Question about Bosch WFMC 3200 Front Load Washer
I found a Bosch WFMC3200 Front Load Washer for sale for $100 and we are in need of a washer as the transmission on our whirlpool gold went bad and repairman told us it wasn't worth the cost of repair and I thought lets be frugal because we need to be and lets buy off of craigslist. This particuliar washer has the details: Bosch front loading washer w/pedistal in gd cond but pump needs to be repaired or replaced for the machine to work. I've been trying to find out how much a new pump is to see if it would be beneficial to buy this machine. Any thoughts advice.
  • Bosch Master
  • 2,605 Answers
Welcome to FixYa.
The pump for those WFMC washers is part # 436440 and priced around $75USD at "repairclinic.com" or "searspartsdirect.com" to name a couple.
I would caution you though before going ahead and buying the pump, you may not need it. It is too common that folks mis-diagnose Bosch machines due to lack of knowledge or lack of interest, I can't say.
Often it is merely an obstruction in the pump or a stuck check ball in the sump. I'd suggest you wait until you can check it over before purchasing any parts you can't return. For $100 I'd buy any bosch as long as it isn't something major worn, like the main tub bearing gone.
Hope this answers your question. Thank you for choosing FixYa and I hope you'll take a moment to rate the info I provided for you here. Good luck.
Regards,
Macmarkus :)
Posted on Nov 08, 2010
Testimonial: "THANK YOU SO MUCH!! Not only for being quick in response but, offering your advice/opinion! We need to be blessed with an inexpensive & good washer!"
Bosch 100 series washer will not spin or agitate
Cleaned out the drain hose from the front panel. Seems to be working fine now.
Thanks
Oct 06, 2012 | Bosch Nexxt 100 Series WFMC1001UC Front...
BOSCH WFMC3200 Washer - Receiving E04 error and manual indicates clearing drain hose and pipe. How do I remove the cover on lower front of machine?
there is small hole in the cover you need to push a small screwdriver or ice pick works in the hole and then turn clockwise till it comes off.
But there will be some water come out so if you have a wet dry shop vac then use it on the end of the drain hose to remove most of the water then keep it handy when you take the plug out there will still be some water come out and you should be able to clena out the trap area
Nov 30, 2010 | Bosch WFMC 3200 Front Load Washer
I need help replacing the front door gasket and seal
Bosch WFMC3200 Front Load Washer replacing the front door gasket and seal.
This video will show you how to change a door seal on this Bosch front loader washing machine .
we have all
bosch repairs in our channel
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 12, 2010 | Bosch WFMC 3200 Front Load Washer
I have a Bosch Nexxt 100 Series WFMC1001UC/05 Front Load Washer that the brushes in the motor are wearing out. Were can I buy a set of brushes at? Any information would be helpful.
Part number is 154740 around 36 dollars from http://automaticappliance.com/ How to video from YouTube http://www.youtube.com/watch?v=N_r8d93xPYw&feature=youtube_gdata_player Different model washer but same motor. Look up videos for how to replace the belt if you have trouble. Symptoms of worn brushes include weak or no spinning.
Aug 11, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
Bosch 100 series will not drain
You need to check and clean the pump filter if you have not already done so.
This is located at the bottom front right of washer.
Unscrew anti-clockwise to remove and clean.
Mar 15, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
Bosch Nexxt 100 series front load washer
You first of all need to check the pump filter.
This should be located at the botom front right of washer.
Look for a drop down flap or cover, once located, unscrew filter anti-clockwise to remove and clean.
The pump itself is directly behind the filter housing, check there is nothing stuck in the housing.
This should solve the prob.
Please leave feedback for my solution.
Thankyou.
Jan 11, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
Bosch Washer WFMC3200.
first of all, start with you close the door,you put the set on and continue please
Sep 27, 2009 | Bosch WFMC 3200 Front Load Washer
Bosch WFMC 3200 Front Load Washer Logo
262 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
