Question about T-Mobile Dash Smartphone
My power button broke on my t mobile dash smartphone, is there another way to turn the phone on
  • 27 Answers
First thing I would attempt is a battery pull. This usually makes the phone turn on into a full use mode.
Posted on Nov 08, 2010
My t-mobile dash power button doesn't work. The phone still takes a charge. Is there another way to power the phone up?
check the switch cause it may have a defect.or maybe it was remove from the board that cause it not to be turn on.
Oct 05, 2009 | T-Mobile Dash Smartphone
How do you turn on a t-mobile dash smartphone
It's a small round button on the back/side of the phone.
If holding the phone w screen facing you, the power button is on the top left, outer edge of the phone. Just hold the button down till you see the screen light up.
If holding the phone in your left hand with the screen facing you (without your thumb covering the screen), the power switch should likely be under your left thumb as you naturally hold the phone.
Aug 06, 2009 | T-Mobile Dash Smartphone
My T-Mobile Dash has frozen, now won't even turn on..help?
Something you might want to try is the Hard Reset. Here is a link thst will show you how it's done. Very easy. Good luck.
http://www.repairmycellphone.net/how-to-perform-a-hard-reset-on-a-t-mobile-dash/81/
Jun 22, 2009 | T-Mobile Dash Smartphone
My tmobile dash power button isnt working
This is extreme, but my Dash phone is alive again. After pushing the power button HARD! for an hour, I broke the button, and pushed it inside the phone. I ripped the button out of the phone with a knife, and carved away the plastic so I could see the circuit board inside. (about a 1/4" x 1/4" hole). Looking in, there are 2 empty holes in the middle -the former mounting legs for the button. To the left are 2 leads (solder points), to the right there are 3 solder points. Using a screwdriver, I jumped (made a connection) with the 2 leads closest to the edge of the phone...ie: 1st solder joint to the left of the holes, and 1st solder joint to the right of the holes, and it powered up. I will cover the hole with black electrical tape. I build prototypes for architects for a living, so this is a successful solution.
Apr 23, 2009 | T-Mobile Dash Smartphone
My phone is frozen
Pop out the battery and sim and wait 10 seconds and put them back in..
here is 2 useful tips:
How to Hard Reset a T-Mobile Dash/ HTCS620:
1. Select Start
2. Select Accessories
3. Clear Storage
4. Type in 1234
5. Select Yes
How to Hard Reset a T-Mobile Dash and HTCS620 without the operating system:
Turn the handheld off, hold the two soft keys (the dashes to the left and right of the phone buttons) hold the power button for 1-2 seconds and then release the soft keys. It should prompt you to clear storage. The “send” button is considered as the green phone button.
Feb 17, 2009 | T-Mobile Dash Smartphone
I hate t-moile...with a passion
do a hard reset turn the handheld off, hold the two soft keys (the dashes to the left and right of the phone buttons) hold the power button for 1-2 seconds and then release the soft keys. It should prompt you to clear storage. The “send” button is considered as the green phone button.
you will lose everything because it puts it back to factory resets but it will power on
Jan 28, 2009 | T-Mobile Dash Smartphone
T mobile dash won't power on
Have your tried taking the battery off to reset the phone itself? You probably need to go to your t-mobile store and have the button/ phone replaced/repaired... sorry
Nov 17, 2008 | T-Mobile Dash Smartphone
Turn on
please see if you press any of the buttons it swtiches or on or if you receive a call..
another option is that you could remove the battery and reiinsert it..most devices restart..also check if the device has a reset button at the bottom,pressing that also starts the device(it does so on most PDAs and pocket pc phones)hope it helps!
Oct 31, 2008 | T-Mobile Dash Smartphone
Passcode locked
turn off phone, keep pressed the 2 tow buttons ( 2 under the screen)while holding press power once after screen comes on press green call button once wait then ok
Apr 04, 2008 | T-Mobile Dash Smartphone
T-Mobile Dash Smartphone Logo
66 people viewed this question
Top T-Mobile Computers & Internet Experts
ismael castillo
Martin Murray
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
