Question about Canon PIXMA MP780 All-In-One InkJet Printer
Loading legal paper
I am going out of my mind as I cannot figure how to make this tray convert to legal
  • 197 Answers
That's in the printing set up in the application you are using.
Posted on Jun 16, 2008
Hp P3015 printer
What you need is the 500-SHEET Laser jet Tray CE530A, It automatically print on two different types of paper such as plain paper and glossy brochure paper without manually loading paper trays for each print job. And Save time and improve the performance of individuals and work teams with the increased paper capacity of this 500-sheet paper tray from HP. With more sheets of available paper, users spend less time refilling paper trays. I hope to hear from you soon.
May 11, 2013 | HP Office Equipment & Supplies
I cant get my printer HP2055 dn to print letter paper..it just goes to the legal tray (3). I also can't figure out how to get to the menu on the printer to see if the trays are set correctly.
Go to your menu and select paper handling. From there you can reset the paper settings. If paper will not pull from tray 2 you probably have worn out feed rollers.
Feb 12, 2013 | HP LaserJet P3005n Printer
Hello, I have a question about the HP 1312 all in one printer. Does it print on legal size paper and where do I load the legal size?
Yes, it can print on legal size paper. Do the following:
Lower the paper tray, and if necessary, slide the paper-width guide to the outermost position.
Fold out the paper-tray extender to catch paper as it exits the device.
Tip: For best results when loading legal-size paper, fold in the paper-tray extender before loading the paper to avoid a paper jam.
May 13, 2011 | HP Office Equipment & Supplies
My Lexmark T640 does not seem to recognize paper "tray 2". I want to print legal, but it only prints from tray 1. How can I get the printer to recognize and use tray 2 so I can print legal AND letter?
2 things
1st make sure the paper guides are set correctly on the trays for legal make sure it's exactly on legal or it put the tray into universal mode. (To clarfiy the guides in the back which allow you to put legal in the tray.)
2nd Go into menu and then to paper menu and adjust/ confirm the settings for tray 1 and 2. Based on your question tray 1 is letter and tray 2 is legal, so make sure both of the tray size and type are set correct.
Oct 21, 2010 | Lexmark T640 Laser Printer
IMy wife pulled the paper tray completely out of
Loading your paper
Paper loading tips:
● Load paper with the side to be printed facing down.
● You can print photos and documents on a wide variety of paper sizes, from
8 x 13 cm (3 x 5 inch) up to 22 x 61 cm (8.5 x 24 inch). The 10 x 15 cm
(4 x 6 inch) photo paper is available with and without tabs.
● Before loading paper, pull the Main paper tray out (use the Main tray release or
the tray grips) and slide out the paper-width and paper-length guides to make
room for the paper. After loading paper, adjust the guides to fit close to the edges
of the paper without bending the paper. When finished loading paper, push the
Main tray back in all the way.
● Load only one type and size of paper at a time in the same tray.
● After loading paper, extend the Output tray extension to catch your printed pages.
Use the directions in the following table to load the most commonly used paper sizes
into the printer.
Paper type How to load Tray to load
Any supported
photo or plain
paper media
1. Extend the Main tray by
pulling it out with the Main
tray release or the tray
grips.
Load the Main tray
Chapter 2
(continued)
12 HP Photosmart 8200 series
2. Slide the paper-width and
their outermost positions.
3. Load paper with the side
Check that the stack of
paper is no higher than
the top of the paperlength
guide.
4. Adjust the paper-width
inward until they stop at
the edges of the paper.
5. Push in the Main tray all
the way in.
6. Make sure the light on the
Photo tray button is
turned off to enable
printing from the Main tray.
Load paper and adjust guides inward
1 Paper-width guide
2 Paper-length guide
1 Push the Main tray all the way in
Aug 03, 2010 | HP Photosmart 8250 InkJet Printer
How to print with the legal paper?
follw the given step and check-
1-Before printing your document, be sure the page size is set to legal paper. Go to "File> Page Setup" and then click on the "Paper Size" tab. Select "Legal" from the drop-down menu.
2-Go to the printer and take out the paper tray. Remove the letter size paper.
3-Insert about one half of the package of legal size paper into the tray, depending on the depth of your tray. Larger printers can accept an entire package, while smaller ones cannot.
4-Make sure that the paper goes underneath the metal clips located at both the front and back of the tray.
5-For printers that don't have a tray, you'll have to manually feed the legal size paper. Locate the paper feed either on the front or rear of the printer.
6-Put a few sheets of legal size paper into the paper feed. The paper should be placed as close to the rubber spindles as possible. These spindles will draw the paper into the machine and feed it through the printer.
7-Print a test page.
Thanks,
Dec 03, 2009 | Brother HL-2040 Laser Printer
Imagerunner 1023if How do I change paper size on printer
you need to change the paper size on the copier or the paper tray dial.you can also select a paper tray from the printer menu..Alt set the printer properties to a paper tray with legal paper and it should overide the setting
Aug 10, 2009 | Canon imageRUNNER 1023iF Black and White...
Printer will not scan pictures.
Introduction To use the scan features, the HP All-in-One and computer must be connected to each other and turned on. The HP All-in-One software must also be installed and running on the computer prior to scanning. To verify that the HP All-in-One software is running on a Windows computer, look for the HP Digital Imaging Monitor in the system tray at the lower right side of the screen, near the time. NOTE: Closing the HP Windows system tray icon can cause the HP All-in-One to lose some of its scan functionality and result in a No Connection error message. If this happens, correct it by restarting the computer or by starting the HP Image Zone software. Follow the instructions below to scan documents from the all-in-one to an application. Make a Scan Step one: Load paper
  1. Open the paper tray door. Figure 1: Opening the paper tray door c00315283.gif
  2. Pull the paper tray extender toward you, as far as it will go. Flip the paper catch at the end of the paper tray extender to open the extender the rest of the way. WARNING: Legal paper might get caught on the paper tray extender if it is fully extended when you print onto legal paper. To avoid a paper jam when using legal-size paper, do not open the paper tray extender.
  3. Squeeze and hold the tab on the top of the paper-width guide, then slide the paper-width guide to its outermost position. Figure 2: Sliding the paper-width guide to the outermost position c00315284.gif
  4. Tap a stack of paper on a flat surface to align the edges, and then check the paper for the following:
    • Make sure it is free of rips, dust, wrinkles, and curled or bent edges.
    • Make sure all the paper in the stack is the same size and type.
  5. Insert the stack of paper into the paper tray with the short edge forward and the print side down. Slide the stack of paper forward until it stops. NOTE: If using letterhead, insert the top of the page first with the print side down. For more help on loading full-size paper and letterhead, refer to the diagram engraved in the base of the paper tray. Figure 3: Inserting paper into the all-in-one c00315285.gif Squeeze and hold the tab on the top of the paper-width guide, then slide the paper-width guide inward until it stops at the edge of the paper. Figure 4: Sliding the paper-width guide to the edge of the paper c00315286.gif Do not overload the paper tray; make sure the stack of paper fits within the paper tray and is no higher than the top of the paper-width guide.
Step two: Load the original NOTE: Many of the special copying features will not work correctly if the glass and lid backing are not clean.
  1. Lift the lid and place the original face down on the left front corner of the glass, with the sides of the original touching the left and bottom edges. NOTE: For more help on loading an original, refer to the guide engraved under the glass.
  2. Close the lid.
Step three: Scan to an application NOTE: To use this feature, you must have installed the full software package and the HP Digital Imaging Monitor must be running.
  1. Press Scan on the control panel. A preview image of the scan displays in the HP Document Viewer window on the computer, where you can edit it.
  2. Click Done or Finish in the software. The HP All-in-One sends the scan to the HP Image Zone software, which automatically opens and displays the image.
NOTE: To stop scanning, press the Cancel button on the control panel, or in the HP Image Zone software, click Cancel . Have a good day,
Jun 18, 2009 | HP PSC 1410 All-In-One InkJet Printer
Loading legal-size paper
:) it should load in the same tray as the letter size, you may need to adjust the tray adjustments to accomidate it, the paper setting are located in the print settings are you click print.
Oct 13, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Canon PIXMA MP780 All-In-One InkJet Printer Logo
old marine
old marine
