Question about Whirlpool Refrigerators
Plastic part on bottom on freezer door broke and the door doesn't open or shut very well.
    Problem Solver:
  • 9 Answers
The plastic kick panel here is easily damaged, but you may be able to loosen it and press it downwards or bend it down with your hands. That should relieve the panel from fouling the door of the freezer.
Posted on Nov 08, 2010
WHIRL POOL STAINLESS STEEL FRENCH DOOR- BOTTOM FREEZER MODEL NUMBER GI5FSAXVY
You should be able to buy replacement stripping at any local hardware and furniture store.
Sep 16, 2013 | Whirlpool GI5FSAXVY Stainless Steel ...
Hotpoint fridge freezer door not shutting
Adjust the feet at the bottom or the hinges if that doesn't work check your gasket and the white plastic washer on the hinge
Oct 23, 2011 | Hotpoint FFA70 Bottom Freezer Refrigerator
I have the bottom freezer w/2 doors up top....light inside will not go off and has started to melt some of the plastic pieces. How do you remove the light bulbs so the darn thing doesn't burn...
There should be a light switch inside each compartment, depress them with the door open one at a time, locate the bad switch and disconnect it. You can remove the bulbs too. Most of the problems with bottom freezer are the door, they seem to not get closed properly and they get heavily frosted, once frosted they seem not to close correctly and cause the lights to remain on.
I would look for the problem with the door closing or the door switch failing.
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Aug 28, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
Freezer door opening when refrigerator door closes
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
Jan 10, 2010 | Amana ABB1927DE Bottom Freezer...
Right side door does not close unless you push it closed with your hand
Part 11 on this diagram is your door closer http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5170924&diagram_id=1335988#d1335988
Nov 06, 2009 | Maytag MFD2560HES Bottom Freezer French...
Freezer door will not stay shut is their a replacement for the maginetic strip bottom freezer small
Oct 21, 2009 | GE Refrigerators
Re: danby upright freezer 20.1 cubic ft., model #
Oct 13, 2009 | Freezers
Bottom freezer popping open on its own
Sep 21, 2009 | Refrigerators
Freezer Door Popping Open
Look at the bottom of the freezer door, there is a little plastic stopper there. It may be worn out or broken. When you close the door this is what holds it there. Start there first.
Sgt 48
Jun 17, 2008 | LG LRSC-26922 Side by Side Refrigerator
Refrigerators Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
