How do I find my IP address? trying to connect to xbox live and the xbox does not connect. needs address.
  • 240 Answers
You can get your IP address a couple of ways.
I prefer going through the command prompt.
Click on your start menu and go to run. For Vista and 7 there may not be a run box so use the search field just below "all programs". Type in CMD and then press the enter key.
This is the command prompt. Type in "ipconfig" and press the enter key. Look for IP address or IP V4 address. You can also look for default gateway to get the network IP address.
DO NOT USE THE SAME IP ADDRESS AS YOUR COMPUTER FOR THE XBOX. You need to use a similar address but not the same. For example, if your computer's IP address ends in "104" then use the same IP address for your xbox but use "150" at the end instead.
Thanks,
Pat
Posted on Nov 08, 2010
  • 320 Answers
To get your IP address, click start and click control panel. Click network and internet connections and click network connections. Right click your local area connection and click status. Click support to see your IP address.
I got a Motorola wired modem and it dosn't let me play xbox live why?
you may have to open a port that you xbox can use to connect to xbox live
    • 1 Connect only your Xbox and computer to the Internet. Disconnect all other devices. This is done to easily determine the Xbox's IP address, which is used in the Port Forwarding process.
    • 2 Open the Windows Command Prompt from the Start Menu. Click "Start > Run...," then type in "cmd" and hit "OK."
    • 3 Enter "ipconfig" n the command prompt. A list of IP addresses pop ups. Write down the IP address of your computer.
    • 4 Open your router setup utility through a web browser. Use the given directions from your router manufacturer to do so. Generally, the configuration page is opened by inputting the router IP address into the URL in the following format: http://123.456.7.8/ (where the IP Address number is unique to the router manufacturer).
    • 5 Open the "DCHP Client List" section of the router setup utility. This lists the devices currently connected to the Internet through the router, which is your computer and Xbox. Write down your Xbox's IP address (in this case, the one that is not your computer's IP address).
    • 6 Navigate to the "Virtual Servers" or "Port Forwarding" menu in your router setup utility. Most manufacturers have a side menu on their router setup utility, which is generally a section under your "Firewall" settings.
    • 7 Input the following port numbers and your Xbox's IP address into your router's port forwarding configuration:
      TCP 80
      UDP 88
      UDP 3074
      TCP 3074
      UDP 53
      TCP 53
      Placing these numbers in the port forwarding menu opens up the required ports that your Xbox needs to connect to the Xbox LIVE network. Save this configuration.
    • 8 Start up Xbox LIVE to check your connection. If you have no problem connecting, then you have successfully forwarded the required ports.
Jun 04, 2011 | Video Game Consoles & Games
My Zonet ZSR4134WE Wireless-N router doesn't connect to live. I've checked the MTU setting and everything. It works perfectly, until it gets to the "Xbox Live" part of the test, then it fails. Please help.
you need to open the ports on your router for xbox ports are TCP 88 UDP 88 UDP 3074 TCP 3074 UDP 53 TCP 53
first connect the xbox to the network and get the ip address (like 192.168.x.x) and then use the computer and login to router setup page and under firewall open these ports for the ip address of xbox . If you find a DMZ there , then enable it for XBOX ip address and reboot the router. ** imp: try to make a static ip address on xbox so when you restart the xbox teh ip address should not change -
to check what is the ip address provided from you router :- go command prompt (start ->run- > type cmd and hit enter) a black screen(command) type ipconfig you will find ip address of computer , so you can set the ip address of xbox like that -but just make the last number different (like ip address on computer 192.168.2.5 then make ip address of xbox to 192.168.2.6) perform this will help .. its all about the ports but be sure with ip address
Oct 01, 2010 | Zonet ZSR4134WE Wireless Router
I am setting up my Xbox live. I set up the DNS server and IP address. And a few other things but it won't connect to live. It will connect to internet though. It says it doesn't recognize Xbox live DNS or...
The DNS is your routers ip address. the secondary DNS is 0.0.0.0 or thats what mine was
you can go to your routers2_bing.gif website and enter it manually. Type 192.168.1.1 this might be it or try 192.168.2.1 or 192.168.1.100
when it shows your routers info write it down and then put it in your xbox's network by entering it manually. btw the secondary DNS is just 0.0.0.0 if it doesn't give you two. the gateway is just your routers ip address.
what else you can do is do port forwarding.
But the xbox is not a static ip address so it'll change. what you can do is when it says to put your ip address in your xbox put all the numbers the same as the routers ip address BUT DON'T USE THE SAME LAST NUMBER! so like if your routers ip address is 192.168.1.1 you can use 192.168.1.23 i use 192.168.2.15 but you may not have the 2 in yours.
http://portforward.com/english/applications/port_forwarding/XboxLive360/XboxLive360index.htm
a website that'll help
http://support.microsoft.com/kb/908874
list of ports you have to open
any other ?'s email me at mbish1993@yahoo.com
Nov 14, 2009 | Microsoft Xbox 360 Console
XBOX 360 LIVE Won't Connect
Is the modem also a router?
You need to login to the IP address of your device... if the modem is only a modem, try going to your own IP address.
http://whatismyip.com will help you find it. This may bring you into the settings of the modem. If it is a router as well, then you will need to go to your default gateway's IP address.
Go to start, then run.
Type cmd, then click ok.
type 'ipconfig' and hit enter. Look for your Default Gateway
type that ip into your browser (IE/Firefox/whatever) and login
adjust the MTU to recommended settings. If its at 1500, try 1364 of 1492
Jun 16, 2009 | Microsoft Xbox 360 Arcade
Failed Ip adress for xbox live
First i want to know how is your xbox 360 connected to the internet? For example ( Modem Connection?, Router Connection?, Or Wireless Connection?
Here are some steps that you need to try:
1. Turn off your cosole wait for 20 seconds and then turn it back on, then test your xbox live connection
2. Go to your network settings
3. Select restore to factory defaults and test your xbox live connection
Apr 03, 2009 | Microsoft Xbox 360 Console
Can't connect with network
if u dont hav e a router that is ur problem. to get ur xbox 360 to connect to vista media center you cannot connect an ethernet cord directly to ur 360, u must have ur computer hooked to a router with one ethernet cord and a whole different ethernet cord connecting to the same router the computers hooked up to. after you do that go to ur vista media center, turn active sharing on, make sure your router is connected to the internet. then go to ur xbox 360 and follow the on screen instruction from the the connect to media center screen.
if your wanting to connect to xbox live and stuff like that, and u enter ur ip address and security information and it tells u that the ip adress u entered is already in use by another device, and that ur xbox 360 needs to be assigned one, do this: simply go to were u put in ur ip address and set it to get the address automaticly (or in other words choose automatic). then go to test connection (ur router should automaticly assign ur xbox 360 an ip address) and ur router should connect to the internet. if it connects to the internet but not xbox live then u have not yet sign up for an xbox live account.
by the way when u make an xbox live account please send me a friend request. my xboxc live account name is: ghdude22
glad i could help!!! :3
Feb 06, 2009 | Microsoft Xbox 360 Controller
Ip address failed
I think you need to ring your internet provider and they will enable xbox live from their side. Its fairly simple and they will know what your talking about.
Oct 20, 2008 | Microsoft Xbox 360 Console
IP address
Try this fix:
http://xbox360help.blogspot.com/2007/04/ip-failed-xbox-360-live-test.html
Apr 13, 2008 | Microsoft Xbox 360 Console
Get go to xbox live
For some reason everyone has the same problem buy the Xbox 360 wireless kit and should work but for now you might as well just wait untill get its fixed
Dec 30, 2007 | Microsoft Xbox 360 Console
Wireless connection of xbox 360
you can find your I.P adress on the PC you use at home that is connected to the wireless modem.
if not theres an option on the xbox 360 to find the I.P automaticly try that!
hope this helps please rate me
Regards Grant
Nov 25, 2007 | Microsoft Xbox 360 Console
Computers & Internet Logo
97 people viewed this question
David Payne
David Payne
