6A00 errow code on screen how do ifix it - Office Equipment & Supplies
  • 8,197 Answers
I got this error once, it appeared that the print head carriage was stuck and after manually moving the carriage a few times the problem was resolved. I also blew some compressed air around hoping to clear any foriegn objects.
If this did not fix then Follow Canon's suggestion, take it or send the unit UPS to the Authorized Repair Facility.
You will NOT be able to resolve the problem yourself.
Good Luck
Posted on Nov 08, 2010
HD errow code 2101 bike won't start
Hi Walter, for more information about your question please visit the websites below. Good luck and have nice day.
Harley Diagnostic Codes 04 to Present
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jan 22, 2012 | 2009 Harley Davidson FLHTCU Ultra Classic...
6A00 error code?
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Apr 16, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Errow message 6A00 the ink jets will not move manually to the left. I can not see the sponges that I have read about. Thanks! Debra
Hi there
This could clean it up for you.
Error A600
Your A600 is a paper path error, usually related to the purge unit. Try checking the purge unit for paper stuck in it.
Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code.
Almost 90% of the time is related to the purge unit being jammed with something and not being able to move.
Look for paper, paper clips, push pins, screws flower bud pods or the like.
The offending item needs to be removed or the purge unit needs replacement.
The purge unit, called a spittoon assembly in an HP, Lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing. That is why you'll find the print head assembly parked on top of it. It also has an electrical pump to milk the print heads and test for ink flow.
The purge unit is a white plastic assembly (on the right side of the printer where the print head homes) that is spring loaded on rides on a rail.
You can try moving it back and forth about 5 times or so and clean the rail with a cleanex and putting a little bit of some light oil on it and then close everything up and try it.
If you found this useful all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
Feb 14, 2010 | Canon PIXMA MP830 All-In-One InkJet...
I get an errow message 6a00 and the printer pulled the paper in crooked. no paper is jammed.
Hi there
Ok you can try this.
Error A600
Feb 04, 2010 | Canon Pixma MP500 All-In-One InkJet...
Canon Mp780 error code 6A00
6A00 is not a jam error, it is an error of the purge assembly not cycling properly. Many times a paper scrap jammed in the capping assembly or the squeegee assembly caught on the filter assembly. Usually worn out gears and dried ink so that replacement of the purge assembly is the best fix.
Jan 19, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Re my security code
the default security code is 12345.
Aug 03, 2009 | Nokia 6080 Cellular Phone
Error Code 6A00 on screen , not printing, also on computer screen Error Code 5C10?
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
Jun 06, 2009 | Canon PIXMA MP830 All-In-One InkJet...
6A00 error
The error seems to indicate a failed sheet feed, check the paper path to see for any stuck bits of paper, however I have heard that this can also be caused by a flaky sensor in the paper path.....
apparently the best way to deal with this is to turn it upside down and give it a shake.
hope this helps
Sep 23, 2008 | Canon PIXMA MP830 All-In-One InkJet...
15 people viewed this question
k24674
jasbo
jasbo
