Question about Lexmark C530dn Laser Printer
Service 960 memory error- r for my Lexmark C532n printer
  • 320 Answers
A 960 RAM MEMORY FAILURE message indicates a failure of the RAM MEMORY that is soldered onto the printer's main controller/system board.
If the printer is displaying a 960 memory error.
1. Power off the printer.
2. If you have any extra memory SIMMs or code SIMMs installed in the printer, remove them.
3. Power on the printer.
4. If the 960 error continues, the main controller/system board will probably need to be replaced.
5. If the 960 error does not return, try printing a few documents.
6. If these documents print correctly, the cause of the 960 memory error is probably one of the SIMMs you just removed.
To confirm this, do the following:
1. Turn off the printer and reinstall each SIMM one at a time.
2. After you install each memory card, power the printer back on and try printing. If the error returns as soon as you install a particular SIMM, that SIMM is probably the cause of the error message.
Posted on Nov 08, 2010
960 memory error
The RAM soldered on card is bad. You need to replace the system
card.
Nov 14, 2012 | Lexmark C532n Color Laser Printer
I have a c532n printer and am getting an error960 service
This error indicates that the system board's on-board memory has failed.Try to power the printer off and wait 15 seconds. Then power the printer back on.
If this doesn't resolve the issue, I suggest you contact Lexmark Technical Support.
Aug 24, 2011 | Lexmark C532n Color Laser Printer
960 service memory error-a lexmark c534dn what is wrong how to fix?? Gloria
The printer memory is failing. RAM soldered on the system board is bad. It would be best if you contact Lexmark Technical Support for proper assistance.
Jun 14, 2011 | Lexmark C534dn Color Laser Printer
960 service memory error how do I solve the problem on a Lexmark C534?
Theprinter memory is failing. RAM soldered on the system board is bad. It would bebest if you contact Lexmark Technical Support for proper assistance.
Mar 29, 2011 | Lexmark C534dn Color Laser Printer
Lexmark c532n no screen? Is there a fix for the screen or just has to be replaced?
Turn the printer off, wait about 10 seconds, and then turn the printer back on. If Performing Self Test and Ready do not appear, turn the printer off and contact Lexmark Technical Support.
Mar 04, 2011 | Lexmark C532n Color Laser Printer
I got the error message on my Lexmark C532n 200.26 and 200.16, there is no paper jammed, the Lexmark technician asked me to change the paper pick up roller which we did, but we are still getting the error...
The 200.16 jam indicates that the input sensor was covered when the printer was powered on or reset, or a cover was opened/closed.
You may also check the following:
1. The paper being used is within specification and has been loaded correctly.
2. Any previous jams have been completely removed.
3. The printing environment is within acceptable temperature and humidity ranges.
4. If the tray was overfilled or a paper jam occurred, sheets of paper may have come off the media stack.
5. If you don
Feb 01, 2011 | Lexmark C532n Color Laser Printer
960 service memory error - a
The error indicates that the system board's on-board memory has failed. This usually requires a service call but you can try to turn off the printer, then turn on after 15 seconds. If the problem continues, I strongly suggest you contact Lexmark technical support or an authorized service provider for assistance. You may need to know your printer's model type and the serial number when calling for service. Thanks.
Sep 10, 2010 | Lexmark C530dn Laser Printer
Lexmark c532n prints smudges on page
The problem could be caused by the photoconductor units. Try to swap the affected photoconductor units (like swap the magenta with black and cyan with yellow). If problem still occurs, then the photoconductors need replacement. I suggest you contact Lexmark Technical Support for assistance. Thanks
Jul 26, 2010 | Lexmark C532n Color Laser Printer
Display is blank (C532N) I have two different diagnosis from Lexmark - one says replace main board, other says replace display. Anyone else have this problem?
I talked to Lexmark tech support they say We should replcae the display. Anyone knows how to clear the red LED error without having the view of the display?
Jul 30, 2009 | Lexmark C532n Color Laser Printer
Lexmark C530dn Laser Printer Logo
4,343 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
