Question about Samsung HC-P4241W 42" Rear Projection HDTV-Ready Television
How do i reset convergence on rear projection samsung hx-p4241w please?
Hi
i had convergence issues on my tv and used the menu choice to fix the problem which did little to fix the issue.
then i used the mute-1-8-3 method and 7 8 9 to select R G B, 4 to select moving part a line, full line or the whole matrix. which was nearly perfect.
however the "matix" is not perfect and in little areas is just a touch wavey, in one corner very wavey.
is there a way i can set one colour of the "matrix" back to factory setting and then move the blue and red to fit it so everything is symetrical and straight?
many thanks
  • musicsphere Jan 18, 2009
    I keep trying to manually converge mine as well with the method as mentioned above.  I can get the color grid lined up but in 4:3 Aspect Ratio my picture is bowed all over the place.  I can watch a movie in one of the cinema mode but text is missing and pieces of the film are not visible.  How can I get that grid unbowed?  The only thing I can think of is to just sit there and tweak the grid for hours until its better.
techman
  • 3130 Answers
SOURCE: Samsung HCM5525W TV red blue outlines on images
The Samsung has bad convergence IC's most likly. This should be repair ONLY by a trained technician as a TV set is not a place to experiment or tinker with because of the extremly high voltage inside. This repair should cost you in the range of 250 to 400 bucks . Good Luck
Posted on Jul 31, 2006
SOURCE: samsung rear projicton tv 42 inch aa68-50523a
how do i converge
Posted on Dec 05, 2008
SOURCE: Samsung HC-P4241W Convergance problem
press mute 183, if it isn't 183 it's 138.   You will see a large grid which you get the fun of adjusting, it's tedious as all get out! Enjoy!
Posted on Jan 18, 2009
  • 3 Answers
SOURCE: Blue ghosting and can't manually adjust Blue convergence
You will need to replace the convergence IC
Posted on Feb 06, 2009
  • 4234 Answers
SOURCE: convergence
This is an indication that the STK is bad. The PC board should be marked to indicate which one if for the green.
Dan
Posted on Apr 13, 2009
Testimonial: "Thank you for your help."
When i turned on my Hc-p4241w i smelled a burning smell then the color started looking 3d, i took a flashlight & looked through the left side of the tv and saw a orange glowing inside and i shut the tv...
Your Convergence output is burnt.DONT turn that TV on until convergence IC's are replaced,orange glowing inside that you see it is resistors that overheating and burning.Unplug TV from outlet before more damage is done
Aug 23, 2011 | Samsung HC-P4241W 42" Rear Projection...
I have a samsung HCP4363wx/xaa rear projection tv, and everything on all chanels looks like its always in 3-D, text is unreadable, any ideas what might b wrong ??
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
You can get a repair kit with parts and instructions from www.TvRepairKits.com
Sep 24, 2010 | Samsung HC-P4241W 42" Rear Projection...
See add details
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV2_bing.gif may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 08, 2010 | Samsung HC-P4241W 42" Rear Projection...
Sony projection tv convergence issue
You will need two STK392-560 Convergence ICs and you will also need two of the 3.5 amp pico fuses as Sonys will always blow at least two of the Pico fuses. You can get replacement ICs and Pico fuses at the fiollowing link and they provide free instalation instructions. Heres the link.
http://servicemanuals.vstore.ca/
Aug 10, 2008 | Sony KP-51HW40 51" Rear Projection...
Samsung hc-p4241w problem
Look for 2 Big black chips they will be together on convergence broad STK-392-110s,120s replace both ics.Use STK-392-180s
Mar 29, 2008 | Samsung HC-P4241W 42" Rear Projection...
HX-P4241W appears yellow. Left and Right of screen are yellow
Yellow is the lack of blue. It can happen when you are running your contrast - which is your overall light level - too high.
Try turning down your contrast. On CRT tech, contrast should always be run at half what the factory allows as full, on the user controls. Full up is what calibrators call Torch Mode, and is NOT the way to get performance to be in the linear operating range of CRT tech.
If your sides are more yellow than your middle, your set may need lenstriping. Mild yellow on the sides is not uncommon, and usually not noticed. But heavy yellow on the sides would indicate that the blue image needs work on white field uniformity.
Yellow is the lack of blue, in CRT tech.
Mr Bob
Feb 02, 2008 | Samsung HC-P4241W 42" Rear Projection...
Samsung HCP4363WX/XAA
Was wondering if you got set fixed yet? STK-392-180s are the ics I use when repairing convergence.Replace both chips.
Jan 31, 2008 | Samsung HC-P4241W 42" Rear Projection...
HC-P4241W
you need to replace STK 392-110s these are your convergence chips and will cause this problem some are stk 120s 150s,up grade to 180s.
Jan 08, 2008 | Samsung HC-P4241W 42" Rear Projection...
Samsung HC-P4241W 42 in. Rear Projection CRT aging
First off, do you not know Internet etiquette? Caps are considered yelling or shouting! So please! head You have the typical convergence failure of the convergence correction IC's. They BOTH need to be replaced. If you have no solid state printed circuit board experience, play it safe and call in a pro to assist you in this repair. Good Luck
Jul 28, 2007 | Samsung HC-P4241W 42" Rear Projection...
Samsung HC-P4241W 42" Rear Projection HDTV-Ready Television Logo
274 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
