Question about GPX D1816 DVD Player
I need the code for my gpx dvd player, i have a phillips universal remote control CL034
cptnkirk4604
  • 39 Answers
SOURCE: code for apex tv through philips universal remote
1. Manually turn on device to be controlled.
2. Press and hold the "Code Search" button until the red indicator light stays on, then release it.
3. Press and quickly release the desired ode button (TV, VCR, etc.). The red indicator light should blink once.
4. Press the "Channel Up" button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator light should blink off with each button press. If you accidentally overshoot the required code, press the "Channel Down" button to backtrack through the library until the device changes channel. Pressing "Channel Up" changes direction again.
5. Press and release "Mute" button to install the code.
If you wish to actually identify the code once this has been done, this is the procedure:
1. Press and hold the "Code Search" button until the red indicator stays on. Release the "Code Search" button.
2. Press and release the desired mode button (TV, VCR, etc.). The red indicator light blinks and then stays on.
3. Press and release the "Code Search" button. The red indicator light goes off.
4. To find the first digit for the code stored under the mode key pressed in "Step 2" press each numeric key from 1-9 in turn. When the red indicator light blinks off, the number you pressed is the first digit for the code you are searching for.
5. To find the second digit, repeat "Step 4," this time when the red indicator light blinks off, this is the second digit in your number.
6. Repeat again for the third digit in your code number.
Posted on Aug 30, 2008
SOURCE: dvd GPX cannot find the remote code for it
I need to program a universal remote with my GPX DVD player
does anyone know the 3 digit code?
Posted on Feb 25, 2008
  • 52 Answers
SOURCE: universal remote
i would go to the rca website and check with them there is a way to do it with out a code from the book i just cant remember the exact sequence,i think you turn on the device then press the devise button and hold power till the power button starts blinking then keep pushing the power button till the devise goes off then you must hit the stop button on the remote right after the devise goes off then you should beable to turn the devise on using the remote
Posted on Aug 20, 2008
SOURCE: remote codes
Radio Shack has a website for all of it's universal remote codes for the remotes it sells at www.rcinfo.com. There you'll find what you're looking for.
Posted on Sep 11, 2008
BElectric
  • 1140 Answers
SOURCE: I need RCR3273R remote codes
I'm not sure you're going to be able to use that remote for that DVD. Philips / Magnavox remotes don't list codes for GPX equipment. I've managed to find a couple of codes that might work but no guarantees here:
0699 or 0769
Your best hope is to use the auto search function on the remote control. If that doesn't work, then it's unlikely the remote will work for you. Do you still have the instructions for programming the remote?
Please don't give me a low rating if these codes don't work. This is a difficult request and I've searched as many sources as I can find. Thanks.
Posted on Oct 16, 2010
Gpx dvd player remote control code
Get the manual for the info or contact the manufacturer for manual download on their website.
Jul 04, 2015 | GPX D200B Player
I have a phillips CL034 universal remote need code for sharp tv
this should work:
SETTING CODES
HOLD THE CODE SEARCH BUTTON DOWN UNTIL THE RED LIGHT STAYS LIT.
PRESS THE DEVICE BUTTON (ie TV)
CHANNEL UP BUTTON UNTIL THE CHANNEL CHANGES. (300 SHOULD BE MAXIMUM)
PRESS THE MUTE BUTTON TO SET THE CODE
Oct 19, 2009 | Philips Magnavox Learning Universal Remote
I have a philips universal remote control and i
I have a Philips Universal Remote CL034 remote and a Memorex MVD2040 also.
Hold [Code Search] until it the LED stays lit
Press [DVD]
0246 or 1606
0246 is the best code to use. For 0246, note that pressing
[Input / TV/VCR] = The all important DVD setup menu
Sep 21, 2009 | Philips Televison & Video
I need a philips cl034 universal remote code for memorex dvd play
I have similar problem with a Philips CL034 Universal Remote and a Memorex MVD2047. The Philips/Magnavox codes listed at this link did NOT resolve the problem. I tried all Memorex codes and tried the "all coded step-through" method. http://www.universal-remote.net/philipsmagnavox.html The above is NOT a solution, rather a note on a time consuming attempt to a solution.
Nov 12, 2008 | Audiovox 150W DVD Home Theater System -...
Dvd GPX cannot find the remote code for it
Jan 03, 2008 | GPX D1816 DVD Player
Code for sanyo tv phillips universal remote cl034
the code is 0506 Ihave the same remote and tv
Dec 15, 2007 | Televison & Video
GPX D1816 DVD Player Logo
255 people viewed this question
Top GPX Televison & Video Experts
Jaime Hernandez
Are you a GPX Televison and Video Expert? Answer questions, earn points and help others
