Question about HP Officejet Pro 8500 Wireless All-In-One InkJet Printer
HI! I just received a replacement printer for my old that just broke and it will not come out of "checking device" mode on the printer touch pad. What should only take a few minutes has now been 2 hours! Can you help?
  • 240 Answers
Try unplugging the power cable for about 5 minutes and then plug it back in. If the message comes back again then you probably need to have it replaced again because they sent you a lemon.
Thanks,
Pat
Posted on Nov 08, 2010
  • crankyed Apr 12, 2011
    I am experiencing the same problem with my new replacement HP 8500A and I find it very frustrating. I have never had such problems with the 3 prior HP printers I have owned. I'm reluctant to call their help desk in India.
    ah
  • Patrick Wolthausen
    Patrick Wolthausen Apr 14, 2011
    Yeah calling tech support in India is never fun, however if power cycling the unit does not help your best bet would be to just get this one replaced again while the warranty is still good.
    There might be another way to reset the printer and fix this issue however there is a good chance the error comes back. Even if there is a fix, these companies would rather send you a replacement to avoid bad press then leave you stuck with a possible lemon.
    Thanks,
    Pat
Printer stays in offline mode
Go to your control panel
Then go to Devices and printers
Make sure there is a check mark on your Dell printer so that it is your default printer.
Mar 27, 2013 | Dell 3130cn Color Laser Printer
Tip
How to Troubleshoot CF-19 The Panasonic Toughbook CF-19, commonly known as...
How to Troubleshoot CF-19<br /><span style="font-style: italic;">The Panasonic Toughbook CF-19, commonly known as simply the Toughbook 19, is a laptop computer geared towards people who work on location, such as field workers or military personnel, who require a sturdy and resilient device. Unique features of the model include its screen which can display clearly in bright sunlight, its touchscreen function and its backlit keyboard. If you experience errors or malfunctions with the CF-19, troubleshoot it to diagnose and solve the problem before replacing the device or seeking professional repair.</span><br style="font-style: italic;" /><br /><span>Instructions</span><br /><br /><span>Device Turning On</span><br /> <ol> <li> <span style="font-style: italic;">Check that the AC adapter is connected properly. One end should be plugged into the laptop and the other end should be plugged into a working AC outlet. If the adapter is disconnected at either end, connect it.</span></li> <li style="font-style: italic;"> Disconnect any device connected to the laptop's USB port or ExpressCard slot. A malfunctioning device may cause the laptop to malfunction and not turn on.</li> <li style="font-style: italic;"> Press the "Fn" and "F8" at the same time to turn off "Concealed Mode." This mode disables the power functions of the device.</li></ol><span>"Remove disks or other media. Press any key to restart" Error Message</span><br /> <ol> <li><span style="font-style: italic;"> Remove the floppy disk or CD-ROM from the device and press any key. This message indicates that the disk does not contain system startup information and cannot run on the device.</span></li> <li><span style="font-style: italic;">Disconnect any device connected to the laptop's USB port or ExpressCard slot as problems with these device's may also cause this message to appear.</span></li> <li><span style="font-style: italic;"> Contact Panasonic Technical Support if this problem persists after attempting Steps 1 and 2 as this may be a sign of a problem with the laptop's hard disk and it may need repairing or replacing.</span></li></ol><span> No Display/Screen is Blank</span><br /> <ol> <li style="font-style: italic;"> Press the "Fn" and "F3" keys simultaneously to switch to "Internal Display" mode as the device may have been set on "External Display."</li> <li style="font-style: italic;">Check if the device is in "Power-Saving" or "Sleep" mode by pressing any key on the keyboard. The screen should come on if the device was simply in "Power Saving" or "Sleep" mode.</li> <li><span style="font-style: italic;"> Turn on the display screen or monitor of the connected device if you have the laptop set on "External Display" and want the display to come up on that device.</span><br /></li></ol><span style="font-style: italic;"><span>Hopefully this can help<br /><br />regards<br />multilinkent</span></span><span><span><span style="text-decoration: underline;"><span style="font-style: italic;"><span style="font-weight: bold;"><br /></span></span></span></span></span>
on Jul 08, 2011 | Computers & Internet
Rpc server is unavailable when installing printer
According to the error message, I assume that the spooler service cannot find out the printer on the network.
You may set the startup type of Printer Spooler service to Manual or Delayed Start for a test.
You could go to Customer support- just dial +1(800)243-0051 Toll Free.
Apr 27, 2017 | Office Equipment & Supplies
When i connect my wd 500 gb external hard disk to my pc windows notifies me with an error reporting "problem occurred during hardware installation.your new hardware might not work...
  1. Restart the computer in Safe Mode.
  2. Rename the Driver.cab file that is in the following folder:
    C:\Windows\Driver cache\i386
    For example, rename the Driver.cab file as
    Driver.old.
  3. Insert the Windows XP CD-ROM into the CD-ROM or DVD-ROM drive.
  4. When the Welcome screen appears, click
    Perform additional tasks.
  5. Click Browse this CD, and then double-click the I386 folder.
  6. Click the Driver.cab file, and then on the
    Edit menu, click Copy.
  7. In Windows Explorer, open the following folder: C:\Windows\Driver cache\I386
  8. On the Edit menu, click
    Paste to paste the Driver.cab file in the C:\Windows\Driver cache\I386 folder.
  9. Remove the device that you tried to install.
    For example, if you received the error when you tried to install a printer, follow these steps to remove the printer:
    1. Click Start, click Control Panel, and then click Printers and Other Hardware.
    2. Click Printers and Faxes (or the icon representing the type of device that you want to remove).
    3. Right-click the printer that you want to remove, click
      Delete, and then click Yes to confirm deletion of that printer.
    -or-
    Use Device Manager to remove the device. For example, if you received the error when you tried to install a modem, follow these steps to remove the modem:
    1. Click Start, right-click My Computer, click Manage, and then click Device Manager.
    2. Expand Modems, select your modem, and then press DELETE. Click Yes to confirm.
  10. Restart the computer. Your new device should be detected and automatically installed.
Nov 12, 2017 | Western Digital WD HDD 500GB SATA 25"...
HP 1312 printer running wirelessly from a laptop (Windows 7). Has always worked fine. Turned printer off when we were on vacation; now printer is "offline." Have reinstalled printer driver and...
Hi!
The problem you described can have multiple causes.
But one is more common:
Every device on your home network (wired or wireless) has its own IP adress. Usualy this IP adress is given automatically by the DHCP server contained in your wireless router. When a device is turned off for some time, it can receive when turned on again another IP adress than before.
So, if your printer has no static IP adress (entered by yourself during printer setup), it is very likely that it has now other IP than the address known by your computer. The computer sends the print jobs to the old adress and of course, nothing is printed.
Please check in your printers proprieties the adress of the TCPIP port assigned tom it, and also check on your router's management site what clients are connected to it.
The network communication between the computer and the printer can be checked by issuing a PING command from a command prompt.
e.g ping 192.168.1.***
the numbers are one example of an IP adress.
Please let me know if it helped, if you need more help ask again, I'll be glad to help you to get the problem solved.
Regards,
Bogdan
Aug 21, 2011 | Office Equipment & Supplies
I have hte xerox phaser 3100mfp & when I try to scan some paper to media device it says "memory full press <stop>" what should I do? P.S. I've tried to restart the device but...
13 Memory full The machine memory is full (there are too many documents that have been received but not yet printed, or waiting to be transmitted).
Print the received documents.
Delete or transmit in immediate mode the documents waiting to be transmitted.
14 Memory full Received document memory saturated.
Jul 13, 2011 | Xerox Phaser 3100MFP/S Laser Printer
Lexmark x5470 the machine received faxes but does not print them. saying "fax jobs in memory"... how do i print them?!?!
It could be because one of your cartridges has low ink level, thus printer is not able to continue printing the fax message. Open the printer cover and replace your cartridges (without navigating away from the fax mode). Once cartridge/s has been replaced, just hit the Check mark to print the fax message.
May 18, 2011 | Lexmark X5470 All-In-One InkJet Printer
I've received the error message: "Printer
Mostly, printer cartridge error occurs when the printer head is unable to identify the cartridge properly. And the basic reason behind this is that the cartridge is improperly attached. To reattach the cartridge, turn on the lid of the printer and then remove the cartridge from the printer head. Check the cartridge to make sure that there are no scratches or other damaged parts that can contribute to a printer cartridge error report. Take note that the cartridge should not be left open for more than 30 minutes; otherwise the ink will start to dry up and the cartridge will get clogged.
Dec 23, 2010 | HP Photosmart C4580 All-in-One InkJet...
Samsung SCX 4521F: Incoming faxes 'receiving' but fail to print
Has the main board been changed??if yes the liu board(modem) board needs replacing.
Jul 18, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Bought today a hP7200 All-inOne Series. Set up and received the following: Error message "Incorrect Ink Cartridge: The following ink cartridges cannot be used after device initializaed and must be...
hi friend
try remove your printer cardige & rinstall it if u have not remove your printer cardige nosel raper so remove tape of the nosel try to install & print
Apr 13, 2008 | Office Equipment & Supplies
HP Officejet Pro 8500 Wireless  All-In-One InkJet Printer Logo
176 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
