Question about Refrigerators
My Maytag fridge is set at 46 degrees but it is still 28 degrees inside. What could be my problem. thanks jon
The thermostat is malfunctioning
Posted on Nov 08, 2010
My Viking professional refrigerator is stuck on 46 degrees refrigerator/ 6 degrees freezer. None of the buttons work. Is there a reset button?
press display on or (activate control) button first you should then be able to choose fridge or freezer and change set temp
after set will read actual temp 46 is a little high sounds like you have service issue
Jun 27, 2017 | Viking Refrigerators
Model mf12568aes. Why is freezer temp 28 degrees and fridge is 54?
the control damper might need turned t a colder setting , or it has too much in the top shelf and it's blocking the cold air
Nov 26, 2015 | Maytag Refrigerators
Why won't my refrigerator and freezer stay below 50 degrees?
Barbara, does it stay at 50 degrees even if you set it lower? I have a similar problem but temps. look ok.
Jul 30, 2014 | Maytag Refrigerators
Whirlpool french door refrigerator
What is your model number? With the model number I can look up the components that may be causing this problem. Example would be a defective thermister or thermostat control. Thanks Sea Breeze
Apr 24, 2013 | Refrigerators
Freezing problem in maytag frig
the probe from the temp panel is not sensing correct temp or the panel itself is bad...call a tech to check it out
Feb 04, 2010 | Refrigerators
Bottom freezer model, fridge temp is @ 24 degrees, but it is set to 46 degrees.
some times the flap that controles the temp inside the fridge gets stuck or sometimes (hate to say this) parts and not installed properly or not at all I have found this to be true from alot of hhgregg stores they seem to buy defects and then replace the missing part
Dec 09, 2009 | Kenmore Refrigerators
Maytag MSD2456GEB fridge section warm
Please remember I am attempting to diagnose your appliance without being there and with very little information.
Sorry but if your freezer is 10 degrees, it is running warm. Freezer is designed to run between -10 and 0 degrees. Reset controls, place them in the middle of the scales. The controls can be confusing. The control that turns the unit on and off is your freezer thermostat and the other is the damper that controls the air flow from the freezer into the fresh food section. What I would think is wrong with your unit is one of two things.
  1. You have a defrost problem.
  2. Your inside fan is not running.
1. Look at the inside back panel of your freezer. If you have ice or frost built up on the panel, you most likely have a bad defrost heater.
2. Check to be sure you have air flow inside your fresh food section coming from your freezer. If not and your control is setting around mid-ways, you have a bad fan or your defrost heater is bad and ice is blocking the air flow.
Please rate solution
Sep 14, 2009 | Maytag MSD2456G Side by Side Refrigerator
9000 btu maytag portable AIR CONDITIONNER Model M6PO9D2B-B
Reasonalbe rule of thumb is a difference of 10 degrees Centigrade.
Charlie
Aug 18, 2009 | Maytag Electronic Portable Air Conditioner...
Fridge and freezer not working on new Maytag, Help!!
at 5 months old don't try to fix it yourself CALL the store where it was purchased or maytag
you may mess up the warranty if you try to fix it yourself
document all of the calls you make to where and who you spoke with at what time
ask for promises in writing have them fax it to you so you have the promise in hand
Dec 14, 2008 | Maytag MFD2560HES Bottom Freezer French...
My True beer fridge is freezing inside.
call repairman sounds like low on freon or thermostat problem either way better to have pro do it hope this helps
Sep 05, 2008 | True Refrigerators
Refrigerators Logo
27 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
