Question about Panasonic AG-HMC150 AVC Camcorder
Camera will not turn on. Using AC or battery does not matter.
  • 3,083 Answers
The most likely cause of this is a bad on/off switch. Unfortunately, to find out, you have to disassemble the unit to check it. It's possible that it's a board problem, but that's not likely.
I would run it by a camera repair shop and see what they think, and how much they'd charge.
You can also contact Panasonic Support to see if they have any suggestions, or what they can do.
http://www2.panasonic.com/consumer-electronics/support/Cameras-Camcorders/Camcorders.75489
As a last thought, check to make sure your power adapter and battery are good.
Good luck, and hope this helps.
Posted on Nov 08, 2010
I have sony cybershot dsc 10 digital camera but it dsn't power on batery charge is full
Please make sure that the Battery in the Camera is fully charged.
Please check if the issue is with the battery charger. Make sure that the Charge Lamp in the Battery Charger is lit when connected to the Wall outlet.
You can try recharging the battery pack for almost 6 hours as initial charging.
If you've another battery pack, try using the same to check if the issue is with the Camera or with the battery.
You can also try turning on the Camera by connecting the optional ACL-S5K AC Adapter. This Adapter can be used for turning on the Camera, it cannot be used to charge the battery pack. For charging the battery in the Camera, the supplied battery charged needs to be used.
If the Camera is not turning on using both the AC Adapter and new battery, then the Camera may require service.
Thanks for using FixYa.
Jan 10, 2011 | Sony Cyber-shot DSC-H10 Digital Camera
I have sony digital camara but it dsn't power on batery charge is full
Jan 10, 2011 | Sony Cyber-shot DSC-H10/B Digital Camera
I have sony digital camara its not power on plz help me
Jan 10, 2011 | Sony Cameras
I was changing the batteries on my Fuji S1 pro camera and did not shut off the camera first. Now It won't turn on at all. I have put three sets of batteries in to make sure it wasn't a faulty battery.
Check the batteries.
These camera's require Alkaline batteries too.
Connect camera to an AC adapter.
Remove all batteries, sd cards, disconnect AC adapter, wait a minute,
re-insert batteries and reconnect adapter. lay flat on the table.
Turn on the camera.
Using the mains power gives more power to the lens motor too,
Sit it on a table with ac mains in, turn on while flat on it's back, hopefully it will
Turn on and auto-focus for you.
You could blow the camera with "canned air" too, to release any particles on the camera
The smallest particle in the lens barrel, will jam up the lens and system to a stand still.
If problem persists, i am afraid, you need to seek professional on site or send the unit for repair.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 14, 2009 | Cameras
My Kodak m1033 will not stay on. Once I press the power, the screen is blurry and then it shuts off.
If your using the battery which is included on the box the KLIC-7004 try to clean the 3 metal contacts of your battery using a clean dry cloth. hen charged the battery using AC adaptor or USB cable., Now if this not work, Try to turn On the camera using the AC adaptor if you experienced same problem it means the your camera is defective, But if you can turn On the camera using AC adaptor It means the battery is the cause of the problem
You may call tech support toll free 1 800 235 6325 ext 12
Nov 13, 2009 | Kodak EasyShare M1033 Digital Camera ...
Lost Power to camera
well you should lurn from this,,only use the charger that comes with the unit,,,im sorry to tell you this but you more that likley have done your camera in was the charger you pluged into your camera the same voltage and polarity as the cameras normal charger?
if it was in revers you would have cooked the camera
Nov 05, 2009 | Kodak Easyshare 1725043 M893Is Digital...
The on off button is stuck in. is there anything you can do or do i just buy a new one.
Reset the camera
  1. Turn off the camera, if possible.
  2. If an SD memory card is installed, remove the card.
  3. Remove power from the camera as described below:
    • If you are using only batteries for power, open the battery/memory card door and remove both batteries.
    • If you are using only the HP AC power adapter, disconnect it from the camera.
    • If you are using both batteries and the HP AC power adapter, remove both batteries and the power adapter.
  4. Wait for 15 seconds. Then reinsert the batteries and close the battery/memory card door or reconnect the HP AC power adapter to the camera. If you are using both batteries and AC power, try each method separately.
Turn the camera on and off. If the issues is not resolved do the following
Connect the camera to the optional AC power supply
  1. Connect the camera to the optional AC power supply. Ensure that the AC power supply is connected to a working power outlet.
  2. Try turning the camera on.
  • If the issue is resolved , you do not need to continue with the rest of the instructions in this document.
If the is not resolved ,then repeat setps 1 to 4 abiove but remove the batteries and keep the AC power adapter connected.
Oct 14, 2009 | HP Photosmart M425 Digital Camera
Samsung s1030 will not retract lense and bleeps 3 times then no response - batteries are fully charged
Try hard reset . Remove the batteries and insert new batteries . Sometimes this may work
Another chance is that lens is struck
* Carefully inspect around it for dirt or debris
* If you see any dirt or debris around the lens, use canned air to gently blow it away
* After removing dirt and debris, turn the camera on and off
This should work.
Try this alternate solution (got information from HP )
  • Turn off the camera, if possible.
  • If an SD memory card is installed, remove the card.
  • Remove power from the camera as described below:
  1. If you are using only batteries for power, open the battery/memory card door and remove both batteries.
  2. If you are using only the AC power adapter, disconnect it from the camera.
  3. If you are using both batteries and the AC power adapter, remove both batteries and the power adapter.
  • Wait for 15 seconds. Then reinsert the batteries and close the battery/memory card door or reconnect the AC power adapter to the camera. If you are using both batteries and AC power, try each method separately.
  • Turn the camera on and off. If the lens does not retract correctly or the camera does not turn on,
You need to take to service center .
Thanks for using FIxya
SAM ANDERSON
Dec 09, 2008 | Samsung Cameras
Re-attach the power source flashing
I had the same problem. I took off the battery pack and wiped the it down with a kleenex as well as the socket in the camera where the battery pack connects to. This fixed the problem.
Oct 18, 2007 | Sony Handycam DCR-HC32 Mini DV Digital...
Camera Won't Turn On
have you tried plugging it to the wall AC? Use a reset button if there is one. Leave the camera with batteries out for a day or two. If nothing seems to have an effect take it to a repair shop to get a repair estimate, see if it's worth it. Good luck!
Jun 03, 2006 | Samsung Digimax 301 Digital Camera
Panasonic AG-HMC150 AVC Camcorder Logo
43 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
