You can defenitely try these steps but if these does not resolve your issue you might have to reinstall the windows. Please make sure you have all the cds for your laptop and also make sure the data has been backed up.
here are the links on how to fix the bootMGR message
http://support.microsoft.com/kb/314503
try to repair your system with these steps.
post if still the issue is not resolved.
thank you
Rakesh
Dell Laptop Expert
Jan 09, 2009 | IBM ThinkPad T43 Notebook
HP Compaq Presario SR1950NX  PC Desktop Logo
94 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
