Question about Vizio VO47L 47 in. LCD TV
Vizio 47 inch java tv image gets stuck on the left side of the screen if i remove a wire component cable or the audio out the problem goes away . what is causing this and will the 1 year vizio warranty cover it
  • 320 Answers
The problem is caused by a low voltage output. If its still under warranty have it fixed by a representative from VIZIO.
Posted on Nov 08, 2010
VIZIO M3D470KD TV TURNS ON, HAVE BACK LIGHT, V LOGO APPEARS ON SCREEN THE FADES AWAY.
Corrupted firmware. An update is necessary. If you wish to get some details; check the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Firmware (Software) update procedure of many popular brand TVs and other devices are given in detail.
Sep 30, 2016 | Vizio M3D470KD 47 inch Class Theater 3D...
How to fix Multi color Vertical Lines on a Vizio E470i-AO TV
Does the menu function display the same lines? What kind of cables are using ? (HDMI, Component vid, S-video, co-ax)
Were you as tenacious checking all cables/connections as you were the electronics? Lets rule out this all too often over-looked possibility.
Do you still get the lines with nothing connected to the TV? (no source connected)
Feb 28, 2016 | Vizio E-Series E470I-A0 47" LED TV...
What I am trying to hook up is a Wii console using component cable but get black and white image on a Mitsubishi WS-65313 65 inch Television?
Follow the color code green for green, red for red, blue for blue, ignore the yellow wire, also be aware that there is an audio cable that is red also that wire goes into the Right channel audio and the white wire goes to the Left channel audio
May 26, 2014 | Mitsubishi WS-65313 65" Rear Projection...
Vizio 46 inch black screen on left side
Sounds like you either have a faulty LCD panel tab, failed LCD driver board, LCD/t-con panel bad connection, or a bad t-con. You will need to get a diagnoses to be sure.
Dec 15, 2012 | Vizio VW46LFHDTV10A 46 in. LCD TV
Today my 55" vizio screen popped and then turned red. I unpluged and restarted everything and now the audio is on, the chanels change, but the screen is completely read. some images are readable.
If this is a VO47LFHDTV20A TV set, the problem is most likely your LVDS(cable from the main board to the t-con)cable is faulty. When you turn the set on, do you have a red screen instead of the standard blue screen? Do you also have red tints on all images on all inputs? If this is the case, your LVDS cable is bad. If you are comfortable opening up your set, track down where the LVDS cable goes into the t-con board. Turn on the set, and wiggle the cable, if the red tinting goes away, you will need a LVDS cable, about $24 part.
Dec 09, 2012 | Vizio VO47L 47 in. LCD TV
I have a vizio 47" lcd tv that was affected by a
I believe the main baord is bad (main board contains the inputs circuits, tuner, sound and video processor).
http://www.shopjimmy.com/vizio-3642-0722-0150-main-unit.htm
http://www.shopjimmy.com/vizio-3647-0102-0150-main-unit.htm
You may want to look inside to see if you can see any burnt components.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: http://interliquidparts.com/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Jun 23, 2011 | Vizio SV471XVT 47 in. LCD TV
Our Vizio VX42L has an audio problem. The sound is "scratchy." When I change the audio setting completely to the left side speaker, the noise goes away and the sound is fine out of that single...
Small component board that controls sound could be faulty. It is near the bottom of the tv and the size of about a quarter. Another possible cause is "shorting" due to assembly ...If the speaker wire comes in contact with the metal at any point you will get this type of noise. Either way, you will need to take your tv apart to truely tell if the board is bad, or the wire has been cut slightly.
Thank you and best of luck!~
Jun 16, 2011 | Vizio 42 in. LCD TV
I have a 2008, Vizio VO47L 47 in. LCD TV. When I first turn it on, the left side(facing) of the screen is dark. Not completely black just shadowy dark for over an hour. Then it goes away, It used to last...
Faulty T-con board or mainboard (AKA tuner board)...the tapping would make me believe it to be the connection of the LCD panel to the T-con board that is causing the issue! This board is located on the top of the tv while looking down from the back. Replace it and you will be good to go!
Please rate if this helped :)
Mar 08, 2011 | Vizio VO47L 47 in. LCD TV
I have a Vizio 47 inch LCD HDTV hooked to a Dish system. The volume fluctuates from very loud to very soft between ads and programs. It also goes from moderate volume to very soft within a program. Help!
Either unplug dish from tv or use the antenna side which is HD and program channels and see if volume the same, if not and is OK then it's your Dish bring your sound down or audio cables bad.
Feb 18, 2011 | Vizio E470VA 47 in. HD-Ready LCD TV
Vizio VO47L 47 in. LCD TV Logo
114 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
