Question about Alesis MasterLink ML-9600
Hi, i had a problem when i switch on my Masterlink there are no power. I have already checked the cable and fuse but there seems to be no problem with it. What could it be the cause of the problem? The machine does not ON when i press the power switch button. I urgently need help. I'm from Singapore and I bought the machine from Sinemax Singapore. I do not want to send the machine for repair until i get advice from the experts. Your kind assistant is very much appreciated. Thanks & Best Regards Nizam Mobile: +65 98527897
  • 37 Answers
Send it to big dave in the USA, he can fix it.
he can fix anything.
dave
Posted on Jul 01, 2011
How to download the OS firmware?
Hi, I'm in the process of restoring a Masterlink, and have just done what you are trying to do. Go to this link:
http://www.alesis.com/masterlink
Read through the materials and then go into "Docs and Downloads" and there you will find the "System Software Update Guide", which explains how to determine which OS version you need based on your serial number, so you can create the ISO disc for the OS you need. I suggest you print it out for easy reference. Then download and unzip the OS files and create your Operating System ISO CD. The instructions are pretty clear so if you're methodical you should have no problems getting up and running soon. Have fun!
May 05, 2014 | Alesis MasterLink ML-9600
Masterlink shut down during a CD playback and won't power up at all. No lights, no sound, nothing.
You need a competent tech to look at the possibility that the power supply has failed - seems the most likely explanation
Apr 04, 2014 | Alesis MasterLink ML-9600
Recording levels are low
There's no record level adjustment on the Masterlink. Increase the output level of your mixer, or add a variable level preamplifier between the mixer and the Masterlink.
Or, use the level adjustment on the Masterlink once the recording has been done, and before you write it to CD, either with level control or DSP normalisation
May 23, 2013 | Alesis MasterLink ML-9600
Theres no power in my turntable. upon opening it, the fuse looks good, and everything seems at first glace to be connected. but it does not turn on when plugged in.
hi,
check the power cable first . then check the on off switch. also check the transformer. do one more thing remove the fuse from the holder and then refix it. may be chance for contact problem.
ok
Dec 31, 2010 | Technics SL-1200MK2 Turntable
Upon turning on our Masterlink, it read "LOAD OS".
if you are computer savy, you can disassemble the masterlink and test the cd drive in another computer. if it works, check the power connector to the cd drive. switch it with the hd connector to see if it fires up.
keep use posted.
bcssr@charter.net
dave
Apr 14, 2009 | Alesis MasterLink ML-9600
Alesis Masterlink ML 9600 won't power up.
After reviewing the repair and owners manuals. I have come to the conclusion that there is a short in the power supply board. Your drives should be fine. I don't know off hand how expensive it is to fix in your area. I would say approx $200
Jan 19, 2009 | Alesis MasterLink ML-9600
Alesis ML 9600
make sure that you have a good power source and cables first.
it seems that a filter cap is not doing what it is supposed to do. which one, i don't know.
you could try to format the HD and update the latest firmware/OS and see if that does the trick. next , if you have new/er harddrive, you could switch it out.
keep us posted
dave
Jul 24, 2008 | Alesis MasterLink ML-9600
CD RESET FAILURE
The CD ERROR 277..can be fixed if u make sure the internal cable connection between the Hard disk and the writer are not mixed up and are well fitted...
Jul 11, 2008 | Alesis MasterLink ML-9600
Masterlink
I tried the "pressing play/pause and record simultaneously" during power
up, and it worked.....dunno for how long. The unit still makes strange
noises occasionally and doesn't seem completely healthy, but it's up
and I'm copying files that I want to save. We'll see.
Jun 12, 2008 | Alesis MasterLink ML-9600
Alesis MasterLink ML-9600 Logo
51 people viewed this question
Top Alesis Televison & Video Experts
Are you an Alesis Televison and Video Expert? Answer questions, earn points and help others
