Question about Kenmore 24032\24036 Top Load Washer
I have a Kenmore 800 series washer that won't fill with water, but will go thru the spin cycles if you set it manually, was working fine before except I thought it was using too much water on the auto sensing mode, what gives ?
  • 2 more comments
  • billw301 Nov 08, 2010
    Could you give more information on where these items are located and what has to be removed to get to them ?
    could you give more info on where these items are located and what has to be removed to get to them ?
  • billw301 Nov 09, 2010
    Kenmore 800 series washer will not fill with water, but works otherwise ?
    The machine was working fine as far as filling and draining, but just quit wanting to fill when you started the cycle on any setting. The height of the drain is over 36". Then machine is 1.5 years old , but has only been used for 2.5 months, so warranty is off.
    President:
  • 1,891 Answers
This could be a pressure sw . too ck remove the air tube and blow on the sw it should click . or use a ohm meter to ck it it has 3 wires going to is power in ond power out to valve when it gets full of water it shuts of water and turns on motor .. . the spin does not have anything to with fill & wash . but it does help for the diag of mach ( thanks ) hope this has helped mm feed back pls ..
Posted on Nov 08, 2010
  • dennis dodge Nov 09, 2010
    going back to the first problem ( " machine is using too much water on some cycle . ) the 800 models may need a syphon break installed on them to prevent the water from draining during the fill / if machine is draining the water out and filling it might take all day to do the wash. if your machine has a syphon break on the drain line it may be bad and need to replace . also the out let of drain should be 36" high to prevent this . and if lower it will require one . i hope this may help mm feed back pls ..
How do I check and replace the water level sensor on my Kenmore 80 Series Hvy Dty Washer?
Try eserviceinfo.com/index as per your 80 series. There are various downloads there that may help access the water level sensor which is most likely the problem.
Aug 08, 2014 | Kenmore Washing Machines
Kenmore Heavy Duty 80 Series Extra Capacity Plus Model# 92480200. The washer will begin to fill and will not stop filling regardless if water level setting is on low, medium or high and will overflow and...
The problem is the pressure switch has failed or the hose is plugged up, has a hole in it. These are usually inexpensive and are very easy to replace. Here is a video this will walk you thru testing and replacing a pressure switch. You can also enter your model # for diagrams and illustrations of your specific model. All parts come with installation instructions. Not all models are available.
Oct 30, 2010 | Kenmore Washing Machines
Our Kenmore Top Load Washer series 800 is not working properly. When you set the Control Cycle knob to start a normal load it agitates instead of filling up with water rinses instead of stopping the load...
We bought our Series 800 Washer (and dryer) in 08/2009. My wife has never been happy with them. It is off warranty now 10/5/2010. We have always had Kenmore... but she hates this set.
We are having the exact same problem with this washer. The current problem is on the regular cycle when it gets to the spin segment it does spin and all the water is removed HOWEVER just before it shut off it fills with rinse water.
I'll bet any money they are made in China. Looking for a solution on the web. Sears is no help.
Jul 03, 2010 | Washing Machines
Kenmore 80 Series washer wont spin or drain at end of cycle
POST ME THE MODEL NUMBER. AND ALWAYS POST MODEL NUMBERS WHEN NEEDING ASSISTANCE PLEASE:)))
Apr 17, 2009 | Washing Machines
Won't complete cycle, stops at rinse. and can't get hot water.
Are you on well water? turn off the cold water to the washer and clean the screen filter out. do not leave filter out.
the machine probably has a cold only final rinse so it won't work properly.
Mar 22, 2009 | Kenmore 24032\24036 Top Load Washer
We just purchased a top load Kenmore 800 washer machine. We have washed 2 loads of clothes and Now it has stopped filling up with water. It will not do it to wash or to rinse. We have gone thru the mannual...
The first thing seems to be the timer,or the water level switch. Try filling the washer with water by hand, if it starts to agitate after being filled its the timer, if not it is the water level switch, let me know if you need further assistance.
Mar 13, 2009 | Washing Machines
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Kenmore washer series 80, Clothes still soapy
If you are getting no water spray during the rinse cycle that would cause the soapy clothes issue.
Are you getting cold water during the wash/rinse cycles? If you have the machine set to warm/warm you may only be getting hot water while the final spin is calling for cold.
If you have cold water available then the timer is not calling for the water spray. The problem is either in the mixing valve or the timer.
Jan 10, 2009 | Kenmore 23822 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
460 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
