Question about Panasonic DMR-EZ47V DVD Recorder/VCR
New hdtv Please help. I just got a new hdtv and got everything set up okay. The problem - is when I turn the DVD recorder I lose signal to the tv and have no picture or sound. I have tried setting the VCR/TV on both and still have this problem. Is there anyway to be able to turn off the dvd recorder (for timed recordings) and still be able to watch the tv. I am using the HDMI connection.
  • 70 Answers
First off, scart has an auto detect feature across pin 8, HDMI does not. If you have turn your TV to the HDMI channel, and at some point turn off the HD source device you are going to get a blank screen, you have to manually turn your TV back.
In regard to whilst you are recording it sounds like you may have tuned in channels on your DVD but not your TV.
Do you have an RF aerial lead connected from the DVD output to the RF on you telly?
Do you have a sky/cable box connected to your TV via scart?
Does the DVD have DVB (digital video broadcast) if so and you have none of the above that is the problem, any tuner running off a single RF lead can only record/play 1 channel at a time. If you have no RF lead going to the TV, then the TV cannot show any terrestrial channels.
Posted on Jul 28, 2008
I have a hdtv with digital channels. I also have a vcr that can record shows. The thing is i have everything set up correctly. How do i record the shows on tv to my vcr?
A VCR will not record HDTV signals. You can only record normal digital signals. If you wish to record HDTV channels you should look at Blue Ray Recorders.
Sep 28, 2013 | Televison & Video
I have a new vhs dvd player recorder that will not record.
please note in your vhs dvd manual it tells which dvd (maxell, tdk etc.)are compatible with the recorder
okay do you have a cable/satellite box connected to tv/monitor? yes or no
yes- is the the tv on ch 3? cable connected to cable box in, cable box out connected to dvd in,(on dvd set up menu make sure broadcast is cable) dvd out connect to tv... ? please note some dvd recorder will not record HBO (you can record on vhs tape)
no connect antenna to dvd in, dvd out goes to tv.....
hope this help...
May 20, 2010 | Quasar VHQ400 VHS VCR
Are you truly free? If so, then answer the
Hello. Your digital TV is all set up to recieve the digital signal that is now the standard signal coming into your home. The old analog signal is history. If you still want to use your VHS/DVD recorder you will have to get a signal conversion box, at your local walmart or radio shack. This will take the new digital signal and convert it so your old analog VHS/DVD can process it properly. Joe
please rate my answer as very helpful....and free. thanks. Joe
Apr 26, 2010 | GoVideo Go Video DVD/VCR Combo
Watch tv properly with JVC DVD off
Some philips tv's have a built in aerial amplifier, perhaps if you bought a digital aerial booster it will improve the picture quality.
Apr 05, 2010 | JVC DR-MV1S DVD Recorder/VCR
Sony V lcd 32 inch losing digital channels and after doing a resetting scan it is ok for about 30 mins.... then screen image breaks up totally and message 'weak signal' shows on screen. Help,please.
You answered the question in your question.
''weak signal' means exactly that, however it can also mean the signal is too strong.
If you have a booster installed into the ariel remove it, if not, try one. Make sure the TV is directly connected to the ariel, not via a DVD recorder or any other devices which require an ariel input.
Sony tv's have very sensitive tuners installed so its just a case of making your aprticualr settings compatible.
Check signal strength over at www.digitaluk.co.uk
Thanks
Nov 29, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Unable to operate recorder at all.
When you are turning the recorder on it is blocking the signal for cable going to the TV. Your TV will need to be on channel 3 or 4 depending on what the dvd/vcr player channel output is set to. This is why your tv is asking you to re-scan. It is losing the video signal because the dvd/vcr is taking over. The reason why the vcr with the button on the remote is because the vcr button is changing the function of the buttons on the remote to vcr. Even though the dvd/vcr is one unit they still will act like two seperate components independent of each other. They have seperate power buttons and the dvd player part may need to be hooked up seperately with rca cables to work.
Sep 26, 2009 | Daewoo DVRS05 DVD Recorder/VCR
HT762TZ -hdmi off
Try new hdmi cable. Try different inpus on set. Try another known good signal source to determine is tv or souce device if at fault. If aother hdmi connector on set ok then replace main brd in tv, if none of the hdmi inputs work even with known good cable and known good signal sourse the replace main board in tv
Aug 29, 2009 | Panasonic DMR-EH57 HDD Recorder Player
Hooking it up correctly
If you hook up using the tuner in ILO you will lose digital signal to the HDTV (it will still go thru but only as analog) so... Use a splitter from the antenna coax to the "antenna in", then you can hook Ilo output to the tv inputs. You can watch/record analog through the ILO and still switch back digital non recording on HDTV thru its own separate tuner. Hook up the dvd player outputs to the ILO inputs(use the front ones is easiest) and then select SOURCE, pick corresponding inputs and enter. You can watch/record from other dvds that way but not from copyrighted ones, It will say protected content. I would only hook up dvd player temporarily to record from dvd player, then to watch dvd's just hook it up to HDTV. If you can select progressive scan on player to HD it might be even better picture but I don't have HDTV so I'm not sure how that works. Maybe more at this site: http://www.retrevo.com/support/CyberHome-DVR-1600MU-DVD-Players-manual/id/534ci862/t/2/ Someone says they are very similar recorders. The front covers are alike i know. Hope this helps.
Aug 18, 2008 | iLO DVDR05 DVD Recorder
Panasonic DMR-EZ47V DVD Recorder/VCR Logo
133 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
