Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
Ran HE3 without Water, it's now locked up
We went on vacation, and turned off the water. When we returned, my wife tried to run the machine without turning the water back on.
It ran for a while and then began beeping. I turned the water back on, but to no avail. It now seems to be in a drain mode, the door is locked and we can't seem to abort the cycle or restart.
Is there any way to reset this thing (unplugging and plugging in again does not seem to reset it).
  • Anonymous Sep 13, 2008
    Same with us, ran machine, forgetting that husband cut off the water. Machine makes draining noise, wont unlock, did some beeping, couldn't cancel, unplugged then plugged two times to no avail...
    Novelist:
    Champion:
  • 261 Answers
Unplug the washer and wait 30 minutes, sometimes the next morning for the machine to reset. Make sure the water is on because it while find multiple failures and lock up, Secondly you can try putting the machine into diagnostic cycle to ensure it is ok. Press drain/spin and select no spin for spin speed finally press prewash quickly two or three times and let it run, any flashing codes?, hit prewash again after writing the codes down.
Posted on Sep 14, 2008
Nespresso Maestria pump isn't primed
We had the same problem and were ready to return the device when we were able to fix it. Here is what we did:
1. Fill the water tank all of the way and place in machine
2. Let the tank sit in position for a few hours (we let ours sit for 3)
3. Run the descaling option
4. Run a few cycles of the "longo"
5. If the machine is still not working repeat the process (Ours started to run after the 2nd cycle)
It just appears that the pumps are shipping with air in them and needs patience to get it out. Once you get it going though you won't regret it :)
Dec 20, 2012 | Nespresso Maestria Rosso
Went of vacation and just returned to a puddle of
your ptc relay and contactor on the compressor body is defective,unplug the unit,remove the spring wire or clip that holds it onto the compressor and install a new one,also if it has a run capacitor replace this also
Mar 18, 2010 | Freezers
We went on vacation and turned off the water.
Turn on the water, unplug machine and plug it back in.
Sep 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Doesn't drip through. Don't know where the coffee water went to?
When setting up a new machine, it requires 2 full decanters of water to be poured into the machine. After you have done this, then you plug the machine in and turn on the vacation switch on the side of the machine. After 15 min, then you will pour in 4-10 cups of water and it will force out the hot water from the tank in the back and brew the coffee. If this doesn't correct the problem, then please call customer service with the model and date code.
Sep 11, 2009 | Bunn NHB Coffee Maker
Ran without water will not fill now
Try unplugging the machine for 30 minutes then plugging it back in. I am worried that the pump is bad due to the fact that it needs water to add resistance to work properly and without water the pump spins so free the it burns itself out. But first try unplugging the dishwasher first
May 22, 2009 | Bosch 24 in. SHE43C05UC Stainless Steel...
Front Load Washing Machine Filling On It's Own
the inlet valves are shot. what happens the coils in the inlet vales can no longer hold the water from going into the unit, causing water to run into unit when not in use. replace the inlet valves and you should be good to go. the inlet valves can be removed by, removing top panel(3screws in back), disconnecting hoses, taking the small clamp on the small hose connected to the dispenser. theirs a small screw holding the inlet valves from back pane, remove old inlet valves and replace and you should be all set. hope it helps.
Apr 02, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Check that the drive belt is OK take it from there thenClose Ireland bye bye
Nov 21, 2007 | Whirlpool Duet GHW9150P Front Load Washer
RS2556SH Side by Side - Icemaker not filling; fill tube not iced over!?
press the reset button (black) on the bottom of the icemaker, the system will go through a cycle, and water will pour into the tray.
Oct 23, 2006 | Samsung RS2630SH Side by Side Refrigerator
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
115 people viewed this question
Sal De
fordexpert
Robert Rankin
