Question about Brother MFC-465CN InkJet Printer
465CN only prints blank pages - Brother MFC-465CN InkJet Printer
  • 240 Answers
If the machine only prints blank pages it is because the print head is blocked. Press the "ink" button on the machine and perform up to a maximum of 5 cleanings. If this fails then call Brother at 1-877-276-8437 or write them an e-mail at support@brother.ca
There might be a problem with your print head. If you get in touch with them they can check your serial number and if it is within the warranty period they will send you a replacement machine. They off free tech support for life so even if they can't replace the machine, calling them or emailing them is free.
Thanks,
Pat
Posted on Nov 08, 2010
Mfc465cn-cant print test page,error PRINTER BUSY
I suggest You Go to Official Brother Printer Page For You Brother Printer Problem On Below Brother forum URL Link: How do print network configuration page Brother In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On : Brother Printer Support
Jan 22, 2014 | Brother Any 8 Inks Mfc-465cn Mfc465cn...
I have not been using the Brother MFC 465CN printer for a while. Bought and installed new cartridges, cleaned the print head several times (from the printer menu option). But, nothing is getting printed....
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
May 24, 2011 | Brother MFC-465CN InkJet Printer
HOW DO I PRINT ENVELOPES ON A BROTHER MFC-465CN PRINTER? SCREEN TELLS ME THERE IS A PAPER JAM WHEN THERE'S ONLY ONE ENVELOPE IN THE TRAY.
my brother mfc 7860 tells me i have a jam when i print envelopes only- there is no jam and will print the next 'page' fine- have to turn it on and off 4-5 times to get it to print one- any ideas anyone???
Aug 11, 2010 | Brother MFC-465CN InkJet Printer
My brother mfc 465CN wont print black only color
Have you tried cleaning the print head? Find the instructions in the troubleshooting and maintainance section of the manual here http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_465cn_EN_1269.PDF
Jun 04, 2010 | Brother MFC-465CN InkJet Printer
I have a Brother MFC 465CN and cannot get the black ink to print. I have cleaned it several times, and am quite irritated! If i print a page from my computer, the colours come out fine, but not the...
Another user here suggested that you change the Media Type in Printing Preferences to 'Inkjet Paper' instead of 'Plain Paper' and this worked for me. Of course I don't know if it's pulling from the black nozzle or not, but I do get black now.
Dec 26, 2009 | Brother MFC-465CN InkJet Printer
How can I delete the memory on a brother mfc-465cn printer fax machine? It will not receive faxes due to this
Review page 65 in your manual. Changing the "Advanced Fax Operations:"
If received faxes are left in your machine's
memory when you change the Advanced Fax
Operations, the LCD will ask you one of the
following questions:
Erase All Fax?
Yes - Press 1
No - Press 2
Print All Fax?
Yes - Press 1
No - Press 2
• If you press 1, faxes in the memory will
be erased or printed before the setting
changes. If a backup copy has already
been printed it will not be printed again.
• If you press 2, faxes in the memory will
not be erased or printed and the setting
will be unchanged.
Dec 11, 2009 | Brother MFC-465CN InkJet Printer
Brother mfc-465cn always restars
Not sure of the exact problem, but try a reset on it. Press Menu, *, 2, 8, 6, 4 within 2 seconds to get into service mode. Enter 91 to do a reset then 99 to exit. See if that helps and post here!
Nov 29, 2008 | Brother MFC-465CN InkJet Printer
Brother mfc 465cn printer
If you remove the empty cartridge, you will see a small window on the egde that plugs into the printer, in the center. This is where the printer optically scans for ink levels. On the empty color cart, you can try covering that raised spline with electrical tape or by coloring it with a black permanent marker. That should fool the sensor into thinking your ink is full.
Oct 31, 2008 | Brother MFC-465CN InkJet Printer
My Brother MFC-465CN is printing text with alignment off and double text.
My Brother printer MFC-465cn is doing the same thing. I have workaround / worked-around it by disabling bi-directional printing. Then print is clear. It's as if the head is shifting an irregular amount on the opposite direction, like the head is loose.
Same for copies. If I use the PC interface to make copies, I can set the copy printing to be mono-directional, then copies are clear.
Sep 05, 2008 | Brother MFC-465CN InkJet Printer
Printer problem
check your ink level your most likely out of ink. make suer your printer is selected as the default printer in orinter settings from control pannel.run a printer head clean up
Mar 09, 2008 | Computers & Internet
Brother MFC-465CN InkJet Printer Logo
637 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
