Question about Maytag Dryers
My neptune dryer is gas,and it all of a sudden stopped producing heat. it stills runs just does not get hot
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 154 Answers
HAS BAD IGNITOR OR THERMAL FUSE
Posted on Nov 08, 2010
I have a Maytag Neptune model number MDG9700A gas dryer...When I first turn the dryer on the dryer will get hot for about minute then the gas turns off and will not heat up again...It glows fine after...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 01, 2011 | Maytag Neptune MDG9700A Gas Dryer
Dryer is running but doesnt seem to be heating it takes a long time to dry and the clothes are not warm when pulled out
Your ignition unit may be worn out and will need to be replaced. Generally, a heating element comes on and once it reaches a certain temperature, it ignites the gas pilot. Then the heating element cools off because the gas is now burning and producing heat. When this heating element stops working correctly, it will not reach the right temperature to ignite the gas. You'll need to have a professional perform the repair. If the dryer is still under warranty, this might be covered.
Check your owner's manual.
I really hope this solves your problem. If it does, please come back to Fixya and rate my advice
Jul 16, 2011 | Maytag Neptune MDG5500AW Gas Dryer
My neptune mdg 5500 dryer starts and runs but will not get hot
heatman101
Jul 10, 2011 | Maytag Neptune MDG5500AW Gas Dryer
Why my maytag Neptune gas dryer stopped heating up?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 10, 2010 | Maytag Neptune MDG5500AW Gas Dryer
No hot air when the dryer is running
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
heatman101
Oct 08, 2010 | Maytag Neptune MDE5500AY Electric Dryer
My Neptune all of a sudden has stopped blowing hot air , I have had all the setting correct.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 10, 2010 | Maytag Neptune MDE5500AY Electric Dryer
My gas dryer all of a sudden just stopped getting hot. it runs but just does not get hot.
heatman101
Sep 02, 2010 | Whirlpool WGD5600S Dryer
Maytag gas dryer will not heat
heatman101
Jul 06, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Our Neptune gas dryer seems to work fine but suddenly produces no heat. The vent is clear and the gas line attached and open.
Look at the glow ignitor. If it is broken then it needs to be replaced. About 20 dollars, and a 5/16 wrench will fix this issue, just make sure that you unplug the dryer before you start touching the electrical. This piece is located in the bottom of the dryer behind the back panel.
May 08, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Dryers Logo
Top Maytag Dryers Experts
Marvin
Marvin
Sal De
Archie Ferrarini
Archie Ferrarini
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
