Question about M-Audio Studiophile BX8 Main / Stereo Speaker
Where are the fuses at on the m-audio bx8 - M-Audio Studiophile BX8 Main / Stereo Speaker
  • rward99504 Nov 08, 2010
    I know where the power fuse is I'm talking about the two fueses for the amp, I do have it pulled out
    I don't see where the fuses are located at?
  • 6,993 Answers
you will find the fuse on the crossover of the speak. The crossover is where the speaker speaker wire enters
Good luck.
Posted on Nov 08, 2010
  • 656 Answers
The fusesin the system will be back of the cabin it will be marked fuse or it will be inside soldered to the board remove the cover and check the power line it will be connected series to the power line power line can be any which power is given to the board
  • rajesh raman
    rajesh raman Nov 08, 2010
    yea pull it out all check wether damaged if there might be a reason for it blowing might be the wire was short or some components in the system fried or over voltage from the source replace the fuse of the same value
How to take the big speaker out of a studiophile BX8 speaker
As you can see, there are 8 screws holding the woofer in. Remove them, lift the speaker up, but before you disconnect it....Mark + and - onto the wires...red + and black -. .http://i46.tinypic.com/14l3j0z.jpg
Aug 18, 2014 | M-Audio Studiophile BX8 Main / Stereo...
How to remove tweeters maudio bx8 speakers
Remove the backplate and the wires are often hold togeter with a tiedrap, so you need a long , how do you call it in english:) , sciccoskind tool or you can try to unplug, the plugs between the powerunit/ amplifier and you speakers . I'm busy rebuildimg m3-8 from m-audio, cause of some where cheap amp/powerunit and did it by hand and i have large hand, but put some tape around the backplatesurrounding for scratches.
And if you have them loose you can remove them.... but why?
Do you think you just can replace them for other once, think again
Jul 10, 2014 | M-Audio Studiophile BX8 Main / Stereo...
Blown circuit board
You will need to remove the blown circuit board and replace it with a new one. Unless you know exactly what components are blown and have the utilities and material to replace the components yourself.
Oct 14, 2013 | M-Audio Studiophile BX8 Main / Stereo...
Cracklin/popping with m audio bx8 d2's thru fast tack mk2
Check for flucuations in your power supply. If none then put a shield sleeve on your cord.
May 03, 2012 | Avid M-Audio BX8 D2
M audio bx8 blows a fuse
best solution wrap the blown fuse with a piece of tin foil and put it back into the fuse terminal and you shouldn't have a problem.
Mar 03, 2012 | M-Audio Studiophile BX8 Main / Stereo...
Where can I buy replacement speakers (tweeter and the 8 inch) for a bx8? I can do the rrepair myself
depends on where you are located...try online at audiostore.com, amazon or ebay...otherwise chect the nearest electronics store
Jan 31, 2010 | M-Audio Studiophile BX8a Speaker
Purchased used m audio w/o connect cables for cpu
The BX8's take either a TRS or XLR inputs only. from a laptop, you can get a 1/8" stereo to 1/4" l/r mono splitter cable at radio shack that will plug into the back. then just plug up and you will be good to go for about $10.
serously, though, you should save up and buy a studio level firewire or usb card like the presonus inspire and use that to connect. for 200 bucks more spent, you would have much better quality recordings and playbacks that are matched and line level.
BOO-YA!!!
Dec 22, 2008 | M-Audio Studiophile BX8 Main / Stereo...
Bx8 monitors problems
You will need to REPLACE THE WOOFER / DRIVER on this unit. Cost for a new driver is about $80.
- DJPA
Nov 04, 2007 | M-Audio Studiophile BX8 Main / Stereo...
M-Audio BX8 blows a fuse
If your monitor is crackling and fizzing, that is not a fuse issue, unless the fuse you have installed is underrated. It sounds like you have a bad driver/woofer, and need to get it replaced. CLICK HERE FOR THE REPLACEMENT DRIVER for this model.
- DJPA
Jul 05, 2007 | M-Audio Studiophile BX8 Main / Stereo...
M-Audio Studiophile BX8 Main / Stereo Speaker Logo
154 people viewed this question
Top M-Audio Audio Players & Recorders Experts
Michial Gueffroy
 Grubhead
Grubhead
jason
Are you a M-Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
