Question about Kenmore Washing Machines
I was given a kenmore, Lady kenmore ultra fabric care washer by my girlfriends mother. It worked fine, we oved it, all hookups seem to be correct, hot water is hot, cold is cold, I was able to do one load and now it won't stop drining no matter what I do, please help??
I had this same problem. I hired a repairman, which I highly recommend you do too. He found that the tub's base was corroded. The agitator wouldn't properly spin, and that had something to do with it ability to drain properly. My clothes were coming out sopping wet. He replaced the tub (at a cost of about $450), and then washer was as good as new. He said that washers and dryers that are made now aren't made nearly as well as these oldies. He said it should be in good working order now for the next 30 years.
Posted on Jan 16, 2011
Kenmore ultra fabric care II 80 series. Washer won't start on 10. But it will start on 4, every position past that and run thru the rest of the cycles fine
i WOULD SUSPECT THE TIMER CONTACT POINTS AT 10 ARE BURNT OR SEIZED YOU CAN TAKE APART AND CLEAN THE CONTACT POINTS IF U KNOW WHAT UR DOING.
Dec 19, 2016 | Kenmore Washing Machines
Lady kenmore washer
Locate contact point under the top section of washer near the lid
Dec 10, 2013 | Washing Machines
I have a Lady Kenmore Ultra Fabric Care Heavy Duty 90 series model # 1108281120. The drain for the fabric softner and bleach do not fill up and if you put the softer in it just drains out in the wash....
take out the draw where you fill the fluid to you will find that the fluid has built up into paste and is not letting the small valve to close properly happy cleaning eric
Dec 21, 2017 | Kenmore Washing Machines
I have a Lady Kenmore Ultra Fabric Care Heavy Duty 90 series top load washer that is about 20-25 years old and works very well. I think that an object has slid under the big thing in the middle of the...
if it is like the other you have to remove the top cover of the agitator cap with a small flat head screwdriver, then using a 7/16" socket and ratchet with an extension remove the bolt(right hand thread) and pull up the agitator.
good luck to you.
Feb 08, 2011 | Kenmore Washing Machines
Old Kenmore gas dryer Model 870692800 aka lady Kenmore Ultra fabric Care blower works, warm air enters chamber, but canister(?) holding wet clothes does not rotate. Ran a load of clothes earlier in day,...
if the tub will not agitate i would first take out the agitator, (there may be a bolt in the top holding it onto the transmission shaft), and check the top of the agitator to see if the splines are stripped. try to run the machine without the agitator on the shaft and see if it will agitate. if it is a case of the machine not spinning out the water after the wash cycle, you may have a burnt wire from the control magnet assy. at the bottom of the gearcase. there are 2 bars and 2 solenoids with 2 wires going to each one, these wires can break or burn off and the machine will not go into a spin mode. hope this helps.
Oct 15, 2009 | Kenmore Washing Machines
I have a Kenmore/Ultra Fabric Care IV - Heavy
Sounds like the machine is stopping to me, could be the off balance switch at the rear off the machine. You should know if its getting to the spin cycle.How wet are your clothes ? Hope this Helps.
Sep 15, 2009 | Washing Machines
only thing i can think of without being there and able to test parts is your door catch could be faulty
Aug 10, 2007 | Kenmore 659 Electric Dryer
Open Questions:
Washing Machines Logo
172 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
