Question about Compaq Presario Notebook
I was working on a paper and my laptop needed charged so i plugged it in and it showed it was charging so i continued to type. A few hours later my laptop said it needed charged again though i was still plugged in. Then my Compaq Presario cq61-313US shut off and i havnt been able to turn it on since. The only thing that happens when i press the power button is the light flashing a couple of times. I just want it to turn on again, please help!
  • 2,229 Answers
When this happens, you may be dealing with a power adapter that has gone bad. Check to see if it's putting out the required voltage ~18-19 volts.
You could be dealing with a broken DC-in jack. This can be fixed, but with difficulty (it involves soldering on the motherboard.
You might have to replace the motherboard. First try to start the computer with the adapter connected, but the batter taken out. If it starts and works, then it's a bad battery.
Posted on Nov 08, 2010
  • alyssa12jb Nov 08, 2010
    the computer does not start up with just the adapter plugged in. how would i check to make sure its putting out the correct voltage?
  • Art Ellison
    Art Ellison Nov 08, 2010
    You'll need a voltmeter. Most adapters have the positive on the inside and negative on the outside of the part that plugs into your computer.
    Sounding like your adapter is bad from your response.
What's wrong with my laptop? Screen goes black when plugged in
This is known problem with chip that regulates battery charging, and need to be fixed by experienced laptop technician.
Jul 21, 2013 | Alienware PC Systems Computers & Internet
I have new laptop how many hour battery charge first time
First Time Charging
  • The amount of time it takes for your battery to fully charge depends on many factors, like your battery type and operating system. Many newer laptops will charge in 15 to 20 minutes, while others can take a few hours.
    When you're charging your battery for the first time, charge it fully before using your laptop. You may have to go through a battery cycle a couple times before your battery begins performing at its maximum capability. To do this, charge your battery fully, let it discharge to about five percent, and then fully charge it again
  • Read more: For How Long Should One Charge a New Laptop Battery? ' eHow.com http://www.ehow.com/way_5261076_long-charge-new-laptop-battery.html#ixzz1GTAFQEz9
    Mar 13, 2011 | Acer Computers & Internet
    I bought acer aspire AO531h one few months back. For last few weeks its battery not charging.With AC(plugged in),notification icon says"plugged in,charging",however "0% available"even...
    Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
    Feb 04, 2011 | Computers & Internet
    I use an advent 4211c,it only works while on AC power and shuts off immediately i disconnect.it has never shown me this problem before and while i switch it on,it shows me battery is fully charge.I tried...
    The problem is your battery pack. Just replace the battery pack the you have with a new one. But before using it, you need to recharge the new battery for 8 ~ 12hrs continues charging. After charging you can now use you laptop.
    Jul 19, 2010 | Advent 4211c Notebook
    I bought a asus refurbished laptop, what should I do about charging a battery,charge it for eight hours without turning on the laptop??
    A battery will charge as you use it . Go aheead and plug it in go about your laptop use as normal it does not need be off to charge the laptop any faster
    Its using AC power to run and will still charge the battery
    IF it does nto charge in a few hours it could be a weak battery
    Try this first beofe you bring it to a service shop EBAY sells every type of battery ever made & Cheap too ! but check for warranty in EBAY bought battery look for return 100 percent guarantee on battery sales
    Jun 15, 2010 | ASUS Computers & Internet
    Borrowed a flip video to tape daughters
    camcorders don't generally charge from pc's as the voltage is much higher.they won't switch on when the battery is low or i should below a certain voltage..try charging it using its charger it will probably be fine .good luck farr64[colin]
    Dec 29, 2009 | Pure Digital Flip Video Ultra Camcorder
    I own a 1 year old Dell Studio 1535. Its original battery died, so I purchased a generic one online. When I turned on the laptop with the battery only (not plugged in), it said battery not recognized,but...
    A generic Battery should Work fine.
    Try going To my computer/Control Panel/Power options.
    You should find a battery Icon, for the Battery if it,s recognised in there. select ( show on Desktop ) And refresh The Battery.
    New Batteries usually require to be fully charged. Then Discharged ( no-Mains Power ) for the first 3-4 Charges. So that the Computers power Management System, Can guage the Capacity Of The battery Inserted.
    Mike @ compurepair.
    Nov 06, 2009 | Dell Inspiron 1525 Notebook
    We purchased a Rascal 300 two months ago that worked just fine. We seen proof that new batteries had just been purchased. It has a built in charger and we have kept the batteries charged. The charger now...
    Here's a link for the owners manual for the 300 model. Click on it and it will open as a PDF document that you can print. http://www.rascalscooters.com/manuals/300_manual.pdf
    The ammeter back in the trunk should be registering when you plug the scooter in. If it isn't, this doesn't mean that it isn't charging as the meter itself may be bad. Put it on charge for a few hours and see if the "fuel guage" on the top of the tiller comes up to full. If it does, than your charger is okay and you just need to ignore the ammeter not working until it doesn't charge at all anymore, then the charger is bad. Note too, that later on when the batteries get weak and you can only go a little ways, that it still means your charger is okay, batteries not. Even bad batteries well show a full charge, but they won't take you far at all. If the batteries don't show a full charge after a few hours, then you need to replace the onboard charger.
    Good luck
    Jul 10, 2009 | Pride New Mobility Legend 4 Wheel Scooter
    Power light on the adapter but no power going into the laptop.
    BECAREFUL because if its under warranty your okay, if not be prepared to shell out big bucks . the opening on te computer , where the plug connects is the problem, alittle solder and its fixed one day job did that type of repairs many times freddiemccly@yahoo.com
    Jun 03, 2009 | Computers & Internet
    Ds lite ac wall charger
    When you first get the DS it will have a bit if charge on it but only a few hours worth. When the DS charges it usally comes up with a orange/red ish light then that goes out about a few hours later when its charged. ad if you want to chek if it is charging correcly turn the DS on whilst it is charging and the little battery simble in the top right corner should show the battery carging.
    Nov 30, 2007 | Nintendo DS Lite Console
    Compaq Presario Notebook Logo
    167 people viewed this question
    Top Compaq Computers & Internet Experts
    pankaj rautela
    pankaj rautela
    Alun Cox
    Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
