Question about Westinghouse Electric Westinghouse Lighting 3speed Ceiling Fan Switch 7707500
Chain broke on 3 speed ceiling fan. Swith is Jin You # E70469 which is 3 sections. There is a yellow wire which comes out of the top section and goes into the second section with no ends showing. There is a black wire, yellow wire & white wire coming out of the second section then a blue wire coming out of the top section. I have been to Lowes & Home Depot but can only get middle speed on fan with their switches and suggestions? Where can i get original switch?
2 Suggested Answers
SOURCE: chain broke on jin you
Try following link, without guarantee: It has same number but says 4 wires
http://www.allelectronics.com/make-a-store/item/PSW-14/PULL-CHAIN-SWITCH/1.html
You posted under Westinghouse:
http://www.atlantalightbulbs.com/ecart/catalog/westinghouse-6.html
Internet search does not show 5-wire switch, they are either 3 or 4 wire.
Maybe you have older fan, or maybe the switch can be replaced with 4 wire.
Next step would be to test your wires to see if 4-wire conversion can be made:
Determine which wire is hot if possible.
Take photo of wires and then remove switch.
Use multimeter set to read ohms, and test between each wire and the wire you labeled hot wire.
http://waterheatertimer.org/How-to-wire-Cooper-277-pilot-light-switch.html#3-speed
Posted on Aug 02, 2011
Ceiling fan model 1660
Always write down which color wire goes into which slot on the pull chain switch before removing it. All I can tell you is the black wire usually goes into the L. The others you'll have to play with. Also, just because the switch looks the same on the outside doesn't mean it's the same on the inside.
May 26, 2013 | Dryers
Chain on a JInyou E70469 3 speed fan switch broke. need to replace switch
I have this exact Jin-You E70469 switch. Forget a replacement unless you drop about $20 on ebay. Westinghouse replacement switches did *not* work for this type of switch. Here's the solution that worked for me: CUT THE POWER and test before you touch anything electrical. 1) Diagram the wiring configuration of the switch noting where things go---take pictures. 2) Take out the wires that connect to it. Use a paper clip to spread the clips to pop them out. If you have any wires that come out and back in the switch itself, you can leave them attached. 3) See those pins that keep the housing together? Get a drill bit---or Dremel tool---just slightly bigger than the bottom of the pins. You're going to drill off bottom/rolled over part of those pins. Take it easy. LEAVE THE PINS IN. Do not take the pins out. With the bottoms of the pins ground off gone, now take off the nut that's threaded onto where the chain comes out. Now, carefully pry apart the bottom of the housing. Take a picture. Notice the position. Notice the position. Now, pry the little closure carefully just a little and replace the chain. Put the spring back exactly how it was. NOTICE the little finger in the bottom cover where the spring catches to snap it back. Put the bottom housing on. Holding the whole thing together, try the switch. If it doesn't recoil, pry it apart again, and adjust where the spring catches. This part will annoy some of you. Test again. If it pull ans recoils, you've got it. Put the nut on. Put electricians tape around the housing---don't cover any inputs. Re-insert your wires according to what you had. Put back together.
Mar 22, 2013 | Westinghouse Electric Westinghouse...
Need a santa e70469 switch
Pull Chain on Bottom
L 1 2 3
Upper Yellow Jumper Pink Grey
Lower Orange - Jumper Black
Santa E70469
SwitchCo part # 01
or
KensElectronics.com part # ZE-208D-01
z
Apr 23, 2012 | Hunter Dryers
Chain broke on jin you 3 speed 5 wire switch part # 70469. only repacement found has 4 wires. any known suppiers in the Orlando,Fl. area?
Aug 02, 2011 | Westinghouse Electric Westinghouse...
Replacing 3 speed 4 wire ceiling fan switch did not take note on what color wire goes L 1 2 3 wires colors are black grey brown and yellow need help to fix fan
Copy following link for 3-speed fan wiring:
Apr 27, 2011 | Solar Fan Impressions 3 Speed/4 Wire...
How to attach an on/off chain to a ceiling light- the original broke off somewhere inside. The fan switch is intact. This is one unit.
You need the little coupler thing that connects to the ball that makes up the chain. If you dont have the coupler ... you could get one at your local Ace Hardware store ... or you could just purchase a similar switch which would have the coupler on the chain.
Jun 07, 2010 | Leviton 1689-050 Pull Chain Fixture Switch
I broke the chain for the fan on my ceiling fan and bought a new switch but didn't write down which wire goes where. Theres a black,yellow,orange and red. The switch has L,1,2,3. Which goes where?
look at this diagram it has the L 123 configuration
just not the same color code other than RD and Blk
but you should be able to work it out anyway
http://www.hurontel.on.ca/~taitg/pages/cfan.html
Please rate our help++++Thyanks for using FIXYA
Oct 11, 2009 | Speed Ceiling Fan 3-speed Switch By...
Wire diagram for pull chain on ceiling fan hunter original
if you indeed have a 23852 hunter original...
Black goes to L, High is Red, Gray is medium and yellow is low. Make sure you have the right switch.
Mar 21, 2009 | Hunter 23852 Classic Original Ceiling Fan
Westinghouse Electric Westinghouse Lighting 3speed Ceiling Fan Switch 7707500 Logo
4,114 people viewed this question
Top Westinghouse Electric Electrical Supplies Experts
AJMAL KHAN
Gene Haynes
Are you a Westinghouse Electric Electrical Supply Expert? Answer questions, earn points and help others
