Question about Linksys Wireless-G Broadband Router
No power I bumped the plug out of the wall, plugged it back in, and no power at all. Hit the reset button - no power. What have I done?
  • 1,183 Answers
Probably the power adapter has gone for a toss. Did the adapter fell from a elevated place?
Try changing the power cord it should be working fine
Thanks
mandeep
Posted on Jun 15, 2008
Why wont my sharp lcd LC-32D44U turn on?
Well, there could a be few issues. First thing is to verify the breaker that gives power to that wall has not tripped off in the home's break power panel. If it is not tripped then verify the wall outlet that the TV is plugged into has a reset button, like a GFI (ground fault interrupt) If it does then verify that it has not tripped. If the GFI on the wall plug is tripped simply push the reset button back in and then try plugging in your TV power plug again. Then if that checks out or does not have a GFI outlet, verify that the power plug going into the back of the TV is not loose. Unplug and replug power plug that plugs into the back of the TV in and verify it is securely connected. Lastly, the power supply in the TV might have gone out.
Aug 22, 2014 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Service ticket 8017416743
Can you please confirm us the main problem you are experiencing with your printer?
Oct 22, 2008 | HP Office Equipment & Supplies
Computer wont turn on
Make sure the tower is getting power. There will be a green light on the back of the tower where the power cord goes. Make sure the cord is snug and that it is securely plugged in to your power source - I'm hoping it is a power surge strip and in which case, make sure the surge strip didn't get unplugged or turned off. If you have it plugged directly in to the wall then make sure that outlet has power by plugging something else in to it that you know works. After doing all of this, make check to see if there is a light on the back of your pc. If not, unplug the power from the back of the tower, wait 30 seconds at least, and then plug it back in. Hit the power button on the front just once, if it doesn't power up, press and hold the button in for a 2 seconds and release. If that doesn't work, your power supply may have gone bad. That happens from time to time. Good luck, hope this helps!
Jan 20, 2013 | Thermaltake Computers & Internet
My emachines4210 tower won't switch on no matter how long I hold the button in!
If it is plugged in to a working outlet, you probably need a new power supply.
Sep 01, 2011 | E-Machines eMachines Desktop PC
I accidently hit the power button on the monitor and it will not power back up. Any suggestions?
You would need to power cycle your monitor. You can do this by unplugging it from the wall for 30 seconds. Than plug it back into the wall and press the power button.
Mar 30, 2011 | Gateway FPD1975W 19" LCD Monitor
Hp officejet 6500 all lights are flashing and mechine says turn off and on . Please can someone Help??
: Check the power cord
1.
Turn on the product.
2.
Remove the power cord from the back of the product.
3.
Check the power cord for any physical damage. If the power cord is damaged, replace the power cord.
If these steps resolved the issue , you do not need to continue troubleshooting.
If the issue persists , continue to the next solution.
Turn the product off and then on again
1.
Press the Power button ( ) to turn the product off.
2.
Wait 60 seconds, and then press the Power button ( ) to turn the product back on.
3.
If the product does not turn off when the Power button ( ) is pressed, wait three minutes, and then proceed to the next solution.
Plug the product into a wall outlet
Follow these steps to make sure the product is plugged in correctly.
1.
Unplug the power cord from the back of the product.
2.
Unplug the power cord from any surge protectors or power strips.
3.
Select a wall outlet to plug the product into. Test the wall outlet by plugging another electric appliance, such as a lamp, into the wall outlet and turning it on. Unplug the test appliance.
4.
Plug the power cord into the back of the product.
5.
Plug the power cord into the wall outlet.
6.
Press the Power button ( ) to turn the product on.
Solution six: Reset the product
Follow these steps to reset the printer.
1.
2.
Unplug the power cord from the wall outlet.
3.
Wait 10 seconds, and then plug the power cord back into the wall outlet.
4.
NOTE: Many power cords have an LED light on the power module or on the end of the cord that plugs into the product. Make sure the LED light is lit and steady.
5.
6. Perform a partial reset of the product
  1. Disconnect the power cord from the product.
  2. Wait for 20 seconds.
  3. Press and hold # and 3 while reconnecting the power cord.
  4. When the product turns on, release both buttons.
  5. Try printing again.
IF still won't resolve it by following steps mentioned above then your printer needs replacement. Malfunctioning hardware.
Mar 28, 2011 | HP Officejet 6500 Wireless All-in-One...
Etec player wont power up while plugged into computer. computer not detecting mp3
What you should do is go and buy one of those usb converters for a wall outlet. that way you can plug it is through the wall and see if it is the player or the coputer. If it still does not work it try it with a differnet cable/ If that does not work hit the reset button on the back and that will reset it without deleting any music. If that does not work you are going to need to buy a a new mp3 player because yours has crashed.
Sep 27, 2009 | Audio Players & Recorders
Loss of power
There would not be a reset button, but a hard reset can be done by unplugging it for a minute or so, then plugging it back in.
If that doesn't work, chances are you have a fuse blown in the microwave.
It's usually behind the grille, which is held in place by two screws.
Let us know what you find.
Oct 18, 2008 | Maytag MMV5207A Microwave Oven
When I turn it on I get E01
  1. The thermostat may temporarily lose calibration due to temperature changes resulting in an E01 error message on the display. Repeat the following steps to reset the unit.
  2. 1. Unplug the unit from the wall socket for approximately 10 seconds.
  3. 2. Plug the unit back into the wall socket.
  4. 3. Press the POWER button once. Within one second, press the COOK button once. The unit should now be rese
Dec 19, 2007 | West Bend 84496 6-Quart Slow Cooker
Linksys Wireless-G Broadband Router Logo
26 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
