Question about Sanyo Televison & Video
SL40 DVD drawer won't open. DVD disc trapped inside
  • 44 Answers
Unplug the power to DVD player and then replug it back in. Turn power back on and Hit open button on the player.
Posted on Jun 16, 2008
My Loewe DVD drawer is stuck closed with a DVD disc inside. How can I open the drawer and retrieve the disc?
Use a knife blade and gently pry the door open, it will work have done it more than once.
Nov 21, 2016 | Loewe Televison & Video
Cant open dvd drawer
Sometimes DVD player drawers get stuck closed because the disc inside isn't seated properly. At other times the player may have another problem. The first step in discovering if it is the disc or another issue is to remove the disc. Most DVD players have a secret eject button. It allows you to open the drawer when a disc gets stuck and cannot be ejected normally.
For this you'll need a standard size paperclip.
  1. Unfold the paperclip and make it as straight as possible.
  2. Look closely at your DVD player . Push the tip the paper clip into the small hole on the tray cover on the front of the Toshiba. The hole is on the right side of the cover.
  3. Press inward gently with the paperclip until you feel a slight resistance, then continue pushing to engage the internal eject button. The tray should pop open partway.
  4. Gently pull the drawer until it's fully retracted. Be careful not to pull too far.
  5. Remove your disc from the drive.
  6. Before you reinsert another disc, use the remote and/or buttons on the player to close the door, and reopen it. You can also press carefully with your fingers. If you cannot open/close the drawer normally at this point, do not put in a new disc until you have repaired the problem.
What You Need
Dec 09, 2013 | Toshiba SD Computers & Internet
Dvr 231 won't load
Someone needs to open the unit to see if something that does not belong got inside and to see if mechanism is functioning or not. If it does not fully load the disc it will eject it on its own.
May 28, 2012 | Pioneer DVR-231 DVD Recorder
Samsung blu ray player, dvd drawer will not open
Either the loading belt or loading gear wheels have the trouble. Sometimes the disc loading mechanism might need replacement. It won't cost mor for the mechanism. But will feel some difficulty in getting it from open electronic spare part market. it will be best to contact the authorised service center for Samsung to get it repaired.
May 12, 2012 | Samsung BDD5500 Bluray 3D Player
CAN'T OPEN DRAWER
Hello
There is a motor along with belt to control the disc tray for every DVD player. If this belt or motor [loading motor] has trouble, the tray won't come out or get into. Check these for perfectness.
Dec 12, 2011 | Philips DVP642 DVD Player
DVD drawer won't open after playing a film. Film plays fine, but now we can't get the darn DVD out!
Disc have something sticky attached on top (label ,specially rental discs') so when you try to eject disc get stuck on tray of spindle motor.Top cover need to be opened in that case in order to remove disc
Aug 23, 2011 | ESA E4000 DVD Player/VCR
Cant read the discs,dvd,cd or blu ray, "no disc"
You need to purchase a dvd disc cleaner or buy a can of air from wal-mart and spray out the drawer and the inside of the player with the drawer open,the eye of the dvd player is probably dusty and can't read the disc...and make sure the dvd is clean with no finger prints on it.
Feb 26, 2010 | Sony BDP-S300 Blu-Ray Player
I cannot open the DVD drawer on my Philips DVDR3480 DVD RECORDER – it just won’t open? The screen display just keeps saying ‘Error’. Any help is appreciated.
I have two of these dvd recorders and both have the exact same problem where the drive won't open. It opens fine when there is a disc in the tray. So I just unscrewed the cover, press the white part which would be over the center of the disc as it's trying to open, it should then open. Then just make sure there is always disc left in the tray.
Nov 26, 2008 | Philips Televison & Video
Gateway AR-230 DVD recorder
I read about some magnetic thing failing as the unit gets older. Mine does this sometimes and I gently tap top of unit as I hit the eject button. Works on mine so far.
Oct 09, 2007 | iLO DVDR05 DVD Recorder
The drawer on the unit won't open.
When the DVD player is plugged into power and switched on, and won't power up (nothing shows up in the front display panel), the power supply unit in the DVD is blown. the noise that player made was probably a capacitor going off. You will have to get the unit repaired.
Jul 28, 2007 | NexxTech DP3222 DVD Player
Televison & Video Logo
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
