Question about Mitsubishi WD-52525 52" Rear Projection HDTV
My lamp on my WD52527 is out and have lamp ware is it lowkated
  • 616 Answers
Its should be on the front right under the speaker cover, or rear left side of the tv. it is labeled "lamp access panel""
Posted on Nov 08, 2010
How to replace the projection bulb?
LAMP DOOR LOCATED IN THE BACK ON THE RIGHT HAND SIDE LOOKING FROM THE BACK. IT IS HELD ON BY 2 SCREWS THE LAMP IS SET BACK IN THE TV ABOUT 5 INCHES FROM THE LAMP DOOR SUGGEST A LONG FLAT HEAD SCREWDRIVER TO LOOSEN THE LAMP. INSERT NEW LAMP AND PUT LAMP DOOR BACK ON. THERE ARE INSTRUCTIONS IN YOUR OWNERS MANUAL.
Dec 16, 2010 | Mitsubishi WD52527 52" Projection HDTV
Lamp light is red
pull lamp from unit and investigate it for integrity
Jul 07, 2009 | Mitsubishi WD52527 52" Projection HDTV
Burnt out lamps
There is only one lamp need. If you keep your user's manual refer to ...how to replace the lamp. (I recommend to use an original mitsubishi lamp) process is kind or smooth path to the user, But if you are not feeling comfortable replacing it a serviceman can give you an estimate on it.
Apr 22, 2009 | Mitsubishi WD52527 52" Projection HDTV
Lamp light coming on my wd52527 when lamp was just replaced tv saying lamp is about to exceded its life
There is a reset of thew lamp timer which should have been done at time of replacement. It is usually the combination of holding 2 or 3 buttons at the same time. The manufacturer usually has it posted on the web or the instructions with the lamp should have the procedure....
Last resort is call the manufacturer tech line
Apr 18, 2009 | Televison & Video
No picture lamp light on
You can find the lamp acces door on the lower back left side. You will have two philips head screw to remove and you will see the lamp. Remove it and look at it. It will probably be shattered. There is also a filter right beside the access door. Be sure to clean that.
You owners manual can provide you with info to ordered a lamp and have it sent to your home
Nov 23, 2008 | Mitsubishi WD52527 52" Projection HDTV
Mitsubishi WD52527 lamp light
Replace the lamp, model 915P028010.  There is a lamp door on the back left bottom of the set (while looking at it from the back).  Take off the door (two screws) and then take off the two screws holding the lamp in place and pull on the handle.  Replace the lamp the same way.  Then make sure to clean the air filters (below the lamp, two screws; and bottom right).  If the set gets too hot it may destroy the set and/or the lamp.  Also, don't turn the set on and off again within a few moments.  It will destroy the lamp.  Take it from someone who had the same problem, keep the filters clean by cleaning at least once every couple of months....Dave
Sep 20, 2007 | Mitsubishi WD52527 52" Projection HDTV
Lamp problem
we will need a little more info from you I'm afraid, does this TV set have any sound, is the set dead, no picture or sound?
Mar 28, 2007 | Mitsubishi WD52527 52" Projection HDTV
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
221 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
