Question about Gateway Computers & Internet
When i start my computer it says system configuration error how can i fix it ( gateway mx3417)
  • 14 more comments
  • pie61dc Jun 15, 2008
    where can i get it
    it didn't work
    it says your system has detected a configuration error
  • pie61dc Jun 16, 2008
    my son says the problem started after using the system restore
    what will i check on the boot order
    it didn't work do you have another idea pls. helped me
    the error comes after the windows logo appears.. please help me
    actually i already turned it off and then turned it on and up to now it's still loading for like 30 mins. now and i didn't inserted any cd i just turned it on.. thank you . if this doesn't work can i still post a message .. thank you very much.
    will the operating system disc can fix it. if not wher can i get the driver for windows repair.. thank you again.
    yah he can't find it.. thank you very much i will contact you ones my system work.. is the operating system disc the same w/ the windows installation disc.. thank you for the help..
    yah i will follow as soon as it stop loading.. 'coz up to now the hour glass is still there.. should i turn it off now..thank you
    ok thank you.
    ok .. thank you.. i will just wait ..
    after i followed what worldvet told me.. then after i do that it started loading up to now
    if this fix my problem i 'll still post a message.. thank you.
    and i thank you guys for helping me w/ my problem 'coz i don't have any idea about this comp. and i know that you guys have so many idea about this thank you so much and i really appreciate it..
    Guru:
  • 859 Answers
Sure you can.
Something changed in your system bios settings. When you get this screen you described, at the bottom of the screen it should present a statement, press (some key ) to enter setup or Press F1 to continue. You can press the special key to enter bios setup and then at the bottom is a guide that will say something like press F9 or another key, to set system defaults. Do that and you should be fine. Exit setup and your system will reboot. If you get the screen again do this: Press F1 to continue and then immediately, immediately press and tap on the F8 key to get your system startup menu. Choose to enter Safe Mode, then shutdown normally after you get your desktop and after power is fully off restart and you should be fine now.
There may be no need to do anything special or other than this.
Regards,
Worldvet
Posted on Jun 15, 2008
  • 3 more comments
  • Glenn Rogers
    Glenn Rogers Jun 16, 2008
    Turn you system off after you insert your Windows CD.
    Turn Power back on.
    Let the Windows installer go.
    When it reaches the point where it says 'there is already Windows installed' select "Repair"
    Let Windows repair your machine.
  • Glenn Rogers
    The Windows CD will fix it if you follow the procedure I outlined previously.
  • Glenn Rogers
    yes, it is. You will need your product key which is listed on a sticker on your pc.
  • Glenn Rogers
    Not yet, you can leave it go. You never know, it may be actually doing something. If after another hour or so you can insert the disc, turn it off and restart.
  • Glenn Rogers
    Let me point out that there is no competition between Ekse and I. We are both here to see you get your PC fixed. We will both be glad to help you as much as we can. He and I have been through this more times than you can imagine so if you get stuck do not REACT, act by asking us, one or both of us will get back to you soon.
    Rest assured and try to relax we know this can be fixed for you. Trust us, its not the money. You pay 9.95 but won't see but 3 maybe 5. So, its not the money that drives us... its the desire to honestly help you through this.
  • 1,879 Answers
Do a System Restore.
What is the exact error message by the way ?
  • monk3ybidzness
    monk3ybidzness Jun 15, 2008
    Like if you are still able to boot Windows (where you can see the Start
    button at the bottom-left part of your screen), click the Start button,
    locate & click Control Panel
    Look for anything that sez SYSTEM, open it up until you get the small
    window that sez System Properties, locate the tab named System Restore
  • Gateway Master
  • 13,433 Answers
You can use the windows installation cd to perform a repair installation.
  • 6 more comments
  • Ekse Jun 15, 2008
    Also it debends, what kind of error has accured. Are you able to get to the windows logo when its starting up / loading? or does this error come before this.
  • Ekse Jun 15, 2008
    if you don't have the disc for your windows, but if you have a xp lisence code in the cover of your pc, like this
    http://www.slimcode.com/cs/photos/blog_a...
  • Ekse Jun 15, 2008
    you can either take the pc to a shop where they can repair this for you, or you can order a replacement cd from gateway.
  • Ekse Jun 15, 2008
    It may also be a simple incorrect setting in bios as WolrdVet has pointed out.
  • Ekse Jun 15, 2008
    heres a very detailed video about bios.
    I was planing to make you a video myself but it takes too much time right now.
    Check the boot order
  • Ekse Jun 16, 2008
    the windows repair installation will most likely fix the problem, you might need to get the drivers for your system again, your sound and so on might stop working at first. thats noting to worry about its just becouse the dirvers havent been installed.
  • Ekse Jun 16, 2008
    Yes the windows installation disc you can use it to repair your windows but then you need the drivers, Il get you the drivers when you have got your pc working again.
    If you are satifyed you can press on the accept button on my solution or if you have any further questions you can ask me.
    You can use the ask me button to contact me ones you have the system working and you need the drivers if your son can't find them.
  • Ekse Jun 16, 2008
    are you in windows setup or where do you have this hourclass
Gateway desktop critical error code
Which operating system ???
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer.
Use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System.
Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK.
2.On the General tab, click Launch System Restore.
3.Select Restore my computer to an earlier time, and then click Next.
4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information.
5.Select a system checkpoint or an installation restore point, and then click Next.
6.Close all other programs.
7.To start the system restore, click Next.
8.Your computer restarts.
Repeat steps 1 through 8 until you fix your configuration issue.
if this hails to fix the problem
Restoring your Windows 7 Gateway computer to its original factory settings is a great way to get rid of pesky viruses you can't seem to remove from your computer, or simply to remove old programs and files from your computer and start with a clean slate.
Your Windows 7 Gateway computer will likely run faster as a result of deleting old and unnecessary files.
It's also a good idea to restore your Windows 7 Gateway computer to its original factory settings if you plan on selling it, or passing it along to a family member or friend.
Recover From Windows 7 Home Screen
Click the "Start" icon in the lower-left corner of your Windows 7 home screen.
Click "All Programs" in the Start menu, then click "Gateway".
Click "Gateway Recovery Management" to open the Gateway Recovery Management program.
Click the "Restore" header, then click "Restore System To Factory Default".
Click "Yes" in the "Confirm Restoration" dialog box, then click "Yes".
Click "OK" in the dialog box warning you that all of the personal data on your computer will be deleted. Your computer will automatically restart.
When your computer restarts the restoration process will begin. The process could take anywhere between 30 and 90 minutes.
Click "OK" when a dialog appears telling you that the computer has been restored to its original factory settings and that you need to reboot your Gateway Windows 7 computer.
Your computer will reboot.
After the computer restarts you will need to configure Windows 7 with your personal preferences.
Recover at Startup
Turn on or restart your computer and hold down "Alt" while clicking "F10" during startup until you are redirected to the Gateway Recovery Management program.
Click "Restore System From Factory Default".
Click "Next" to begin the restoration process.
Jul 02, 2013 | Computers & Internet
Gateway laptop error
Recover at Startup
or if still no joy
http://www.almuseo.com/download-repair?Windows 7 0xc0000185for Windows 7 0xc0000185 and associated problems.
Windows 7 0xc0000185 error message codes are almost always caused because of missing system files inside your Microsoft Windows operating-system.
When you've got Windows 7 0xc0000185 error message then we suggest that you perform an error scan.
This article provides related information that explains the best way to repair your Windows Windows 7 0xc0000185 error codes either by hand and automatically. Additionally, this guide can help you to fix most regularly occurring error code messages connected with Windows 7 0xc0000185 error code which you might possibly get.
Jun 03, 2013 | Computers & Internet
My gateway dv4200 09 power plan settings are not working properly
May 20, 2013 | Gateway Computers & Internet
My computer is stuck in hybernation mode
Hi wushuassazin:
1. What exactly do you see on the monitor screen when the computer starts?
2. Do you see any error message?
Step 1: We recommend you to start your computer in last known good configuration and check if the computer starts.
a. Start your computer and tap F8 key continuously to see advanced boot options.
b. Select Last known good configuration and hit enter.
c. Check if the computer starts.
Step 2: If the computer does not start, then check if it starts in safe mode
a. See Start the computer in safe mode
b. Check if the computer boots to the desktop.
c. If it boots, then restore the computer to an earlier time.
See How to restore Windows XP to a previous state
Step 3: If the computer does not start in any mode, then repair install using Windows XP disc
a. See Perform a Repair Installation
b. Once you've completed the installation, check if the issue persists.
Also use a system utility software like RegInOut to fix and avoid all such type of windows errors.
Hope this solution works for you.
Dec 25, 2011 | Gateway Computers & Internet
System configuration data updated ERROR,--Need a solution I have a fairly new Gateway M-1625 laptop running windows vista 32 bit, sp1. I turned it on and beeped twice (beep, beep) and gave me an...
Got a backup?
If not, download a Linux Live CD. Boot your machine with it, save all your data to an external drive and then do a complete disk format and re-install. That will be quicker in the long run.
Not sure about that PC, but on Dell, for example, you hit CTRL-F10 (I think) at power-on and it gives you the option of reinstalling the OS from the recovery partition (wiping any unbacked-up data in the process).,,Gateway is probably similar.
The Boot/BCD issue means your 'Boot Configuration Data' is hosed.
Jun 07, 2011 | Computers & Internet
What does ' a disk read error occurred press ctr alt del to restart, everytime i do it it gives me the same error??
You could have a hard drive problem. To check the hard drive boot up to the Windows XP cd in repair mode. At the C prompt type: chkdsk /r
This will start a program called Check Disk that will evaluate your hard drive and attempt to fix any errors. it Check Disk is successful it will complete 100% and return to a C prompt. You can then attempt to reboot. If Check Disk finds unrecoverable errors you will need to purchase a new hard drive and rebuild the OS.
Jun 14, 2009 | Gateway MX6453 Notebook
Error Code 1068 in Windows Vista 64
1. Click Start, and then click Help and Support. 2. Under Pick a Task, click Use Tools to view your computer information and diagnose problems. 3. In the Tools area, click System Configuration Utility. 4. In the right pane, click Open System Configuration Utility. This opens the System Configuration Utility. 5. Click the Services tab. 6. Make sure all the following services are turned on. To turn on a service, click to select the check box.
� Application Layer Gateway Service
� Network Connections
� Network Location Awareness (NLA)
� Plug and Play
� Remote Access Auto Connection Manager
� Remote Access Connection Manager
� Remote Procedure Call (RPC)
� Telephony
� LexBce Server (if you have it) 7. Click OK, and then click Restart.
If this doesnt work please reinstall the os or do a sfc/scannow it will check all system file.and will ask for the XP cd.
May 12, 2009 | Microsoft Windows Vista Home Premium...
Gateway 420GR will not boot up
Try hit F8 before gateway screen start last known. Start the computer using the last known good configuration
  1. When you see the message Please select the operating system to start, press F8.
  2. Use the arrow keys to highlight Last Known Good Configuration, and then press ENTER.
  3. If you have a dual-boot or multiple-boot system, choose the installation that you need to access using the arrow keys, and then press ENTER.
note.gif Notes
  • Choosing Last Known Good Configuration provides a way to recover from problems such as a newly added driver that may be incorrect for your hardware. It does not solve problems caused by corrupted or missing drivers or files.
  • When you choose Last Known Good Configuration, only the information in registry key HKLM\System\CurrentControlSet is restored. Any changes you have made in other registry keys remain.
  • NUM LOCK must be off before the arrow keys on the numeric keypad will function.
If this doesn't work you go into setup and make sure your system is finding your hard drive or you will have to find your restore disk. mysleuth
Apr 02, 2009 | Dell Dimension 8200 PC Desktop
When the computer starts up. "Gateway" appears on the screen. Then the computer freezes. None of the reinstallation discs do anything. How do I fix this?
Reboot and keep tapping on F8 to go to Safe Mode. Do not put the reinstallation disk yet. Once in Safe Mode select "last known good configuration".
You can also run "Chkdsk" from the C hard drive Properties if you get to Safe Mode. Double click "My Computer", right click on C drive, select Properties, select Tools tab, go to Error checking and click on "Check now" then check "automatically fix file system errors" and "scan for and attemp recovery for bad sectors" and click "start"
If that doesn't work proceed to do System Restore in Safe Mode or remove previous programs that may have caused your Windows to freeze. If you suspect virus, run your anti-virus in Safe Mode.
If none of the above works then try your XP CD (or reinstallation disk) and do a repair.
Jan 09, 2009 | Gateway 838GM (RB838GM) PC Desktop
How can i fix system configuration error
Please try to put little more explnation
or try this
Click Start button, and select Run or press windows key + R
in the Run dialog box type 'msconfig' and press enter
In the System Configuration Utility dialog box, select Startup and uncheck the unwanted programs from the start up list.
Select the Srvices tab and you can change the configuration changes here. Be sure not to uncheck anything necessary for the windows to boot.
hope this may solve your problem
Rabby
Jun 15, 2008 | Gateway Computers & Internet
Computers & Internet Logo
57 people viewed this question
Top Gateway Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
