Question about Dell Latitude D600 Notebook
There are two blinking green lights that will not go off. The computer screen is dark. when i press the turnoff button, the computer green light on the right hand side of the computer continues to stay on. On the side of the laptop there are two lights blinking. How do I get these lights to go off or turn this computer off
  • 27 Answers
Unplug the laptop and remove the battery. The discharge the laptop by pushing the power button for 15 seconds while it is unplugged and does not have the battery installed. Then put the battery back on and power it up, and use your laptop as you normally would.
Posted on Nov 08, 2010
My toshiba at200 table 10.1 wont turn on
1. When you press the power button to turn it on, do you see any thing on screen, like the toshiba boot up screen or something like that. Or is it completely blank (black color) always.
2. Can you see a faint image of your desktop (try to see it in dark place with flash light). This is important to confirm.
3. Also, when you press power button, do you see the LED lights on laptop blinking or solid green (which ones are in blinking/solid) and do hear any sound ? Or do you feel that your laptop doesnt even try to boot.
4. Can you hear any Beeps when you try to turn on the computer. If yes, what is the sequence of those beeps.
Continued......
If you answers are -
1.
blank
2.
no image
3.
only the satellite light is blue, the powercord is blue and the battery is blue
4.
no noise
Please do the following carefully and let me know result :
1. Shutdown and Unplug your laptop.
2. Remove the battery from the laptop.
3. Wait 2-3 minutes
4. Now press ON (power button on laptop) for 1 minute
5. Then release the finger and wait one more minute.
6. Now plug in the power cable (dont insert battery yet) and press ON button.
7. Did your screen start working now ? (do you see windows loading)
Jan 04, 2015 | Video Game Consoles & Games
Big Screen Televison problem
1) pull chassis ( requires un-hooking extensive wire runs)
2) turn chassis upside-down
3) solder any / all bad connects,esp. regulator pins
Look for electrolytic capacitor leakage evidence =
dark,discoloration of trace material
4) replace any bad capacitors
5) re-install chassis and test
Nov 05, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Sony Bravia KLV-40X250A power indicator blinks once but screen is black
um u should turn your tv off for like 10 minutes , i think yourr tv is a internet tv so let it cool sometimes sony internet tvs freeze with black screen so try it out.
good luck :)
Aug 06, 2012 | Televison & Video
I have a Mitsubishi WD-62525 HDTV that suddenly wont turn on. Just has a green blinking light when you hit the power button. Any ideas?
I found this on another website, most likely it is your power supply capacitors.
  1. Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
  2. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
  3. Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
  4. Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  5. Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  6. Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
  1. DM Module Capacitors have FAILED.
  2. DM Module is defective.
  3. EEPROM Board failure
  4. Power Supply failure.
Feb 28, 2011 | Mitsubishi WD-62525 62" Rear Projection...
My Sony VAIO VGC-RB43 PC cannot reboot there is a green light blinking in the back and i want to know how to reboot my computer.
if able u can reboot by accessing start button and clicking turnoff and choosing restart. some pc's have restart button under power button. if not you can shut it down by holding pwr button for 10 seconds. some computers will not reboot if your hardware abstraction layer (HAL) was corrupt. if so you have to reinstall it. u can just follow help options in your pc help by pressing F1 and seraching for HAL.
Nov 27, 2009 | Sony VAIO VGC-RB43 PC Desktop
ACER AL1715 PowerLed blinking only,no picture,flash about .5secs
This sounds as if you are using the hibernate feature in windows reboot it and reset the power options to hibernate never check the vid connection as well
Dec 19, 2008 | Acer AL1715 17" LCD Monitor
I have a mitsubishi 1080 projection tv. I wont turn on, the green light just keeps blinking.
Check the manual...blinking green light is normal. The unit is powering down cooling the lamp. It could have been a shut down command through pressing the off button by accident. If problem continues I would unplug tv and power on/off. Steady green. Next to the lights is a small indentation where you can reset the TV to the defaults. Take a paper clip ...power on..and put in the center. The green light will blink for a minute or two then go dark. THen power up.
Dec 10, 2008 | Mitsubishi WS-55513 55" Rear Projection...
I need to know what the error codes 5100, and 5700 mean, and what causes those errors to come up on the screen. Thank you
Try resetting the printer:
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5) Press the Power button. The LED lights in green, and the selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
6) Power off then back on and test.
Jun 20, 2008 | Canon PIXMA iP90 InkJet Printer
NEC VT 470 projector won't work at all
Try pressing the HELP button. Don't release and press the power button. The LED lights should blink. Release then try to power on again.
Jan 11, 2008 | NEC Replacment Lamp Projector Lamp for...
Dell Latitude D600 Notebook Logo
136 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
