Question about Whirlpool GEW9250 Electric Dryer
Dryer functions like normal however the temperature never gets warm. I am assuming the heating element is not working, how can I check or is there some reset button etc??
  • Whirlpool Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Posted on Nov 11, 2010
My Whirlpool AWZ8578 does not heat up. I have replaced heating element and thermostat but still not much heat. It is look warm, but not drying clothes as it used to. Please help
If you are not getting any heat but the dryer is otherwise functioning normally, then check the heater overload mounted on the dryer exhaust. It is essentially a fuse that melts when the dryer overheats. It is screwed onto the heat exhaust duct inside the dryer. If you know the heating element is coming on as you can see it or feel the heat inside the dryer but clothes just aren't getting dried, then it is an airflow issue and the likely problem is the dryer vent line is plugged with lint. This can be the external line that vents to the outside from the dryer, or internal inside the dryer. Either way that is a fire hazard and should be cleaned ASAP. Hope this helps
Feb 14, 2017 | Whirlpool Dryers
Dryer problem
have ou check the heating element, the thermal fuse..?
Jul 04, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Dryer not heating
Thank you for your inquiry, friend!
Based off the information you have provided your Frigidaire dryer is not heating. This could be a potential issue with your heating element, timer, or thermostat. In order to accurately check each part you would need to disassemble your dryer and test each piece for the proper continuity. This is not a simple DIY job and I would highly suggest contacting a professional technician comes out for proper diagnosis and repair. Best of luck! -Matt
Apr 20, 2015 | Frigidaire Dryers
I changed the heating element in my lady kenmore dryer, but still not heating...
If the previous element was burnt out, the following test can be done.
First unplug the dryer. then bridge the active and neutral on the plug with a bridging jumper. ( a piece of skinned wire will do ) then set the dryer control on heat (hot or warm) make sure the door is closed ( door switch cuts element as well as motor.) If this is impossible then you may be able to operate the switch by clamping it with something. then disconnect the element wires from the element. You should be able to read continuity across two of the element wires. If you can, then select the other temperature setting (hot to warm ect.) if you can read continuity across the common and the other then the element is faulty if you cant, then check hot temp switch, warm temp, switch belt breaker switch. if it has one.
Aug 31, 2011 | Whirlpool 279843 Whirlpool Kenmore Dryer...
Maytag EPIC dryer runs but does not get warm and therefore the clothes do not dry.
Hello there and thank you for choosing fixya
It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these.
Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance. Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it. To determine if the heating element is burned out, watch the part testing video at the bottom of this page. Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician. Cycling thermostat Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
Aug 05, 2011 | Dryers
Dryer is running but doesnt seem to be heating it takes a long time to dry and the clothes are not warm when pulled out
Your ignition unit may be worn out and will need to be replaced. Generally, a heating element comes on and once it reaches a certain temperature, it ignites the gas pilot. Then the heating element cools off because the gas is now burning and producing heat. When this heating element stops working correctly, it will not reach the right temperature to ignite the gas. You'll need to have a professional perform the repair. If the dryer is still under warranty, this might be covered.
Check your owner's manual.
I really hope this solves your problem. If it does, please come back to Fixya and rate my advice
Jul 16, 2011 | Maytag Neptune MDG5500AW Gas Dryer
Whirlpool Dryer LEB6200KQ0 - Issue will not heat. Have checked Power, Getting 220 volts (110 on each line at dryer) Checked Heating Element. Have continuity. Checked Thermal Link. Have...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 06, 2011 | Dryers
My heating element stays on for about 15 sec at a time-is this normal?
Is is normal for the heating element to cycle on and off. The element is usually protected by an operating (or hi-limit) thermostat that helps regulate the internal operating temperature. The element is not supposed to stay on continuously or you could end up with a scorched clothing, or a fire hazard. As your clothes get dryer, the heating element should cycle less. As long as you are not having any problems with dryer performance, you shouldn't have anything to worry about.
However, if your dryer is heating, but you are experiencing longer dry times or poor drying efficiency, the following link can give you some things to check before you assume there is a malfunction with your dryer:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
The number one cause of dryer heat related problems is poor exhaust ventilation. If not vented properly, a dryer will not dry efficiently, will actually take longer than required to dry, and will cause the heating circuits to overheat to the point of failure. The dryer will actually seem hotter than usual in many cases as the heating circuits begin to overheat. This is also the source of many fire hazards if not resolved. Read through the link provided and review some of the potential causes.
If you have any questions, please post back with your MODEL NUMBER and let me know. I hope you find this information is helpful.
NOTE: If you thoroughly check everything and still have problems let me know. The problem could be related to a thermostat failure.
Mar 12, 2010 | Dryers
Heating problem
Most dryer heat related problems are attributed to poor ventilation. An easy way to determine if you have a clog somewhere in the ventilation is to remove the vent hose form the back of the dryer and attempt to dry a load. The air flow leaving the dryer, should be forceful and warm (about 140 degrees F).
If the airflow is warm and the dryer performs as it should, you may have a clog in your ventilation from the point where it leaves the dryer, to where it exits it your home. In particular, if you have a vent line that runs through an attic or crawl space. These configurations are known for creating choke points for lint to accumulate.
If the airflow is weak and/or cold, you may have a clog INSIDE the dryer blower fan housing or a failed internal component. The following link explains:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
It is normal for the heating element to cycle on and off. The dryer has an internal bias (operating) thermostat that maintains the internal drum temperature based on your temperature setting. The heating element is not supposed to stay on continuously. Before assuming we have a failed component, doublecheck your ventilation for kinks or clogs and let me know.
If you have questions, or require further assistance, please let me know. I hope this helps you.
Jan 16, 2009 | Whirlpool LER5636P Electric Dryer
Gas dryer
Welcome jessegonzales
Check the outside vent leaving your house does not have a screen on it.
Take the screen off. Even half blocked and the dryer will not dry well.
Possible solutions
1. Defective Heating Element
The heat produced from heating elements is measured in watts and a normal heating element will produce about 4500 watts of heat. If the heat element is shorted to the case, this will cause the heating element to operate on 110v and use only about 1/2 of the element wire. In effect, the heat produced will be only about 1/4 of the amount that should be produced and the end result is an increased drying time.
The normal method for checking a heating element is to check it continuity. With the element unplugged you can check the continuity from one wire post to the next. If the circuit is open, thent he heating element is faulty.
However keep in mind that the element could be shorted to the case as described above. In this situation it is possible to have continuity, but the element still be the source of the problem.
Let me know.
Please remember to leave a rating
2. Defective Heating ElementThe heat produced from heating elements is measured in watts and a normal heating element will produce about 4500 watts of heat. If the heat element is shorted to the case, this will cause the heating element to operate on 110v and use only about 1/2 of the element wire. In effect, the heat produced will be only about 1/4 of the amount that should be produced and the end result is an increased drying time.
the heating element is faulty.
3.Defective Thermostat
The thermostats are responsible for maintaining the proper temperature in the dryer. Check the exhaust temperature of the dyer and if the temperature is above 150 degrees, you will most likely need to change the operating thermostat.
The thermostat can also fail in the opposite mode. It can prevent the element from heating at all. A failed continuity check at room temperature will verify this condition.
There are some special thermostats that are single pole double throw. These thermostats are often used to control the timer when set to the Automatic Dry cycle. If the dryer timer will advance in the Timed Dry cycle but not the Automatic Dry cycle, then the thermostat could be the problem.
4. Defective Gas Valve Coil (Gas Dryer Only)
If the gas dryer will light once but will not relight until it cools down, it is likely the gas valve coils are faulty. These coils loose some strength when subjected to heat. When they become old, the addition of heat may be enough to prevent them from opening the gas valve when hot. However the coils still work when when cool.
An easy way to diagnose the coils when the burner is not lighting, watch the ignitor. If the the ignitor glows for 10 to 15 seconds but no flame is created, then the coils are faulty. If the ignitor is not glowing the problem is elsewhere.
Recent Customer Symptoms:
The dryer burner doesn't always come on when starting. If the burner does come on, once it goes off if won't come on again until the dryer cools down.
One of these will solve the problem!
Thank You
Huuum.
Jul 29, 2008 | Frigidaire FGQ332ES Gas Dryer
Whirlpool GEW9250 Electric Dryer Logo
32 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
