Question about Panasonic PT-AE900U Multimedia Projector
I have a Panasonic PT-AE900U projector that doesn't project an image. The lamp fires up but no light makes it past the LCD panels, no video or menu graphics, nothing. I have checked all internal connections, wiring, etc. but nothing is physically wrong with it. Powers on and off with no issues; bulb is working but no light out of the lens. Please help!
  • 1 more comment
  • Frank Paul Nov 08, 2010
    Hello 2007nfm- thank you for the advice; I have checked the brightness and shutter function with no change but will look at the thermal sensor. I already have a copy of the service manual and did some basic checks but am wondering whether processor control to the lcd panels has somehow failed. I should note that the power indicator does go to green when the unit is powered up and the CPU test LED does illuminate (D1024) as it normally should. I am obviously missing something but will continue to troubleshoot this problem. You help is appreciated. Regards -Frank
    Hello bannonj- thank you for the advice. The bulb is working correctly and I do have a new spare I tried with the same result. I already have a copy of the service manual and did some basic checks but am wondering whether processor control to the lcd panels has somehow failed. I should note that the power indicator does go to green when the unit is powered up and the CPU test LED does illuminate (D1024) as it normally should. I am obviously missing something but will continue to troubleshoot this problem. You input is appreciated. Regards -Frank
  • Frank Paul Nov 15, 2010
    Hi vetteman- I did take the analysis block apart to check the mirrors and optics and with the exception of a minor cleaning, everything is in good order. I still think that what ever controls the three LCD panels is not functioning (IC chip?). Any input is appreciated,thanks. -Frank
  • 2,299 Answers
This is usually caused by the mirrors being out of alignment. Make sure that the mirrors have not fallen or broke.
Posted on Nov 12, 2010
  • 1,514 Answers
Was the bulb replaced in the unit. If it was it, or the cover, may not be installed tightly enough. Also if the bulb was not replaced when it has it's lifetime of 3,000 hrs was reached it may not operate correctly. If neither of these is the problem you should contact Panasonic Technical Advice on (800) 524 - 1448 or by email at pbtssupport@panaconic.com
If you don't have a manual there's one available at http://service.us.panasonic.com/OPERMANPDF/PTAE900U-MULTI.PDF which might be of some help.
Posted on Nov 08, 2010
  • 2,069 Answers
You should first of all check that the input selection setting is correct, the "BRIGHT" adjustment setting is not at the minimum possible setting and that the "SHUTTER" function is not in use.
If the above is ok, then you should check the thermal sensor. with this, i thought i should provide you with its service manual that will guide you on how to disassemble and check these parts. please download it from here and especially check on page 32 and on. Good luck.
My acer projector flickers after 10 minutes and very hot air comes out from its vents, making it difficult to stand near it and it also show vertical lines.
the projector flickers after 10 minutes ,it seems that the lamp ballast is failing
shows with vertical lines, it seems that the LCD panels are failing or the panels cable not be tightly plugged (panel-cable plugs into the mother board)
We supply original projector lamp,bulb,parts,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry,Lampdeng Limited
Mar 12, 2014 | Panasonic PT-AE900U Multimedia Projector
Panasonic pt ae900u doesnt project full picture,subtitle cannot be seen on screen
change the resolution of the input source
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip,color wheel, motherboard, powersupply ... with high quality and competitive price.
Jerry China Lampdeng Limited
Tel: +86 131788 67858
E-mail: lampdeng@hotmail.com
Skype: lampdeng.com
YM: lampdeng@yahoo.com
http://facebook.com/lampdeng
http://www.lampdeng.com
Feb 18, 2014 | Panasonic Office Equipment & Supplies
Our projector (Panasonic PT AE900U) is still working but the picture seems very dark all of a sudden. we are wondering if this means we need to replace the bulb and if so, what do we replace it with.
You need a new lamp. Cost is around $350. The following site shows replacement:
http://www.shopvsc.com/Replacement-Lamps-for-Panasonic-Projectors-s/284.htm?searching=Y&sort=7&cat=284&show=50&page=1&f-PT-AE900=109462
Oct 16, 2010 | Panasonic (ETLAE900) Projector Lamp for...
I have a Panasonic pt-ae900u projector that doesn't project an image. The lamp fires up but no light makes it past the LCD panels, no video or menu graphics, nothing...help would be appreciated
I have the exact same issue with my projector and was wondering if anybody has an idea what the problem/solution could be? Have checked all internal connections, wiring, etc. but nothing is physically wrong with it. Powers on and off with no issues; bulb is working but no light out of the lens. Please help!
Oct 14, 2010 | Panasonic PT-AE900U Multimedia Projector
Panasonic PT-AE900U Projector Lamp stops working (intermittent)
since it has worked 1200 hours or even more since u have been resetting the counter! just change the lamp, resetting the counter does not make the lamp work or not work , it is only a reminder for the user to change the bulb when it should be & that u have some balance hours left to procure a new lamp!
if the brightness is adequate, then it is a ballast problem & not lamp problem!
buy a new lamp as u will anyway need to , fit it & it may solve ur problems permanently!
Jan 27, 2009 | Panasonic PT-AE900U Multimedia Projector
Panasonic pt ae900 wont fire up
First , start over and unplug it. Wait a few minutes. Turn on AV system that is connected to it but not video or dvd player. With remote, point at is corectly and push power 1 sec or as soon as you see green light come on. Be quick.
If this fails you can wait 4 hours and repeat. OR try only projector with out any feed.
Let me know if this worked.
Dec 14, 2008 | Panasonic PT-AE900U Multimedia Projector
Panasonic PT-AE900u no image
may i know now what is the age of your projector. have you done replacing the lamp of the unit before.
Lamp life varies by manufacturer and projector type. Lamp life also depends on the projector's environment: air flow, clean air, and also on the level of usage. Check the user's manual or specification pages for your projector to determine the exact lamp life.
Nov 04, 2008 | Panasonic PT-AE900U Multimedia Projector
Panasonic PT-L759U
With the power on and the lamp off, hold the input button down on the projector then press and hold the power button for 5 seconds
Nov 16, 2007 | Panasonic PT-AE900U Multimedia Projector
Panasonic PT-AE900U displays black and white only
sounds like bad cables, or wrong setting on projector you may have it set to compoent instead of composite,, you don't tell how you are hooking it up. (what type of cables you are using)
Oct 25, 2007 | Panasonic PT-AE900U Multimedia Projector
Panasonic PT-AE900U Multimedia Projector Logo
171 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
