Question about Viking DFB450 Dishwasher
Dishwasher does not want to start it lights up and then the blue light on the bottom turns off -- it has a small amount of water in bottom and that is about 1/2" to a 1" ans is starting to smell ,, help please --- there is nothing stuck in the tray collector
  • 641 Answers
SOURCE: dishwasher
Check whether the drain line was assembled exactly as per Kenmore's instructions. Good luck!
Posted on Sep 11, 2007
MNfisherman
  • 11896 Answers
SOURCE: small amount of water remaining in bottom basket
There is a screen in the drain that is plugged.
Posted on Apr 15, 2009
  • 4 Answers
SOURCE: Water does not drain from the bottom. I understand that a small amount is normal, however, this is not a small amount. Thanks for your help.
It worked for me .I have a danby countertop dishwasher.
I took off the metal top
I looked under on the left side to find the pump
I took both hoses off the pump and took off the little fan.
i took off the little metal bracket behing the little fan. and unscrewed the little pump to take it out.
the little metal piece that the fan was on wouldn't even move.So i sprayed it down with wd and it started moveing again then a screw fell out.so i found where it went(inside the motor which the fan and metal piece move) got the tweezers and replced it. oiled it some more and put it all back together. Perfect.
Posted on May 25, 2009
  • 864 Answers
SOURCE: water and odor collecting in our empty dishwasher after 4-5 days
A small amount of water may be normal.  Clean the filter at the bottom of the tub.  Sprinkle some baking soda inside between washes.
Posted on Jun 02, 2009
  • 66 Answers
SOURCE: THE DISHWASHER STOPPED WORKING. NOTHING COMES ON.
call for a technician to do the checking of the problem maybe it needs repair
Posted on Nov 17, 2009
Small amount of water covering bottom dishwasher-won't drain
YES IT IS WATER FROM DRAIN HOSE LEFT AFTER PUMPING OUT THE MAJORITY OF WATER AND IS LEFT IN HOSE.
Mar 10, 2010 | Maytag 24 in. MDB3700 Built-in Dishwasher
GE Dishwasher no water upon start, humming, blinking lights
Seems like the anti flood is activated when water (even a small amount) appears on the bottom of the machiene. This is usualy a leaking pipe but can also be caused by a clogged pipe. Most machiens do have a plastic pipe that (from the flat water tank) feeds water to the bottom of the machiene in case of an internal fault. The anti flood is normaly a polystireen float with micro switch on the base of the washer. This automatically puts the outlet pump on to drain the water. The machiene does not work exept the outlet pump in this mode.
Jan 18, 2010 | Dishwashers
Candy dishwasher 2 program lights keep flashing after program starts then stopas and flashing starts
My candy dishwasher Model No CDI 3015-S retains water in the bottom of the machine at the end of the program. I have checked the filter which is clear so do not know what else to do to clear the problem. Anyone faced this problem or know what might be the cause?
Jan 18, 2010 | Candy 17 in. CS455 Built-in Dishwasher
Control stuck on, with multiple light combinations
All this is normal except for the lights coming on. could be the panel control board.
Oct 08, 2009 | GE Dishwashers
Water and odor collecting in our empty dishwasher after 4-5 days
Jun 02, 2009 | Dishwashers
DIshwasher wont start, flashes pre-wash and was lights
1) Ensure the dishwasher is turned off. 2) (may not apply) Turn the plastic blue lever located under the sink to the vertical position (this opens the valve, so water can go into the dishwasher) 3) Pour powder indo the dishwasher 4) Turn the dishwasher controller to the top position (the 12 o?clock position) ? this is the eco-setting. 5) Press the on/power button on the dishwasher, so that it now turned on (a light will display) 6) Move the dishwasher controller to the ?R? position (it?s on the very left), and leave it there a second or two. 7) Move the dishwasher controller back to the eco-setting (the 12 o?clock position).
Apr 19, 2009 | Ariston Technologies L63SNA Stainless...
Zanussi DCE 5655 dish washer
Unplug at night if doesn't work change the L subport conversion chamber and remove the restricter plate
Feb 27, 2009 | Zanussi 21 in. DCE5655 Free-standing...
No water coming in
Check the float.
There is a float inside the dishwasher but you can't see it. The small dome in the bottom has a float inside that activates a switch underneath by a plunger. Sometimes this float gets stuck in the up position. Take the bottom panel off and look directly under the dome for the switch and the plunger that activates the switch. Push this plunger up to see if it moves freely. If it moves then you need to check the switch then the water valve solenoid with an OHM meter. Next, use the meter to see if the timer is sending power (110) to the water valve.
If everything is good to this point then check the water supply. Turn the water supply off, disconnect the water line from the dishwasher water valve, run a small amount of water into a pan.
Hope this helps.
Jan 18, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Electicity going to dishwasher but when program dial turned it doesnt start program even though its switched on and door closed
small amount of water at bottom of dishwasher, electricity is going to the unit no breakers are blown, no light nothing responding on dishwasher
Sep 03, 2008 | Kenmore 16872 Built-in Dishwasher
Indecit dishwasher not circulating water
Checked that the motor was not seized by inserting slotted screwdriver through hole at back of machine to engage in slotted end of motor to spin up water circulating motor. Motor was not seized, so that was not the problem. Then took bottom off machine and on inspection found that the start capacitor which is bolted to side of motor was bulging and discoloured wher the terminals are. Replaced Start capacitor ( Less than £10.00) and machine motor started up. Machine behaved irratically at first, flashing lights etc.but got it to reset by switching on and off a couple of times, ran machine through cycle, now working ok.
Mar 04, 2008 | Dishwashers
Viking DFB450 Dishwasher Logo
Top Viking Dishwashers Experts
Mike
Don Kahr
Don Kahr
Level 1 Expert
Rick Gloria Malmoe
Rick Gloria Malmoe
Are you a Viking Dishwasher Expert? Answer questions, earn points and help others
