Question about Frigidaire ATF6000ES Front Load Washer
FWT425RHSO FRIGIDAIRE CLOTHS WASHER
I HAVE POWER COMING IN BUT NOTHING WORKS. FIRST i THOUGHT IT WAS THE DOOR LATCH/SWITCH BUT IT WAS OK AND COIL WOULD PICK UP i THINK THE CONTROLES ARE SHOT DONT KNOW IF IT IS WORTH FIXIN? IT IS 8YR.OLD
  • 66 Answers
If you have changed your door lock then it will more than likly be your pcb or timer
Posted on Jun 15, 2008
I have a 2008 Lincoln town car the motor for the latch works but is not getting electricity, all the fuses are ok is there a fuse between the fuse box and the latch
Latch for what ? trunk lid ? Door ? The power door locks an the trunk lid are controlled by a electronic module . The luggage compartment lid release switch is a input to the driver door module . The driver door module sends a message over serial data network to the trunk module . If you know nothing about automotive electronics , your best bet would be to take to a qualified repair shop.
Feb 14, 2018 | Lincoln Cars & Trucks
Kenmore dishwasher will not start
The most probable cause is the door latch (or switches in the latch) are not working right, and the controller thinks the door is open, even though it is closed.
Aug 13, 2012 | Kenmore Dishwashers
E1 F5 code after self clean cycle. its been 12 hours and wont unlock and still says code
Hi.
E1 and F5 (F5-E1) means that the Self clean latch will not lock. The problem is usually fixed replacing the door latch. If the door latch is working, check wiring to door latch. The control module causing the error is not very common but possible. If the latch and wiring are OK, check control board.
Here troubleshooting from manual:
1. If door latched:
1. Disconnect power from unit.
2. Check wires and connectors from control to door switch, then from door switch to control. If no damage to wires and all connectors okay, proceed to step C.
3. Replace door switch.
4. Re-apply power.
5. Press and hold any key down for 1 minute to clear F5 failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
2. If door not latched:
2. Check wires and connectors from control to latch switch, then from latch switch to control. If no damage to wires and all connectors okay, proceed to step C.
3. Repeat steps A and B for door switch.
3. Measure door switch (door open = switch open small low voltage terminals). Replace switch if defective.
4. Measure latch switch (unlatch = switch open, CAUTION - oven light contacts are closed). Replace switch if defective.
5. If corrections are made in any step, reconnect power to control. Press and hold any key for 1 minute to clear R failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
6. If failure remains, disconnect power and replace control.
Here parts and diagrams: arrow_link.gif KERC507EAL1
Regards.
Ginko
Jun 18, 2011 | KitchenAid KERC507 Electric Kitchen Range
2002 passat door latch thinks it's open when it's closed
The switch is part of the loca assy. and is about $200. Try this first...
Open the driver’s door. With a screwdriver or equivalent trip the latch on the door 2 clicks so it is in the locked position, just under that finger get a can of Brakecleen and hose the snot out of it. I mean really firehouse it. As fast as it evaporates I still had it running out of the door drains. Be careful not to get cleaner on the plastic door panel, trust me take extra care. Open the outside door handle to release the latch, then open and shut the door for a while, like a few dozen times, to work the latch. Repeat as necessary. Follow up by shooting some PB Blaster, WD-40 or whatever light lube is handy. If this doesn’t work, give it might take a day or so to work free. If still nothing then the micro switch might actually be broken, but this usually does the trick
Jan 14, 2010 | 2002 Volkswagen Passat
Beeping driving me crazy
Ok, the first issue is the oven temp sensor. it is shorted. you will need to replace this device asap. Now, the second is is concerning the Self clean latch. it is not functioning and it is unable to be locked by the control(shorted). Use the procedure below to test this device.
1. If door latched:
4. Re-apply power.
May 29, 2009 | Whirlpool RBD305PR Electric Double Oven
Code fse1 comes up when a few minutes after pushing start to cle
F5 - E1 Self clean latch will not lock
1. If door latched:
  4. Re-apply power.
Apr 01, 2009 | Ovens
Frigidaire Dishwasher (model FDB1050REB0) Wash Light Flashing
Well, I've got a different problem. I need a control module!!!
BUT!
The flashing WASH light appears to indicate the door latch (switch) is not fully engaged. I proved that I mine which works, just doesn't pump out/drain water. If I unlatch the door and then press START, the WASH light blinks.
*WARNING* 120V ELECTRICAL CURRENT! ONLY ATTEMPT THIS IS YOU KNOW WHAT YOU ARE DOING!
The switch is located behind the control panel (5 screws from the inside.) The Hot (Black) AND Neutral (White) wires comes from the electrical input and pass through the switch. You can do a simple continuity check with the power disengaged to test the path through the switch and into the control module (pins 3 & 9m black and white).
Now... anyone have a Control Module (working) they want to give/sell to me so I don't have to go buy a new dishwasher? I just replaced the drain valve on mine :( If you do, you can send me a note vidioteic (at) gmail (dot) com
Happy Washing!
Feb 13, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
I get an error code on my Whirlpool RF362BXKW range. I have shut down the power to the unit, have cleaned the unit and the error code won't go away. None of the oven cooking options work with the error....
What I did was hit cancel and hit the unlock button. Then I leaned against the door a bit as I hit the lock and hit the self clean and start the lock check dissapeared. I hit lock again and nothing else and it started the cleaning process.
Apr 08, 2008 | Kitchen Ranges
Dishwasher doesn't run
If you turn on the dishwasher and nothing happens: 1) Be sure the power is on, the door is latched, and the control is turned on. Also make sure the appliance cord is plugged into the electrical receptacle under the sink (some are hardwired and don't come unplugged). If it can be unplugged, make sure the electrical receptacle is working (plug in a working appliance or a circuit tester). 2) If that doesn't solve the problem, the door switch, the timer, or the selector switch may be defective. To solve the problem, you may be able to adjust the door latch's strike slightly, using a screwdriver (turn off the power to the dishwasher at the electrical panel when working on it). 3) If that doesn't work, call an appliance repairperson.
Jan 18, 2006 | Hoover 24 in. DT999 Free-Standing...
Frigidaire ATF6000ES Front Load Washer Logo
132 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
