Question about Dell Inspiron 1545 Notebook
Dell insperon 1545. When I press the power button the light comes on, the fan runs for a couple seconds and then shuts off. Doesn't matter on battery or AC. I have removed the hard drive and cd rom drive, same problem. When I remove the memory I get a repeating 2-beeps but it stays powered up. I have tried both memory modules by themselves sill no boot.
  • 320 Answers
Try to use other memory card instead of the one that is previously installed. Problem like that is caused by memory failure.
Posted on Nov 08, 2010
My dell inspiron 1545 won't start, I have pressed
removed your battery and charger then hold the power button for at least 10 seconds then replaced battery and charger.. good luck
Apr 08, 2012 | Dell Computers & Internet
Dell 1545 will not power up
SOUNDS LIKE A BAD MEMORY STICK
Dec 26, 2011 | Dell Inspiron 15 Laptop
Pressing power button results in power light and hard disk light coming on for a couple of seconds cpu fan spins for same length of time then fan stops lights go off few seconds later lights come back fan...
it seems that you have damage memory card replacing may fix a problem but its better for it that you bring it to a technician in order to check much better because the motehrboard may possible be the problem.
Jun 30, 2011 | Acer Aspire 4315 Notebook
I press my power button and the fan starts for a second and blue disk drive light flashes like it is loading but nothing comes up on the screen and it will shut off about -5 seconds after pressing the...
have a look on the bottom of the case for access panels, remove these and check the fans for dust build up, even if the dust doesn't look too bad, its worth cleaning. Also try to remove the fan to check between that and the heatsink, dust can build up there very much. This could cause the fan to be innefficient so could be an overheating problem causing your shutdown.
May 06, 2011 | Dell Vostro 2510 Laptop
I have a dell inspiron 1545.week before it showing time-of-date stopped. then I changed motherboard coin battery.now my laptop not booting up when I press start button the DELL logo come up on screen with...
hi
first off all open hdd screw and pulld hdd in laptop then check
if not stuck problems in hdd if stuck then check rams super drivewifi card and othere hardware
click yes for vote
Feb 22, 2011 | Dell Inspiron 1545 Notebook
Dell Inspiron 1525 laptop, no power light, battery light flash orange, wifi light flash blue and orange I bought the Dell Inspiron 1525 laptop in 2008. I use the laptop as a desktop, so I never plugged...
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
Mar 06, 2017 | Dell Inspiron 1525 Notebook
I have dell inspiron 1100 laptop, when i turn it on fan goes on for about 15 sec,with no screen, power lights and battery lights either, i can hear sound from HDD and DVD rom, but after 25 sec everything...
Could be loose battery pack.
A bad memory chip would do this as well. Sounds like your not getting power.
Try this,
Unplug it, remove battery, wait couple minutes, press and hold the power button for 5 full long seconds, wait couple minutes more, then put battery back in securely, then plug in, turn back on.
Mar 07, 2010 | Dell Inspiron 1100 Notebook
Facing problem with battery of Dell Inspiron 6400
1. Shut down the system, remove the battery and the Ac adapter from the computer.
2. Press the power on button for 10 seconds
3. Reinsert the battery
4. Power on the computer and as soon as you see the dell logo press the f2 key a couple of time
5. Using the up down arrow keys , go to the option that says battery info. If there is an error message listed kindly post it back
6. Otherwise shut down the computer reconnect the ac.adapter and check if the problem is solved
Also the battery has a diagnostic lights on it , remove the battery from the computer and press the button on the battery a set of lights would glow. If they are steady and come in a series the battery is good , If some lights are missing the battery is bad and may need replacement
Thanks
Proton
May 15, 2009 | Dell Inspiron 6400 Notebook
Dell Inspiron 1545 Notebook Logo
205 people viewed this question
Alun Cox
