Question about Sony XM-2200GTX Car Audio Amplifier
Can you bridge the XM 2200GTX - Sony XM-2200GTX Car Audio Amplifier
  • 27 Answers
Yes you can but you have to read the instructions and make sure you install the correct type of speakers.
Here is the link address for the manual.
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Posted on Nov 08, 2010
Hello, i have the sony xplode 2200.. The amp says that it is 1200w either bridged or to 2channels. I have 2 cerwin vega hed subs that are 1000w a peice. The retailer informed me that they are wired to...
well for 1 , musicc is goin in an out that means ur grounds not big enuff or its not getting good ground thats why ur amp is getting hott to becuase u got all that power but no ware for it to go so check the ground for me an if ur music is still doin that then try ur acr wire unplug one of them when musice is low an plug it back in an unplug the other so on , i would love to know if this help an please vote
Jul 18, 2011 | Sony XM-2200GTX Car Audio Amplifier
Need to know how to hook up duel voise coil subwoofer using a sony XM-2200gtx amp
set the amp to mono if your are able, if this means that you can only use one set of outputs then connect both voice coils to that one. (both positives together and both negatives together) Run at low volume for a whiole to make sure all is well and there are no overheating problems.
Some amps allow you to connect to the positive connection on one side and the negative on the other, this is known as "bridging" and may well provide more power to your sub.
May 05, 2011 | Car Audio & Video
Is it normal for my xplode xm-2200gtx to get rally hot?
it depends how hot youre talking about it will get warm if you use it for a long period of time
Apr 05, 2010 | Sony Xplod XM-1652Z Car Audio Amplifier
Can you bridge a sony xm-2200gtx amp, if so what polarity on which channel. Currently pushing two speakers. trying to see if i can bridge it and use a singe speaker?
left positive and right negative-make sure the speaker that you intend to run in bridged mode is 4 ohms or you will kill your amp
Nov 30, 2009 | Sony XM-2200GTX Car Audio Amplifier
Bridging problems
Normally bridging an amp is using the left + and the right -
Here is a link to your amp specs
http://www.crutchfield.com/p_158XM2200/Sony-XM-2200GTX.html?tp=115&tab=features_and_specs
Jan 30, 2009 | Sony XM-2200GTX Car Audio Amplifier
How do i bridge a xm-2200gtx.
Usually the Left + and the right - is bridged. Here is a link to the specs on your amp:
Sony XM-2200GTX no sound but light will go on sometimes
I'll assume that you've checked the amplifier's on-board fuses.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Nov 05, 2008 | Sony XM-2200GTX Car Audio Amplifier
Installation question
it depends on the amplifier your are going to run. if you bridge the tens together that will give you an 8ohm load. say the the amp is 2-4 ohms stable, then you would be fine
Jun 21, 2008 | Sony XM-2200GTX Car Audio Amplifier
Sony XM-2200GTX...Power, Green Light, All OK, No Sound!
Sony generally drives their power light from a source that does not rely on the amplifier's switching power supply. This means that it's not a good indicator as to the health of the amplifier.
As long as you have B+ and remote voltage, it will light up. Since you've tested the speaker and the signal source, I think the amplifier is likely defective.
Oct 17, 2007 | Sony XM-2200GTX Car Audio Amplifier
Power comes through ground
Check to c if any power wire shorting to ground
Aug 20, 2006 | Sony XM-2200GTX Car Audio Amplifier
Sony XM-2200GTX Car Audio Amplifier Logo
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
