Question about Rival MT660 Microwave Oven
I need a sf15ah250v fuse for my microwave. - Rival MT660 Microwave Oven
GE microwave oven fuse? no sign of power
PokMan, Check the attached links,instruction and guides on fuses and thermal fuse breaker. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Where is the fuse located and how do you replace it GE Microwave Oven
GE Microwave Fuse Thermal Fuse Breaker Parts
GE Microwave Oven internal fuse Google Search
Microwave Not Working
Microwave Oven Troubleshooting in MINUTES STEP BY STEP
Jun 11, 2016 | GE Microwave Ovens
Does this unit itself have fuses inside it? If so, how do I access them.
Shelia, A lot of microwaves do have internal fuses, Links below will show how to change them.
How to Fix Microwave Oven Simple Fuse Replacement
Microwave Won Work GE Microwave Thermal Fuse Replacement part WB27X1127
Microwave Line Fuse Replacement Whirlpool Microwave Repair Part W10422951
Mar 21, 2016 | Microwave Ovens
How do I find the fuses in Microwave
Mainly there are three/four fuses in Microwaves depend to maker.
First one to be checked it is on plug about 13A in cable out side microwave
Second one for power supply usually comes 10A located in terminal board of cable supply in side microwave if you follow the cable.
Third fuse i think about 5A for high voltage it located usually on wire connected between transformer and capacitor.
Fourth some Microwave have third one on the control board located behind switch panel.
now.
if the second fuse is blowing immediately after starting microwave that usually mean one or more of the following need to be replaced
1- diode
2- HV. capacitor
3- magnatiron
Which only can replaced by skill technicians
THANK YOU.
Oct 31, 2014 | Emerson MW8998B 0.9 Cu. Ft. Counter-Top...
Is there a fuse in a frigadaire microwave
Good Afternoon Friend,
I understand that you want to know if there is a fuse in your Frigidaire microwave, model# FGMV174K. Looks like there are 2 different fuses inside your microwave. Neither are fuses like in your home's circuit breaker. There is the magnetron fuse, which controls the heating, and the monitor switch with ceramic fuse. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your microwave status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 10, 2014 | Frigidaire FGMV174K Microwave Oven
My spacemaker stopped working and no panel lights. It's not the circuit breaker. Any ideas? model JVM140001
Could be the fuse inside the microwave is blown. You will need to unplug the microwave and remove the front control panel. Inisde the microwave housing you will need to trace the electrical wire coming into the unit. Usually you will find the in-line fuse located on the black power wire. You can pull the connectors off the fuse and test it with a continuity tester. If the fuse is blown replace it but make sure you use the same amp rated fuse as you removed. If the fuse blows again then there is an electrical short somewhere in the microwave.
Dec 24, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave blown fuse 5kv 0.75A needs replacing !!!SAFELY!!!
yes you can but it will eventually burn again and this time causing bigger damage
Oct 25, 2009 | Maytag MMC5000 Microwave Oven
I have a GE Profile spacemaker 2.0 microwave and it just quit working on me. Sounded like a fuse popped?? I verified that the electrical outlet was working. Is there a fuse to replace inside the microwave?
Hello. You have isolated the problem.
Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it.
Jun 23, 2009 | GE Profile Spacemaker Over-the-Range...
Microwave has stopped working after being run empty for a short time. Is there a fuse that needs to be replaced or is the microwave dead?
There is a fuse inside the oven. The rating of the fuse may be 8amps. It is not suggested to run the oven without load inside.
May 04, 2009 | Kenmore 63252 Microwave Oven
GE MICROWAVE FUSE REPLACEMENT
i have a galanz microwave i need to replace the fuse and i dont know wht to buy
Dec 21, 2007 | Microwave Ovens
Rival MT660 Microwave Oven Logo
274 people viewed this question
Top Rival Microwave Ovens Experts
William Miller
William Miller
Jaime Hernandez
Are you a Rival Microwave Oven Expert? Answer questions, earn points and help others
