Question about Bissell 1672 BIGgreen Wet/Dry Vacuum
My machine does not work. It will not put out water or will not **** up water It will turn on only
    Novelist:
  • 147 Answers
The pump is probably dead in the unit. you can try to turn it on without turning on the suction I believe. Providing your model has 2 switches you can anyway.
the only other thing it could be is the solution tube maybe blocked, or not enough solution in the tank to draw from.
a pump is approx $40-$60 just so you know.
Let me know either way.
Good Luck.
Posted on Nov 08, 2010
Bissell cleanview carpet cleaner
There are a few things that can cause a Bissell carpet cleaner to not dispense water. First thing to check is the belts if your machine is a Pro Heat. The flat belt goes around the motor shaft and the pump. As the motor runs it spins the pump. This is a stretch belt and stretch belts should be replaced at least once or twice per year to work properly as they will lose elasticity even if the machine has never been turned on. The first thing to check is to see if water will spray from the upholstery tool. If it sprays but you still get no water at the floor jets then check and clean the jets to insure they are not clogged. Getting water from the upholstery tool means the pump is working ok. If not, make sure the water tank and soap tank are not empty. Even if the water tank is full make sure the soap tank is full too. I would suggest NOT putting any soap in the soap tank because that is what causes most of the problems. Put plain tap water in the soap tank and try the machine again. Hold the trigger down giving it plenty of time to flush out any air bubbles and/or soap from the pump and the lines. If you still can't get any water from to the floor jets the most likely problem is the heater is clogged with mineral deposits or soap gunk. When a machine sits in the closet for months the soap in the lines coagulates and will clog things up. Which is why if you want the machine to work for a long time NEVER put soap in it. To do a better job of cleaning put your soap and hot water into a sprayer and use this solution to pre-condition the carpets. Pre-conditioning gives the soap and hot water a chance to dissolve the gunk in your carpets, then use fresh hot water in the machine to flush the soap and dirt from your carpets. Your machine will last longer and your carpets will be cleaner and stay clean longer because you rinsed out the soap. If you try this method you will be amazed how much cleaner your carpets will be.
If you need to clean the heater you will need to separate the handle assembly by removing all the screws. First make sure the machine is unplugged. You'll have to figure out which screws need to come out, it's not too tough. The heater is inside the handle. Look at how it comes apart so you will know how to put it back together. The heater is the silver metal thing with wires and hoses. Remove the screws that hold the cover on being sure not to lose any of the tiny red gaskets. Remove the cover and clean the soap or mineral deposits from the heater core, put the cover back on and put it back together and it should work fine. To keep it from getting clogged again simply make sure you use soft water if minerals were the problem and never put soap in the machine.
Oct 22, 2013 | Vacuums
Solution will not spray on carpet unless you use tools or spot spray also brushes are not turning
proheat 9300
Remove the water tank. You will see 2 red tabbed plastic spray tubes.(where the spray comes out if not clogged) Pinch the clips to remove from the machine. Then you will need to pinch the hose clips to remove the red tabs from the hose. Clean out those red spray nozzles. Next step: have a towel ready and fill the solution tank with water. Put the solution (not water) tank on to where the water tank would go. Place the machine selection knob to rinse/wet only. Now with towel under the hoses that you removed the red tabs. Turn on the machine and pull the trigger to activate the water. You should see water flow out of the hoses that had the red tabs on them. If not, release and pull again the trigger several times. If only 1 hose has water coming out of it then block the one that works and try the process above again to de clog the one that isn't working. Good luck.
Dec 07, 2011 | Bissell 9500 ProHeat 2X CleanShot Upright...
How to unclog a bissell proheat turbo carpet cleaner
proheat 9300
Nov 24, 2011 | Bissell ProHeat Turbo Deep Cleaner Upright...
Repair hoover steam vac F7210
Fixya does not make servicing recommendations.
Jul 23, 2017 | Vacuums
Krups espresso machine Type F927 It doesn't seem to build enough pressure. I've run cleaner/descaler through it several times and put in a new water filter. Ideas?
Make sure the button that turns on the top is all the way turned to the right. I have had similar instance where the button was slightly turned and it did not work.
Sep 11, 2010 | Vacuums
No water sprays when I press lever on handle
proheat 9300
assuming the water works for the tools
Apr 13, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell steam cleaner model 9300 not putting out soap
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
,b..,
May 14, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
Hoover SpinScrub
I would almost guarantee the recovery tank is not seated properly. Trust me, I reseated the tank 5-10 times before giving up. I finally decided to give it one more try before forking out the money for another cleaner. I removed the clean water tank, turned the machine on (you could feel the air blowing out the sides on the bottom). With the machine still running, I unclipped the recovery tank and lifted it up (yes, you can do this, and it creates a very loud air thrust, but don't be scared), then I SLAMMED it back down into the seat and immediately I could tell the difference. The air stopped blowing from underneath and I could tell I had suction once again. I turned it off, put the clean water tank back on, and it worked like a charm. Trust me, you may be convinced that the recovery tank is seated properly.....LOL.....it ain't! Hope this helps!
Mar 24, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Bissell 1672 BIGgreen Wet/Dry Vacuum Logo
136 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
