Question about Magic Chef 31000 Gas Kitchen Range
Constant beepoping andF1 is displayed
How can I stop the beeping andF1 display?
  • pj20407 Sep 25, 2008
    Yes, same here!
I found the sad solution. The part must be replaced and is likely to fail again at some point. The only other options are to not fix it and use a switched power bar or alike to turn off the power when not required for use, or replace the range with something without the Magic Chef defect.
There was a class action suit about this problem which was long since settled. The manufacturer had to pay. They have never acknowledged the defect in the part or upgraded the part in any way to alleviate the problem.
"Be Good All Day"
Paul
Posted on Dec 07, 2008
How can i stop beeping and f1 display?
Constant beep no display
Try drying the board with a hair dryer but not so hot to destroy the electronics. Place an ample amount of distance between the board and the electronics. Set aside for an hour, then try the machine.
Jan 14, 2014 | Kenmore HE4t 3.8 Cu. Ft. King Size...
Non-stop beep sound and won't display
A constant beep, usually indicates the post is detecting no memory installed. This is usually caused by the memory not being installed correctly or incompatible memory. double check you have the correct memory for this mother board. If you have 2 chips, install one and test. If this does not work swap the memory and try again. If both chips fail, you might try a different brand of memory.
Jan 27, 2012 | ASUS A8N-SLI Premium Socket 939 NVIDIA...
Fridgidaire Error 68 (model No. LE02152EEO) and constant beeping!
this fault code means there is a stuck key on the control board.you need to disassemble the display panel and free up the stuck key if this does not work then the display panel and or control board need to be replaced
Sep 02, 2009 | Frigidaire AEQ6000ES Electric Dryer
Constant beeping when powered up, no display
If the beeping is constant, check your keyboard for any keys that are stuck in the depressed position.
Jul 07, 2009 | Computers & Internet
"F1" DISPLAYED AND BEEPING
F1-->Failed Thermistor Control Replace ERC
you will have to replace the ERC or Electronic Range Control or the touch pad.
Dec 18, 2008 | Ovens
Our bosch diswasher on auto wash will stop functioning in middle of the cycle start beeping and there is an icon of a faucet on the display. What does this mean?
Hello zeviemail
Welcome
You said, your Bosch dishwasher on auto wash will stop functioning in middle of the cycle start beeping and there is an icon of a faucet on the display.
What is your model number and the year of the dishwasher?
Oct 04, 2008 | Bosch Dishwashers
2 questions
Hold down the Display/Menu function button (one of those three buttons on the left of the unit) for about 3-4 seconds until the display reads "t set". When this appears, push the track forward button once (>>|) so the display reads "beep"; now press the play pause button (>||) once. The display will now say "on", push the track forward button (>>|) once to make it read "off"; now push the stop play button. You're done. Enjoy the silence.
Mar 14, 2008 | Sony Walkman D-EJ100 Personal CD Player
F1 and constant beeping
Tul2pi, there are several things that could cause this. 1. shorted keypad. If you unplug the keypad ribbon from the board and the beeping stops it's more than likley your problem. 2. Temperature probe in the oven may have gone bad. You would have to ohm this out. At 75 degrees it should read approx. 1091 ohms. 3. Worst of all it would be a control problem itself where as you would have to replace the control board. Since you are so close to the warranty period, I would call Frigidaire at 1800-944-9044 and see if they would cover it...Catriver..post back.
Aug 29, 2006 | Frigidaire PLES389D Electric Kitchen Range
Magic Chef 31000 Gas Kitchen Range Logo
115 people viewed this question
Top Magic Chef Kitchen Ranges Experts
Paul Carew
Dan Webster
Dan Webster
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
