Question about LG WM1814CW Front Load Washer
My LG washer shoes OE and I don't know what to do??
  • 18 Answers
If I'm not mistaken this is a drain issue so check to make sure nothing has your drain hose kinked or clogged. There is also a drain filter that you need to check and clean if needed. There is a small door cover on the bottom fron of the washer. First pull the tube out a little and hold it over a container then remove the cap. This will drain the pump and when no more water comes out you can remove the drain filter by turning the cap thats next to the tube you just drained. Sometimes there is still a little water left so you may have to clean up a little but not much. Clean the filter if needed and you can also look in the pipe to see if any debris was left in the pipe. Place everything back and this should get you back to doing more laundry.
Posted on Nov 08, 2010
I"m getting the OE signal.
Here is a tip that I wrote that gives more detail about how to fix the OE codeon LG washers....
LG Washing Machine OE Error Code
heatman101
Aug 12, 2011 | LG WM2277H Front Load Washer
My tromm LG front load washer is flashing OE, what is it.
heatman101
Jul 19, 2011 | LG Washing Machines
Have an LG washer displaying an OE code what could be the problem
An OE error code means that the washer is not draining properly. Pull the filter out at the bottom left corner to make sure that the filter is not plugged with debris. Read your manual before pulling the filter out so you don't flood your room.
Good luck.
May 28, 2011 | LG WM-1832C Front Load Washer
The washer is displaying an OE. How do I fix this?
Here is a tip that I wrote that gives more detail about how to fix the OE code on LG washers....
heatman101
Sep 03, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My lg washer will not spin out it keeps flashing OE no matter what i do
heatman101
Sep 02, 2010 | LG WM-1832C Front Load Washer
My washer isn't working the washer is an LG TROM WM2277HB the washer shows OC I don't know what that means
Hi dear.As I know there is a OE code on LG washers,if it's Check the followings.OE is drain fault.Check your machine filter there must be blockage(Coin,pin,fluff etc.)clean it.Also check for any kink on drain hose.I hope that helps.Thanks.
Aug 28, 2010 | LG WM-2277HW Front Load Washer
Lg washer oe error
On LG washing machines, the OE flashing code means there is a drainage problem. hope that helped.
Please Rate Me
George
Apr 28, 2009 | LG WM-2277HW Front Load Washer
LG wm1814cw washer
No, there is no access to the drain pump other than by removing the front panel to get to it.  It is a job that can be done but you will need to spend some time to disassemble the machine to get to it.
Sep 04, 2008 | LG WM1812C Front Load Washer
LG WM1814CW Front Load Washer Logo
182 people viewed this question
Top LG Washing Machines Experts
Marvin
Marvin
jimorris77
Paul
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
