Question about Toshiba TDP-T9 DLP Projector
Toshiba TDP-T9 projector: Power light flashes, lamp will not come on. Lamp appears fine. Any thoughts?
  • 9 Answers
SOURCE: Toshiba TDP-S20 lamp problem
The lamp ballast which ignites the lamp has failed it sounds like. The red flashing lamp is the tell tale sign with a good lamp installed. Make sure the lamp door is closed too, there is a door switch that can also trigger the red lamp and no startup. There is a company in San Diego CA that can repair the unit called PROJECTOR DOCTOR
Posted on Jan 22, 2008
SOURCE: Toshiba TDP S8 projector shuts down suddenly
most probably the lamp is dead already.
jimag2008
Posted on Jan 24, 2008
3bachelors
  • 52 Answers
SOURCE: Toshiba Lamp Reset - How?
Not positive, but I would assume the same as my Toshiba.
With the on, input, and menu buttons held down, insert the power cable.
Hope this helps, NGK
Posted on Sep 03, 2008
SOURCE: Toshiba Projector won't turn on!!!
I had the same. Try to press the "input" and "menue" buttons and plug in the power cable. No control light should be active after that. Press the "power" button and it should work.
Posted on Dec 28, 2008
  • 5 Answers
SOURCE: HOW TO RESET TOSHIBA TDP-S8 LAMP
after installing the new lamp, hold the volume top & bottom key simulteniously, when green light indicate at panel start the projector & go to service there you may found reset lamp ? press yes the lamp will reset.
Posted on Feb 01, 2009
Service manual
It is not working for Toshiba TDP-XP2, when I hold three button above and plug the power on, the light at power button is blinking forever.
Any help will appreciated.
Apr 04, 2012 | Toshiba TDP XP2 DLP Projector
Tip
Toshiba TDP-P9 Lamp time reset
I had sleepless nights with my customers TDP-P9 projector where I changed the lamp.
The lamp timer resetting gave me headache but now I finally solved the right combo:
1: Unplug the power cord
2: Hold down 'On/standby' 'Input' and 'up arrow'
3: While keeping the buttons pressed, insert the power cord and wait for the projectors led's to flash briefly and then power button to keep illuminated and then starting to blink.
4: Release the buttons and power on, it should now have 0 hours in the timer.
on Apr 06, 2011 | Toshiba TDP-P9 DLP Projector
How do you reset lamp hours on a Toshiba TDP-Tw420 projector?
1. Turn-off the projector by pressing the "ON/STANDBY" and unplug the power cord.
2. In the meantime, hold down buttons "ON/STANDBY", "MENU" and "INPUT and plug-in the power cord .
3. The lamp operation counter will automatically turn to zero.
4. Check if the lettering "0H" appears on the lamp operation counter in the status display.
Jul 31, 2011 | Toshiba TDP-TW420 DLP Projector
I want to rest the Lamp timer of Toshiba Projector TDP-TW95 after replacement of New Lamp
hi
reset ur lamp timer through the following procedure
p { margin-bottom: 0.21cm; }
1. Turn-off the device by pressing the "ON/STANDBY" and unplug the power cord
5. After the lamp operation counter has turned to zero, turn off the projector by pressing "ON/STANDBY" and unplug the device.
ok
Jan 06, 2011 | Toshiba TDP-TW95 DLP Projector
Toshiba TDP-T9. the light won't change from yellow to green. we tried restarting the computer and the projector, but nothing seems to work.
Well first check the colour scheme of your monitor and of the projector.
If this doesn't work check the working hours of the lamp. Try cleaning the filters and if this doesn't solve your problem the best thing to do is to change the lamp of the device.
If you need further assistance please leave a comment. Cheers
Aug 25, 2010 | Toshiba TDP-T9U Multimedia Projector
Toshiba tdp-t90 projector. I rplaced the lamp on
set the beamer off, unplug the power line, press -on-/input/menue at the same time and plug the beamer to the power line again thereafter you can remove your fingers from the below mentioned buttons. now the lamp counter should be reseted to 0 hope this helps it works on a TDP-T100
Aug 02, 2009 | Toshiba TDP-T90 Multimedia Projector
Feb 01, 2009 | Toshiba TDP-S8 Multimedia Projector
Standby light for toshiba
probably power supply or ballast (starts the lamp)
either would be $600.00 or so to repair, probably costs more than the projector is worth.
Jul 15, 2008 | Toshiba TDP-S8 Multimedia Projector
Wil not turn on
Either your lamp is burned out or you had it unplugged for a while.
If you have had it unplugged for a while, plug it in, make sure the yellow power light is on, then wait for about an hour. Don't repeatly try to turn it on in the meantime. After about an hour or two plugged in,,,,, it should power up. Then reset your lamp timer through the menu.
Apr 02, 2008 | Toshiba TDP-T9U Multimedia Projector
Nov 29, 2007 | Toshiba TDP-S20U Multimedia Projector
Toshiba TDP-T9 DLP Projector Logo
296 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
