Question about Ovens
I was baking something in the oven one day and the breaker went. The oven shut off. Tripped the breaker and it started working again. Same thing happened again but this time I was not using the stove or oven. and the Oven would not heat up. But the stove top still works.
  • lisamyers135 Nov 11, 2010
    thanks, I will have to call someone in and hopefully that will be the end of the problem
    President:
  • 1,891 Answers
The oven uses 220 volts the top may only use 110 volts . when the breaker trips it just may not be able to handle the load . the range may be ok but the breaker may be at fault . it may even be a loose connection . this causes heat and may trip the breaker ..mm hope some of this helps . i think you should have a electrcian ck your power . ,, mm
Posted on Nov 08, 2010
Older whirlpool oven super capacity 465. tried to set bake and temp at 425 after preheat ove locked and went to self clean by itself shut down at breaker tried again and same result. the bake button r
You have a fault, if the contact breaker is tripping , that's something shorting like a element , or a fan motor. Basically you need someone with technical knowledge . ISOLATE THE OVEN FROM THE MAINS SUPPLY. Your going to need a tester, for continuity, inspect all heating elements, and fans visual and continuity tests on both , if no fault found move to the wiring and switches, test them , if any wiring showing signs of burning then a regulator problem may exist, replace damaged wiring after checking regulation, this job requires some considerable skill, and should not be under taken by a unqualified person.
Hope this is helpful
Regards
John
Oct 30, 2014 | Ovens
GE Wall Oven - No heat (broil or bake)
On appliances like this only the heating elements use 220 volts. things like the clock, fan, etc use 110 volts. That is why some things work and other do not. Start at the breaker, sometimes a double pole breaker will have 1 side tripped, but will look perfectly fine. switch the breaker all the way to off then re-set. If nothing changes follow the power to the appliance remove the panel and look for some fuses, check to see if any are blown. Also sometimes the microwave will have a separate power source even though its built in to the same appliance. So that's not always a good symptom to follow.
Nov 10, 2007 | Ovens
Oven elements do not heat?
The oven bake element has burnt out and needs replacing. Shut the power off to the range. Remove the element mounting screws located inside the oven above or below each end of the element. Carefully slide the element out, disconnect electrical wiring. Install new element.
Mar 28, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
My oven wont work?
check your breaker to see if it tripped,sometimes the breaker will trip and one or the other wont work.meaning the stove top or oven.also check and see if their are any breaks or burn spots in bake element and your broil element.
Mar 12, 2009 | Frigidaire FEB27S5A Electric Single Oven
I was baking something and all of a sudden the lights in our house went dim and our oven glowed bright orange and when I opened it, smoke came out but my food was still uncooked. Now the oven won't heat...
Sounds like you had an element burn out and tripped a breaker.
Find the breaker to the oven. If its tripped it should be in the middle position, not "off" they are sometimes easy to mistake for being on.
If you have a volt.ohm meter we can doagnose the problem and confirm if it is the element or not. (90% chance thats it.)
They are fairly easy to replace and usually pretty cheap.
But before you buy parts, make sure if its still under warranty or not. If it is, it could save you some time and money.
Jan 07, 2009 | Ovens
GE Oven JTP15BW Broil Element on, Bake Element off during baking.
I have the same problem. Just swap the 2 wires that are marked as 'broil' and 'bake' on the controller board. But sometimes it switches back, then I have to swap the wires again.
You might want to leave the 'broil' post unconnected to prevent burning food..
Nov 21, 2008 | Jenn-Air JJW8530C Expressions Collection...
The clock started flashing as if the power went out. Then when we tried to
The plug receptacle may be bad. Check the plug for proper tension. If feels loose, have the receptacle replaced. Inspect the plug for discoloration. (a sign of a bad receptacle)
May 22, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
KitchenAid KERA807PSS01 oven won't shut off until breaker thrown
assuming its a stainless stell oven? if so heres the par tyou need its a membrane switch( your cancel button ceased to operate corrrect???not a bad part to install you need to remove a few screws from under control panel itself( perhaps a few on the sides, the front control will lift off and this part is installed from behind the control panel (SHUT THE BREAKER(S))
part number 9756595ES
in the mean time instead of shuttin off the breaker toreset you can simply( requires reading manual ) set your oven to time bake. it will shut off automatically after predetermined time has been obtained.
Apr 27, 2008 | Ovens
Whirlpool oven issue
Usually, when an oven won't bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Oct 26, 2007 | Whirlpool RBS305PDS Electric Single Oven
F2 error, both ovens stopped working
F2 is a Oven temperature exceeded the clean runaway temperature (self clean only) or the cooking runaway temperature (cooking modes only)
Nov 23, 2006 | Dacor ECD230 Epicure Electric Double Oven
Ovens Logo
101 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
